Need help with p0269 code - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 6.0L Power Stroke Technical Info
Thread Tools Display Modes
  #1
Old 10-05-2012, 10:23 AM
ynkesfn2
Offline
Member's Gallery
I'm getting a p0269 code #3 cylinder on my programmer, engine is running very rough! I have a 2004 6.0
Resently I've done the following.
-cleaned turbo and oil change
-new fuel filters
-Changed EGR cooler
-rebuilt FICM
I've been doing alot of research and I see that injectors don't go bad very often. I saw on a thread someone mentioned a BUZZ test? What is that?
Just need a push I the right direction, HELP!!!
Old 10-09-2012, 07:02 PM
BDS
Offline
Member's Gallery
Re: Need help with p0269 code
Sounds like you lost number 3...You need a scanner (Auto Enginuity, Snap On, OTC....)to do a buzz test and power balance test to confirm your problem. Hook up with someone local and get that done to confirm the bad injector. Most likely a bad spool valve on the injector so you if thats the case you need a new injector in that hole.
__________________
1997 F350 4x4 XLT CC LWB PSD.In Progress
2001 Excursion Limited 4x4 PSD.97 longblock,S467.7SX,Precision 46mm Gate,238/200,Studded,Springed,SB Push Rods,DI Headers,BWD Stainless Intakes,5/8" Pickup,Twin SD Pumps,4 Corner Fuel,Billet Trans,GearHead.
1999 Cummins 2500 Ram Ext Cab 4x4.260k,Stock.K9 SAR Rig.
  #3
Old 10-10-2012, 12:24 PM
toolmangary's Avatar
toolmangary
Offline
Fixing Broken Stuff
Member's Gallery
^^^^ Yup ^^^^
__________________
1997 F350 4X4 CCLB PSD
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
Then the wife has a car
It's all just nuts and bolts and a few wires.
ex·pe·ri·ence   [ik-speer-ee-uhns] noun, verb,
What you get when you don't get what you want
  #4
Old 10-13-2012, 01:19 PM
romad99
Offline
Member's Gallery
I currently have the same problem after my oil cooler change and ended up buying the injector from PMM for less than $200.00. It should arrive today. Just to be safe I went ahead and shipped my FICM to ficmrepair.com for servicing.
Brandon
__________________
2004 F-250 Lariat 6.0 PSD, 2wd, CC/SWB
Welded EGR Cooler, PMM Coolant Filter System, Edge Insight CS and Blue Spring upgrade. Otherwise stock.
(View-All Members who have read this thread : 35
06_WhiteBull, 2003ford, 5150Mikey, BDS, Bigdog, bismic1, bond james bond, brinson, bruster, cingram84, Dave-pls, DHFF, duece, ebs05, FamExc, ford4x4guy74, FrancisTractor, ghohouston, HankyD, jparker, Mhatlen, mjustiss, mkelly, Powerstroke smoke, romad99, Roush4_6, semmens21, sfu7274456, Smokin Stroker, Strokin 35s, superdutycummins, toolmangary, treetechsixOH, weisers26, ynkesfn2
You may not post new threads
You may not post replies
Forum Jump
