***Cluster bad or is it the connector?-05 F350 - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 6.0L Power Stroke Technical Info
Thread Tools Display Modes
  #1
Old 09-01-2012, 05:02 AM
98stratusryder
Offline
Member's Gallery
05 F350 CCLB dually
Problem is that all of a sudden while driving, the radio, cluster, and windows all stopped working. It's been doing it a lot more often. Over the weekend a buddy and I were getting ready to unscrew the cluster, he tapped the blue plug(connects to the cluster) and everything went back on and shortly when back out.
So, now that I think I've pinpointed the problem I have a couple questions.
1. Anyone have a wiring diagram of the blue plug or where I can get one?
2. Is there a way to test the cluster?
Thanks guys, any help is appreciated b/c this is driving me nuts! Chris....,
Old 09-02-2012, 03:10 AM
bboteler's Avatar
bboteler
Offline
Member's Gallery
Re: ***Cluster bad or is it the connector?-05 F350
Not sure but if you need a replacement cluster let me know, I replaced mine with a lariat, my xlt cluster is for sale.
__________________
2005 F350 ex-cab long bed, 4x4. SRW. Big tires, bolts here and there...deleted a few things, added a few others, a couple monitoring devices.
  #3
Old 09-03-2012, 04:10 AM
98stratusryder
Offline
Member's Gallery
^^^ Thanks I'll let you know, what happens.
  #4
Old 09-03-2012, 02:08 PM
mx185sw's Avatar
mx185sw
Offline
Member's Gallery
I have been chasing a similar issue with my truck... first started with the display not lighting up for the AC controls... determined when that happens, if I turn on the headlights, you hear a click and the AC control panel lights up. This happens only about 4 or 5 times a year (been doing it for about 3 years now)... just recently, my dash blanks out, no display and no gauges work. Pulled whole dash apart and determined that one of plugs on the BACK of the fuse box was stressed just enough that the spade connectors loosened up... a simple tweak of the spade connectors in the plug so it fit tight again corrected the problem. Also I read somewhere that the shifter cable rub the wire harness at the just below the dash... you would have to remove the upper and lower steering column covers and ignition lock cylinder to get to the rub point
__________________
Sean
___________________________________________
2005 F250 Harley CC SB
Banks IQ, Banks 4" Exhaust, Cat Delete, Sinister EGR Delete, Sinister Coolant Filter , Oil Filter Bypass, 150K
Towing 8.5 X 26 Ft Enclosed Trailer
  #5
Old 09-03-2012, 02:44 PM
mx185sw's Avatar
mx185sw
Offline
Member's Gallery
here is the wiring for the 05 dash. http://s1049.photobucket.com/albums/s388/mx185sw/Truck/
  #6
Old 09-03-2012, 02:56 PM
Zmann's Avatar
Zmann
Offline
Member's Gallery
search GEM module
__________________
O6 King Ranch cc sb 7 inch lift ,37 Toyo's,Helo’s Edge Insight CTS guage only , Auber EGT , o8 center console ,2x10 subs, xm satellite ,coolant filter,RSX 9000 shocks,dual bilstein steering stabilizers ,Viper , remote toolbox popper, High Idle mod , up fitters added ,weather guard mats , ARP's, BPD EGR cooler, Fabtech traction bars, X3 Matt's tunes
  #7
Old 09-03-2012, 03:17 PM
mx185sw's Avatar
mx185sw
Offline
Member's Gallery
Here is the pic of the fuse panel.. the left most connector is the one i found to have loose connection.. 4 10mm bolts and the fuse panel pulls out far enough to wiggle test for loose connection
[IMG][/IMG]
  #8
Old 09-03-2012, 03:21 PM
98stratusryder
Offline
Member's Gallery
Thanks guys, I'll check it out today.
  #9
Old 11-27-2012, 11:14 PM
6oh stroker's Avatar
6oh stroker
Offline
Member's Gallery
Im having this EXACT same issue!!!!! what have you determened?????
__________________
06 250 CC/SB 6 speed
Aeromotive A1000
Aeromotive regulator
Caterpiller filters
SCT tunes from Rcd
Arp's
full egr delete
  #10
Old 12-19-2012, 12:49 AM
!!!PainTrain!!!'s Avatar
!!!PainTrain!!!
Offline
Hate 'R Us
Member's Gallery
Just thought I would update this thread with my own experience.
I was having the same issues as the OP. My truck is a 2005 XLT SC/SB with the 6.0. I have a little over 100K miles on the clock. Started out losing the radio while driving. This slowly progressed into losing the entire instrument cluster, losing power windows, and eventually my truck would just shut off by itself.
I took it to my Ford dealer (Keystone Ford in Chambersburg,PA) and they had it fixed in a day. They said it was actually fairly common. On the back of the instrument panel, there is a relay. If this relay goes bad, it will cause all of these issues. The only thing to do is replace the instrument cluster. He said it had nothing to do with the "GEM" or the Smart Junction Box (Fuse panel).
I've put a little over a thousand miles on my truck since getting it back and it runs like a charm, no issues what so ever.
__________________
(View-All Members who have read this thread : 46
!!!PainTrain!!!, 04 f350, 06 f250 man, 6oh stroker, 7.3maniac, 98stratusryder, bboteler, Bigstevex4, bismic1, brute_mt, bthornton, charlez, chrlskn123, dylanjessy, El king-350, florida 6.0, fordguy61mi, Ggshort, gonehunting, HeavyAssault, IIvonnyII, keblmo, kyle882, lep, Low Key, mastrkee, Mhatlen, muddynoll, Mudwizer, mx185sw, No Regrets, PokkerJoe, pwrstrk6.0, Sawman, shadow6.0, Smoker05, smokeum99ta, Smokin Stroker, sonnyy13n, thorguy57, toolmangary, tuhy, West C4, Willy MO, Zmann
You may not post new threads
You may not post replies
Forum Jump
