race settings on HS Mini - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 6.4L Power Stroke - Aftermarket & Performance
Thread Tools Display Modes
  #1
Old 09-12-2012, 10:35 AM
DenisTheMenace
Offline
Member's Gallery
what are the best settings for "racing" i tried the hd300 on hot s1m lbf5 and runs good anything that i can change for it to run better?
Old 09-12-2012, 12:18 PM
powerstroke6.4's Avatar
powerstroke6.4
Offline
Member's Gallery
Re: race settings on HS Mini
You could try the mild tuning on the hot setting (250 hp ) with lbf 5. I think I saw somewhere that a guy had better track times on the 250 hot as compared to the 300 hot. Also make sure all the defuels are turned off.
__________________
2008 F350 JOB 1
H&S MINI MAXX
HD300 W/S1M
SINISTER EGR/COOLER DELETE
5000LB AIR LIFT AIR BAGS
6000K BEAMERS HID HEAD & FOGLIGHTS
KMC XD HOSS WHEELS W/35X12.5R20 NITTO TRAIL GRAPPLERS
2.5" LEVELING KIT
DIESELSITE COOLANT FILTER
ROTELLA EC-1 RATED COOLANT
5" DP BACK FLO-PRO EXHAUST
FLO-PRO CAC PIPE & INTAKE ELBOW
CCV MOD
  #3
Old 09-12-2012, 02:57 PM
DenisTheMenace
Offline
Member's Gallery
Might give that a try, my boost defuel was 38psi, and the truck would defuel, is it "safe" if i turn the boost defuel off, whats the "maximum safe" psi the turbos can go and truck can handle?
  #4
Old 09-12-2012, 03:36 PM
powerstroke6.4
Offline
Member's Gallery
I'm not sure what a safe number would be but for the tranny relearn they say to shut off all defuels before doing the runs in the hot setting
  #5
Old 09-12-2012, 04:19 PM
DenisTheMenace
Offline
Member's Gallery
Gotcha... What shift schedules would be good for racing?
  #6
Old 09-12-2012, 07:58 PM
powerstroke6.4
Offline
Member's Gallery
I myself am not a racing guy but I would try one of the s1 tunes. They lock the tc in 4 and 5. I daily drive the s1m and it seems to feel good when I floor it. However like I said i don't race so maybe someone else with a little more expertise in that area will chime in.
  #7
Old 09-13-2012, 08:09 AM
jelvine1
Offline
Member's Gallery
Where is the hd 300 tune on the mini max. I just got mine last week and all I see is the hot tune.
  #8
Old 09-13-2012, 02:19 PM
powerstroke6.4
Offline
Member's Gallery
Check your version in the settings screen. I you are at 6.4.34 or higher then you just have to go through the download prices again and select hd300 for the tune option. When you first put it on did you notice an option for easy, mild or hot damm tunes?
  #9
Old 09-14-2012, 03:33 AM
DenisTheMenace
Offline
Member's Gallery
You can only select the HD300 if you remove the DPF and select dpf removed!
  #10
Old 09-14-2012, 06:38 PM
Dirty Curry Racing's Avatar
Dirty Curry Racing
Offline
C10H20
Member's Gallery
I have the mini maxx now and been playing with the MCC tuning. Running in Hot with the HD300 on SL1 for trans tuning is the best for racing, 12lbs 4wd launch is more than plently and should get you out of the hole the fastest.
__________________
Rig: 2010 F250 CC SB 4x4
Tuner: H&S Mini Maxx HD300
Tuner setting: Hot
Trans Tuning: 1 shift Schedule low modifier
Curb Weight w/Driver: 8360lbs
Best 1/4 time: 13.55 @99mph with HD300 tune
(View-All Members who have read this thread : 104
03silvertj, 04fatboy, 08farmerstroke, 08straightpiped, 08twinturbo, 08whitethunder, 64Strokin08, 95gasser, ARCTICCAT, austin229, B585Ford, Bair, Bellyboat, Bigdiezel, BigRedBlackSmoke, bigwes, blk6.4, BMFF350, Buford93, bweezy, canam800, capt dong, CaribePickUp, chris d, cjames, compromised, Cory151, Deere8420, DenisTheMenace, Diesel-1, Dirty Curry Racing, DMAXsmoke, Dozer, drewid20, evans-10, farmwelder86, fenner408, footlong70, fordtough97, georgerosen06, greenday3437, Gunnin, heavytF, hustler315, ilmathewspro, InnovativeDiesel, jdsf350, Jeff @ Spartan, jelvine1, jipi99, jmhelems, jmkeck, joestroo, Johnny77Mutt, Jritola, Jtpappy6.4, Just1MoreTime, kdsf350, kicker417, KPBJJ, laingenb, LILGSX, Lysons, mamadiga, maverik2711, mclane187, michaelleblanc, Mugsy, Nicklange421, ofd343, oh-ate6.4PSD, onebadf150, OnlyPolaris, Pan4905, pmiller75, Popsicle, Power6.4stoke, powerstroke6.4, Preems14, QBall, Quackaddict, rdunagan, richard720, Rmartin-97, Road Hammer, Robs94z, Rubenk, SickStroke6.0, sideactiondiesel, Silver Beast, sonic blue l, straggleweed, Stroker, stroker4life, stumperhead, tblg700, tensixniner, travisH3, Uncle Buck, Wheelhop, whitefx4, wingnut60, wp3223
You may not post new threads
You may not post replies
Forum Jump
