Will Van Trans Work. - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > F-250 & F-350 1986-1997 & Other Ford Trucks > 1994-1997 Power Stroke Technical Info
Thread Tools Display Modes
  #1
Old 10-07-2012, 11:58 AM
msscatter
Offline
Member's Gallery
I posted this in the trans section but haven't gotten any replies. My cousin has a '97 Super Duty. The trans is about done for. We bought a PSD van together for parts. It's a '94 and was t-boned in an accident. It has 145,xxx miles on it. We drove it home (about 50 miles or so ) and it runs and shifts great. Does anyone know if the trans will swap? We haven't gotten under it yet and done any measuring or anything ourselves. Any input would be great. Thanks.
Old 10-07-2012, 02:28 PM
Ford Pride
Offline
Ford Pride
Member's Gallery
Re: Will Van Trans Work.
It will work if it has the speed sensor in the rear diff. Some vans had them in the tail housing
__________________
Mike 97 SC F-250 6637,Adrenaline HPOP,203*, BTS tunes,stageII 180/80,IC,E-fuel,3" DP,5" from DP to top of flat top of black stacks,trans cooler,shift kit,all lights blacked out. Soon to come is s366 and a built trans
  #3
Old 10-07-2012, 02:51 PM
msscatter
Offline
Member's Gallery
Thanks. I'll have to check it out. His plan if they're the same is to have the van trans freshened up and swap them.
  #4
Old 10-08-2012, 07:01 AM
speeddemon31176's Avatar
speeddemon31176
Offline
Demon Dually
Member's Gallery
If the truck is a superduty(f-450) that would mean that the e-brake is on the tailshaft of the transmission. If the van transmission is the same then you are good to go. The superduty transmission is really nothing more than the 4x4 transmission with the e-brake assembly in place of the adapter for a transfer case. If the van is earlier than a 99 then it will be the e40d which would be the correct model type with the vss in the rear differential versus the 4r100 with the additional speed sensor in the transmission.
__________________
  #5
Old 10-08-2012, 10:02 AM
msscatter
Offline
Member's Gallery
Okay. That helps. Thanks.
  #6
Old 10-08-2012, 11:15 AM
rpm-inc
Offline
Member's Gallery
the 99-03 4r100 vans use a speedo gear in the tail housing of the trans. Pretty sure the eariler e40d vans do as well.
__________________
03 E-350 7.3, forged rods, exhaust ported heads, comp 910's, 38R/47, 4.10LS, stealth twin pumps, 300cc hybrids from Swamps, h-11's, racerx trans and TC, Swamps tunes, water...
  #7
Old 10-08-2012, 11:29 PM
msscatter
Offline
Member's Gallery
Okay. Can the tail section off the truck be installed on the van transmission, eliminating the speedo gear? Or is it more trouble than it's worth?
  #8
Old 10-09-2012, 05:37 AM
speeddemon31176
Offline
Demon Dually
Member's Gallery
No in short you can not just put the 2wd tail housing on a superduty(4wd) transmission. The output shaft is shorter on the 4wd/superduty transmission. If there is a speedo gear on the transmission then it will still work if your truck has the vss in the rear differential. You simply do not connect a cable to it. Just leave the speedo gear in its place and forget about it. If the van transmission doesn't have the e-brake assembly on the tail of the transmission then it will not work without several expensive modifications as well as disabling the e-brake on the truck.
  #9
Old 10-09-2012, 10:06 AM
msscatter
Offline
Member's Gallery
Thank you, that info is very helpful. As soon as we can get a break from work we're going to crawl under them and look. Both of us have cab and chassis trucks with dump beds and are running the Hell out of them right now. Work season should be over in a month or so.
  #10
Old 10-10-2012, 01:57 AM
speeddemon31176
Offline
Demon Dually
Member's Gallery
The pre-99 vans only have a vss in the rear differential. They have an E4OD transmission. The 99-up vans have the 4R100 transmission which has the extra sensor.
(View-All Members who have read this thread : 51
7.3maniac, 7.3psd1999, 96P_Stroke4x4, 99whitestroker, biggreen96, BigWhite97, bracketracer, caleb90, charlez, co04cobra, csx7006, danberg1, danielzink, Dave, deezeljunky, derekc, diesel_brad, E99Superduty, farmall16, Ford Pride, foxman, GASMAN6674, gnxtc2, Greger96obs, hendricksbus, hunter scar, Jonni Nitro, LBF, leojr, milehighstroker, mojoman, msscatter, Nodge, old Smokey, ontwowheels, Original Guster, Ranger50, rockets10510, rpm-inc, sdm, silent64, Smash Fascism, snoblade82, socoman1988, speeddemon31176, stoneykegonsa, TNR, tomspear, Wazincow
You may not post new threads
You may not post replies
Forum Jump
