got a deal on 97 f450 ? - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > F-250 & F-350 1986-1997 & Other Ford Trucks > 1994-1997 Power Stroke Technical Info
Thread Tools Display Modes
  #1
Old 10-09-2012, 12:59 AM
babydoll
Offline
Member's Gallery
Question got a deal on 97 f450 ?
bought a f450 240 k
wont start unless u pull it starts pretty well if its warm and runs pretty well. how many amps do the glow plugs pull [full set] voltmeter does not move at all when the light goes off someone has ethered it and blew the air cleaner apart, cranked on it a lot and never started till we pulled it where do i start? glow plug relay does not seem to be working. it did hit a few times when we cranked it
hope I started this the right place read a lot but havent posted any.
Old 10-09-2012, 05:56 AM
speeddemon31176's Avatar
speeddemon31176
Offline
Demon Dually
Member's Gallery
Re: got a deal on 97 f450 ?
Test the glow plugs for resistance individually via the pins at the valve cover harnesses. You can jump out the glow plug relay across the large terminals and see if it starts that way. Ether is a bad sign as that means there are probably several bad glow plugs with the tips blown off or swelled along with cylinder wall damage. If the glow plugs are actually working you are looking at a couple hundred amp draw(250 ish).
__________________
  #3
Old 10-09-2012, 08:51 AM
babydoll
Offline
Member's Gallery
does not have any power coming to the glow plug relay
connected cable from bat post to relay for a few seconds some resistance there , does ether destroy the glow plugs? hope they werent working when they gave it ether but something blew the air filter apart and part of the piping, I ll test the glow plugs and hope for the best, thanks
  #4
Old 10-09-2012, 09:15 AM
jtgf250's Avatar
jtgf250
Offline
Member's Gallery
The explosion from ether is bad for the motor just in general. If you dont have power to the relay, start there first. The meter isnt going to move when the glow plug light is off do to the fact that the glow plugs are off. All they do is heat the air in the cylinder and that helps ignite on the compression. Thats why it starts ok when warm out. I would bet the plugs are bad and a set is about $80-$100 bucks. No real need in spending a pile on them. I would certainly take care of the air filter and piping though. Good luck
__________________
2003 F-250 CCLB 7.3L
Lifted sitting on 315/75/16s, Afe stage 2 with pro guard 7, 4" turbo back, IAH delete, Triple Guages, TGC dual steering stabilizer, Bilsteins all around, 6.0 Trans cooler, polished intake y pipe, foil delete, and ccv mod, PHP Hydra chip
  #5
Old 10-09-2012, 11:51 PM
babydoll
Offline
Member's Gallery
update , found a corodded broken wire going to glow plug relay [power supply from relay] deteriating connectors going to valve covers at least three, still wont start by cranking, puts out a lot of white smoke, hits good but wont keep running can u get new connector ends, or do u have to buy the whole harness ? at least some of the glow plugs are working and would be hard to tell how many with the bad connectors. wondering what this truck would be worth, have about 900 in it now I guess the high pressure pump is good with it running when u pull it
  #6
Old 10-10-2012, 02:13 AM
speeddemon31176
Offline
Demon Dually
Member's Gallery
The pigtails are readily available at any parts store including ford and international. Fix the wiring for the gpr and replace the glow plugs and I bet she starts just fine.
  #7
Old 10-10-2012, 02:29 AM
diesel_brad's Avatar
diesel_brad
Online
STILL LEARNING
Member's Gallery
Just make sure to use FORD/beru glow plugs. Anything else is looking for problems
Also, You can save a BUNDLE by using s WESTERN plow solenoid in place of the OEM one and it is BETTER #56131K And they are $12 vs 75-100 for a ford one
__________________
I am probably the most hated person on here, and I don't care
97 CCSB 4WD DRW 7.3 5spd DP Tuner, 6637, Flo-Pro SS Exhaust, 99 I/C, T500, Autometer gauges, Valair Organic clutch, PFM 2.25" RSK, SD springs Front/rear 315/75/16s,
Bunch of other trucks
  #8
Old 10-10-2012, 03:39 AM
babydoll
Offline
Member's Gallery
are the pigtails the plastic connectors on the end that go inti the valve cover? that is what is bad Thanks
  #9
Old 10-10-2012, 03:51 AM
speeddemon31176
Offline
Demon Dually
Member's Gallery
Yep those are the pigtails. If those are burnt/melted, I would suggest pulling the valve covers and checking the connectors and UVCH harnesses underneath for damage as well. If they are damaged and you just replace the pigtails then you will just end up damaging them again.
