| Register | Members List | Timeslips | Calendar | Sponsors | Becoming a Sponsor | Mark Forums Read | Auto Escrow | Auto Loans | Insurance |
Thread Tools | Display Modes |
#1
Max Hp with Stock turbo an stock fuel
What is the max horsepower I could get out of a 7.3 with a stock turbo an stock fuel system?
__________________
Ts 6 position Cold Air Intake 3 inch down pipe 4 inch straight pipe more to come I hope |
| Sponsored Links | |
Advertisement |
#2
Re: Max Hp with Stock turbo an stock fuel
__________________
'97 PSD CC SRW 4x4 TS 6 position w/ Swamps tuning, DIY intake, 4" offroad exhaust, Swamps IDM, 1.0 turbo with EBPV delete, Autometer gauges |
#3
My goal is 375rwhp. Can it be done. I plan on buying a reman turbo or rebuilding mine. Yes, I do plan on injectors. What size would you recommend for that kind of number?
#4
Injectors
Turbo Fuel system HPOP OF course gauges, exhaust, Intake
__________________
I am probably the most hated person on here, and I don't care 97 CCSB 4WD DRW 7.3 5spd DP Tuner, 6637, Flo-Pro SS Exhaust, 99 I/C, T500, Autometer gauges, Valair Organic clutch, PFM 2.25" RSK, SD springs Front/rear 315/75/16s,
Bunch of other trucks |
#5
I'm wanting to do this on stock turbo an fuel system. I email jake@irate about his e-fuel kit an some turbo I found on there.
#6
jakes e-fuel(not stock) and his turbo(again, not stock) |
#7
That is a last resort though. I wanna attempt all of this on stock components besides injectors an exhaust an such.
#8
Do it and let us know how you make out
#9
I made 380HP to the wheels with Swamp's Baby Hybrids (hybrids with stock nozzles) with a stock turbo and fuel pump.
Billy T. gnxtc2@aol.com
__________________
'97 Black F250HD SC Punisher trans, PI Converter Dana 60 RSK w/ V & F SD springs Swamp's Baby Hybrids, D66 CJC Traction blocks Lived Tuned by Jonathan 227K Other vehicles -1987 Buick Grand National (Staged) -2004 Mercury Marauder |
#10
I'd suggest you add an IC to your list of mods...it will drop the restriction, (the stock manifold is VERY restrictive), and help keep the EGT's in check, as well as making more USEABLE power. It will also help the turbo live...
rebuild your turbo good intake setup exhaust mods stage I injectors Intercooler TS chip W/custom tunes (I use TW tunes) this should give you 375 on the ground and it should live. you can help yourself quite a bit if you do decide to go E-Fuel tho, because the stock fuel system is a nightmare of complexity and it's all piled right on top of the engine where you may need to work on other things....lot better with E-Fuel, getting rid of the CRAPOLA on top of the engine...I did it as much for that as anything else.....try changing the stock fuel pump sometime yourself, you'll see exactly what I mean, not something you want to try alongside the road somewheres.......
__________________
'97 Centurion. F350 4x4 CCLB Full Force 180cc Stage I's, D66, SRP-1.1, ARP, Banks IC, DIY E-Fuel, EBPV Del & Gut'd Ped., BD Brake., SD IDM, HPX, BstFoolr, 4" DP - 4" exh, 6.0 Fan, 180 T-Stat, DIY Don.105006 AF, CCV Mod, BTS, 3/8" cooling lines, Tru-Cool Max, PML, Bumper Mod, Gauges, Fluidampr, Mellings LPOP.....Tuned by "The WildMan"..... |
| Thread Tools | |
| Display Modes | |
