injector solenoid ? - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > F-250 & F-350 1986-1997 & Other Ford Trucks > 1994-1997 Power Stroke Technical Info
Thread Tools Display Modes
  #1
Old 10-08-2012, 03:32 AM
rockets10510
Offline
Member's Gallery
injector solenoid ?
ok so on a buzz test on my truck some of the injectors can harely be heard. my question is can they be changed out with good sounding ones and can there be any performance gains?
thanks anthony
Old 10-08-2012, 07:11 AM
speeddemon31176's Avatar
speeddemon31176
Offline
Demon Dually
Member's Gallery
Re: injector solenoid ?
A solenoid that is not functioning correctly is going to cause a loss in the performance of the engine. My advice would be to verify that the UVCH harnesses are in good condition first before you go replacing solenoids. Also check and make sure that the connections on both sides of the valve cover gaskets are unburnt and making good contact. It is very common to have burnt pins/connectors which will cause all sorts of problems.
__________________
  #3
Old 10-08-2012, 04:31 PM
rockets10510
Offline
Member's Gallery
they are not burnt i just had to pull the injectors because of blown orings. i know all the connections are in good working order.
  #4
Old 10-09-2012, 01:12 AM
Patrick Feeley's Avatar
Patrick Feeley
Offline
Member's Gallery
If you measure the resistance of the injector solenoid, it should be about 2-3 ohms. Cheers!
__________________
SOLD: 94 F350 CC DRW PSD, 5 Speed, 4.10 LS, SBC Con-O, Baldwin Filter, Tymar HPX Hose, 3” DP, Bilsteins, $12 AIC, Coolant Filter, Explorer O/H Console, Trans Temp, Boost, and Pyro, Pedestal Mod, Gutted EBPV
  #5
Old 10-09-2012, 04:32 AM
rockets10510
Offline
Member's Gallery
can that be measured from the outside of the valve cover?
  #6
Old 10-09-2012, 05:27 AM
speeddemon31176
Offline
Demon Dually
Member's Gallery
It is best to use an old injector pigtail to do the testing right at the injector as any extra wire is going to increase the resistance in the line.
  #7
Old 10-09-2012, 01:35 PM
Ranger50's Avatar
Ranger50
Online
1 Slo PoMoFo
Member's Gallery
For what a meter reads and how accurate it has to be in this case, horse hockey. You would have to either have even smaller gauge wire or lengthen the wire about 35 feet to see a difference.
Plus if the solenoid fails, it will have LESS resistance. I had one that was 0.5 ohm, the rest were 2.7-3.1 ohm. When I replaced the solenoid, it came back to 2.8 ohm.
__________________
"Never trust an intelligent man with no money to play fair."
97 F250. 213k. Just about as stock as stock can be. Cali mod. Yard ornament.
  #8
Old 10-09-2012, 03:41 PM
diesel_brad's Avatar
diesel_brad
Offline
STILL LEARNING
Member's Gallery
I was always told that the noise makes no difference. You could have 8 new solenoids make 8 different noises
__________________
I am probably the most hated person on here, and I don't care
97 CCSB 4WD DRW 7.3 5spd DP Tuner, 6637, Flo-Pro SS Exhaust, 99 I/C, T500, Autometer gauges, Valair Organic clutch, PFM 2.25" RSK, SD springs Front/rear 315/75/16s,
Bunch of other trucks
  #9
Old 10-09-2012, 10:20 PM
loudmouth
Offline
Member's Gallery
I was told the same thing by two reputable injector builders on this board back in 09 when I was fighting my issues.
  #10
Old 10-10-2012, 02:09 AM
speeddemon31176
Offline
Demon Dually
Member's Gallery
Your right. I forgot that with all my years of electrical schooling that I don't know anything. Good luck fixing it.
(View-All Members who have read this thread : 62
2000 powerstroke7.3, 6.9PoweredScout, 84mudder, 94Matt, 97blackbetty, accudie, babydoll, biggreen96, bigshawn, Bugman, cclb865, crewcab7.3, danberg1, davey99ps, Deererainman, diesel_brad, dlmater, dzlstroker, Eford00, eleventhtruck, ezygo, Fordguy26, Gallo, ghohouston, gnxtc2, greenbeast, hendricksbus, Hijo202, Jcam88, JI97PSD, JMCX, jrracerdad, kip4234, loudmouth, mastrkee, mojoman, msscatter, Nodge, ntruderrider, OBSWIZ, old man dave, Patrick Feeley, poorboy's stroker, pooter, Power97Stroke, quartershot, Ranger50, rockets10510, rpm-inc, rusty1161, silent64, speeddemon31176, strokepower, toolmangary, USMCNICK, vick97psd, voodoomaker, WidowMaker, zilla68, zkurtz, zx800x
You may not post new threads
You may not post replies
Forum Jump
