| Register | Members List | Timeslips | Calendar | Sponsors | Becoming a Sponsor | Mark Forums Read | Auto Escrow | Auto Loans | Insurance |
Thread Tools | Display Modes |
#1
Finally bought a diesel truck!!!!!!!!!
Went out and bought a 05 fx4 F-350 with the 6.0 in it.115k only on it,first diesel truck.what do i need to know about them?looking to do some after market things no lift she sits great now,looking for gauges,brands,pillar mounts,how hard is it to put hid's in it? got extra $$$ to play with as i got a smoking deal on it,saved lotta money.
Truck will be used to tow the 32ft camper and my 25ft car trailer. |
| Sponsored Links | |
Advertisement |
#2
Re: Finally bought a diesel truck!!!!!!!!!
You have quite a bit of reading to do on the 6.0, there are a few things that need to be cleared up before you get the mod bug, such as:
ECT/EOT temps (delta) EGR cooler possible headgaskets injector sticktion FICM voltage once those are all taken into consideration then you can persue mods. Most of the time a "smoking deal" means one or more of the above needs to be done.
__________________
03 CCSB King Ranch 4X4 6.0, IDP Xstreet, Muffler delete. 13.90@94.627 00 CCSB, ZF6, 2WD. RIP 1-22-12 06 Mitsubishi Evolution IX SSL, LR 2.0, TS EFR9180, E85, 4 slicks and a chute...maybe some other stuff ![]() 69 Camaro, awaiting turbo LSX and chassis work |
#3
paper work with truck shows head gaskets done already,had a very well known diesel shop go thru it already everything checks out.
#4
Gaskets are great...you need head studs though. If you have those done already that is a good start.
__________________
2002 CCLB 4X4 6" skyjacker lift * Ford AIC * 4" turbo back Diamond Eye exhaust * 6637 mod w/ Donaldson filter * Gauges* No Foil * Edge Insight CTS 1988 Camaro Iroc Z 2000 Polaris Scrambler 4x2 400- Bored out and tuned by DAB Racing ~Andy~
#5
If it is still in there get the egr out of it ASAP!!! it will save you headaches in the long run. Check to see what type of head gaskets went into it, If the black onyx ones went in you are on borrowed time my friend. Some things I have had to look into on mine and repair for that matter was, a injector that took a crap If it is bucking or missing in overdrive or smoking like a tire is on fire in the bed you have lost one or more. Put some revx through it and keep your batteries in top condition. It will save you issues with the FICM later on and in turn save injectors as well. ARP headstuds, and the blue spring mod. Key note is it is a 6.0 and it is a maintenance whore so stay on top of it and she should treat you juast fine. Oh yeah almost forgot SMOKE is a bad word around here and a 6.0 shouldnt smoke unless something is wrong anyway... Enjoy the truck I love mine.
#6
__________________
2004 F-350 CCSB Lariat 6.0L, Auto, FX4, 285/75R16 Toyo M-55s on Mickey Thompsons, K&N intake, EGR delete by Sinister, Coolant Filter by Sinister, Cat ELC, Blue Spring Mod, 6.4 Banjo Bolts, Scangauge II, billet grille insert, debadged |
| Thread Tools | |
| Display Modes | |
