Fuel pressure ? - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 6.0L Power Stroke Technical Info
Thread Tools Display Modes
  #1
Old 10-05-2012, 01:35 AM
rollingthunder's Avatar
rollingthunder
Offline
Heath
Member's Gallery
Fuel pressure ?
I've been slowly noticing that my fuel pressure will drop. At first only at WOT and lost 10-15#'s. My FICM programmer came in yesterday and I loaded the 40 tune and drove. Truck drives great and throttle response is awsome--but at WOT it falls on its face--looked up at the gauge and it was at 20#'s So I stopped at NAPA and got one of their pumps, installed it and the same thing. I have a RR from Dozers Diesel--Still uses the stock front lines and filter bowl--caps off the return port and new lines from the rear of the heads to the reg. and back to stock return line. i changed the upper filter as well. Maybe something in the tank restricting it from sucking fuel?? Without the FICM tune it still dips down past 30. Stock injectors---I have had problems with stiction on number 7, but a fresh oil change with T-6 and a bottle of archoil and it has been fine the last couple days. Any thoughts?
__________________
2005 250 crewcab king ranch
arps, egr delete,coolant and oil bypass filters
4" turbo back MBRP
A-1000 fuel w\Reg return
Warrne 175\30's
Old 10-05-2012, 02:03 AM
6.7 Powerstroke
Offline
Member's Gallery
Re: Fuel pressure ?
You have the updated FPR kit installed? I assume your filters have been replaced.
  #3
Old 10-05-2012, 10:31 AM
rollingthunder
Offline
Heath
Member's Gallery
Re: Fuel pressure ?
Regulated return and fresh filters
  #4
Old 10-05-2012, 12:12 PM
ynkesfn2
Offline
Member's Gallery
Re: Fuel pressure ?
I've heard alot about the blue spring upgrade. You may want to look into that.
  #5
Old 10-05-2012, 01:46 PM
sixOno's Avatar
sixOno
Offline
Member's Gallery
Re: Fuel pressure ?
Napa pump? Aftermarket pump or a stock pump from napa? Anyway u should be around 50-70psi. Weak pump maybe....what kind of filters u using?
__________________
190/100's,adrenaline hpop,powermax,arp's,58v idp modrate tuned ficm,extreme x,5'' exhaust,afe stage3,coolant filtration,oil bypass,egr delete,airdogII 165,6.4 banjos,sump,egt's/boost/trans/fuel gauges.
  #6
Old 10-06-2012, 12:23 PM
rollingthunder
Offline
Heath
Member's Gallery
Re: Fuel pressure ?
Motorcraft filters. It was the original pump with 150,000 miles on it, so I switched it out with the napa pump and its doing the same thing which makes me think its not the pump. I just ordered a sump from XDP. my plan was to run the stock pump with an airdog and sump. I'll put that in on monday when it gets here. If its not that than I guess i'll look at the regulator up top.
  #7
Old 10-22-2012, 11:06 PM
sixOno's Avatar
sixOno
Offline
Member's Gallery
Re: Fuel pressure ?
you ever get the truck figured out?
  #8
Old 10-22-2012, 11:36 PM
Mhatlen's Avatar
Mhatlen
Offline
Fuel it up again Dummy
Member's Gallery
Send a message via MSN to Mhatlen
Re: Fuel pressure ?
Probably was a squashed regulator spring with 150,000 miles worth of cycles to it?
__________________
2006 F250 Lariat SC 4X4, ScangaugeII,CAT EC-1,Sinister coolant filter,blue spring, Atlas40, Updated Turbo lines/stc/standpipes/dummy plugs, DC Power 190 alt., 4"exhaust straight piped, Amp Steps,Optima Blue Tops,7"fabtech lift w/D&R Coils,Rancho RSX9000,Toyo MT 38/15.50/18. 168 lbs of Dyna-Mat,Also 200 lbs of foam rubber under cab and firewall.
  #9
Old 10-26-2012, 08:56 PM
rollingthunder
Offline
Heath
Member's Gallery
Re: Fuel pressure ?
No. I oredered some 175\75 injectors from warren so I decided to make sure I didn't have any other problems
2012-10-25 13.35.29 by Heath_Runkles, on Flickr
Napa bases and filters through a A-1000 sucking from a XDP sump and -8an 1\2" line all the way up to the motor.
  #10
Old 10-26-2012, 09:22 PM
sixOno's Avatar
sixOno
Offline
Member's Gallery
Re: Fuel pressure ?
do you have the guts out of the original fuel bowl regulator?
(View-All Members who have read this thread : 74
04 f350, 04harley250, 06_WhiteBull, 1hydroman, 2 Stroker, 521TURBO, 6.7 Powerstroke, 93-97 stroker, AJ 007, amdriven2liv, asatriano, Az07Ford6.0, babydoll, Bigdog, bismic1, BlueOvalDiesel, bond james bond, boosted93cobra, bootcamp, bulldogsf350, Bustedflush, charlez, cody_32, craig031600, dauntejoel, daywalker, firedude26, fordpowerf450, galiv, GO DIESEL, gonehunting, headviking, hustler315, jammin60, jbrixen, Jgman141, Joshbaker, jp115, jpowerstroke, justind, kx450f, Mhatlen, miller45103, mkelly, muddynoll, NH OIL BURNER, pastorsid, psdmike, rollingthunder, Ron-M, Roush4_6, runwaypark, shredder55, Six Liter, sixOno, Skpph, Smoker05, Smokin Stroker, SmokinBlueOval, sonnyy13n, surfdunn, tatertot, The Butcher, Tjackson, toolmangary, treetechsixOH, truckguy876, Weatherlite, weisers26, Wheelhop, woodking, ynkesfn2, Zmann
You may not post new threads
You may not post replies
Forum Jump