  #10
Old 10-10-2012, 04:04 AM
babydoll
Offline
Member's Gallery
thanks agin I ll go deeper and check it all out
(View-All Members who have read this thread : 204
04La4iat, 300,000 and counting, 444CuiOBS, 4duggan, 6.9PoweredScout, 7.3LStrokeR, 7.3maniac, 7.3_Stroker, 87 F250 6.9L, 94.5 Stroker, 95F250, 96F350Kid, 97-7.3powerstroke, 97psd16.5mpg, 97strokeme, 97supercab, a5t1, Al Mighty, Alvapowerchoke, Aminator, babydoll, BadDogPSD, bcangelo, bdblk12v, Believer45, bigdog379x, biggreen96, BigGreenStroker, bjc, bknight187, BlackBeauty96, blackf250, bracketracer, brian's1996, Bubbawagsf250, buckey, BuckinBronco, Bulldog, Carson's ford, CAT, chadder1313, championship8, Chris's Dually, cjames, cody342b, COFG-28, coolvette, crewcab7.3, Cundiff, danberg1, danielzink, dark20011, Deererainman, deezeljunky, diesel dane, diesel_brad, Dirtyboy82, donthelegend, Drew2010, dwelder454, Dwilson, E99Superduty, Elgin MGP, ezygo, f250towrig, farmall16, FarmBoyStroker, fixithud, floridastroke, foxman, fummins, Futchgator, Gaius, GASMAN6674, Gettobooty, ghohouston, Gmalino, golfer, Got4wd, hami3533, hidolr, Hijo202, hilber, hoss869, Hprpartytruck, hunter scar, Idaho Shooter, Jcam88, Jeep1947, Jeffro92, jim dandy, jimmiejet, JJBlack, Jnalaplace, joemx611, John Martens, johndeereman, Jonah52, Jonni Nitro, josh77, jp988, jrcoogs, jtgf250, just shawn, Justincredible, K5383, Kaltima420, kawamatt2, kbragg430, KCDAXFACTOR, KCMEADOWS, keblmo, kilapapipa, kingstransport, kramarj, Krause, Ks94.5powerstroke, LBF, LBZ, leojr, lil o rinny, loudmouth, louisvanwilker, madpogue, mandkole, markfuga, MeanGreen, Mike97f350, mikesuperduty, mojoman, motlemans, Mr.Wonderful, msscatter, Mudbrother, my97stroker, navistar45, Nodge, NutFarmer97, Oakes, ohiopowerstoke, OilBurner62, old man dave, old Smokey, OldschoolPSD, oldwood, ontwowheels, Otter70, ozzyedd, pappa b's powerstroke, pff250hd, PJB, podunk, poorboy's stroker, Power97Stroke, powersmoker73, powerstroke33096, powerstroking7.3-444, psdmike, PsRumors, ranthom, red450IH, RichRich, robertnol, Robjesup88, RollingZrock, rolsmojave3, rpm-inc, salprofish, sargepep56, sdm, Shovel, shvlhead78, silent64, slutz4, smith7.3, smokey73, spectreblazer, speeddemon31176, t.land, teevo20, Teninoguy, Tinman23, TNR, toads250, Truck4, tuckerpetrak, TXStroker97, tyler886, ved0303, wadeclinton, wannabstrokin, webb06, WidowMaker, wildstang, woodking, wrenchturner250, yz85rider2002, zabeard, zilla68
You may not post new threads
You may not post replies
Forum Jump
