6.0 Stocker Question Studs/EGR Delete - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 6.0L Power Stroke Technical Info
Thread Tools Display Modes
  #1
Old 08-31-2012, 11:08 PM
Taylor0369's Avatar
Taylor0369
Offline
Member's Gallery
Stock air filter back in and its running great at at 131K. I am running 100% stock fluids and filters...3 questions
1. Do I have to do the EGR delete?? How can I tell if already done??
2. Do I have to do the studs/head gasket?? How can I tell if already done??
3. Bought the blue sprink kit...can this harm a stock truck or safe to install to stock??
Thanks for all the help
Old 09-01-2012, 04:37 PM
04 f350's Avatar
04 f350
Offline
Rockstars no center caps
Member's Gallery
Re: 6.0 Stocker Question Studs/EGR Delete
Stock intake I've heard is very good so if u don't wanna spend coin on a good intake then good job there, first question....yes you need egr delete, you can tell by looking at the left side of the intake manifold to see if the egr cooler is still in place, if it is then your a no go on the delete unless by some chance whoever had it before you just welded the ends shut and put it back in, second question is yes/no, some 6.0s blow head gaskets running stock power and no aftermarket anyhtthng on it, if ur gonna run a programmer on the truck then wouldn't w a bad idea, after u do studs and a delete the 6.0 is about as good as it comes, and the blue spring kit is a nice upgrade for our fuel pressure, not very expensive and helps alot, will not harm your truck at all and takes all of 30 mins to install, good luck with everything
__________________
5 inch TB exhaust, s&b intake and intake horn, x3 with looney fuel tune, AD2, XDP sump, egr delete, innovative ficm tuner, 03 turbo with batmo, sinister coolant filter, gogo solenoid, CCV mod, zoodad mod, 6.4 banjos, boost pyro and trans gauges, maghytec diff cover's, scangauge 2, blue spring kit, black rockstars no center caps
  #3
Old 09-01-2012, 06:40 PM
Deangarth's Avatar
Deangarth
Offline
Member's Gallery
you dont need and egr delete, you can buy an upgraded egr cooler so you truck dont throw codes. whn i get mine in a month or so, (a 6.0 that is) gonna go for upgraded egr from bullet proof diesel and the blue spring and an edge cts, then see if my oil cooler needs some attention by watching the eot and ect. but imo you dont NEED and egr delete but at least shoud buy an upgraded one.
__________________
02 F350 CC SB 7.3 Auto 4wd Lariat bone stock.....for now
http://facebook.com/deangarth
PETA-People Eating Tasty Animals
  #4
Old 09-01-2012, 10:45 PM
04 f350's Avatar
04 f350
Offline
Member's Gallery
If you have an 03 or 04 you won't throw codes but yea you can just do that if u want, get the bulletproof egr cooler or just do a delete either way
  #5
Old 09-02-2012, 06:30 PM
Mhatlen's Avatar
Mhatlen
Offline
Fuel it up again Dummy
Member's Gallery
Send a message via MSN to Mhatlen
My 2 cents worth: lol
The egr is always up for debate but; there are many guys ( some Ford Master Mechanics) that keep them because they want them and not just for smogging reasons. A bullet proof egr cooler is better than stock however the 2003 and early 2004 factory coolers rarely have a problem, you can tell if you have one on your truck if it's round. Compare with pics here on forum or on internationals powerstroke page.
If you keep up on coolant changes it will extend the life of the egr cooler. Also cleaning egr every 10K miles or so is time well spent. IMO
Head studs can be seen at the bottom of the cylinder head near the exhaust manifolds, you can see them if it has been done already.
As for the blue spring mod for the fuel pressure regulator: by all means install that, it will raise your fuel pressure to around 60 psi which is what the injectors need to keep them from wearing out prematurely.
Congrats on new truck just remember one word : maintenance/maintenance/maintenance
__________________
2006 F250 Lariat SC 4X4, ScangaugeII,CAT EC-1,Sinister coolant filter,blue spring, Atlas40, Updated Turbo lines/stc/standpipes/dummy plugs, DC Power 190 alt., 4"exhaust straight piped, Amp Steps,Optima Blue Tops,7"fabtech lift w/D&R Coils,Rancho RSX9000,Toyo MT 38/15.50/18. 168 lbs of Dyna-Mat,Also 200 lbs of foam rubber under cab and firewall.
  #6
Old 09-02-2012, 07:58 PM
Taylor0369's Avatar
Taylor0369
Offline
Member's Gallery
Great Info from all...my stock EGR cooler is running great with no issues...as well as the rest of the stock 6.0....put in blue spring and hope it was not too late at 131,000 on vehicle...should it fire up right away or small hesitation is normal 2-5 seconds when plugs warmed up/key turned??....or should I allow more time after the glow plug light goes off on the dash - heard some do 30 seconds for safe start??? I am in the south normally 70F -100F degrees outside when I start depending on time of day
  #7
Old 09-02-2012, 08:18 PM
Mhatlen's Avatar
Mhatlen
Offline
Member's Gallery
As soon as light goes out fire it up, if it's crazy cold you can wait a bit more
(View-All Members who have read this thread : 50
'94IDITurbo7.3, 04 f350, 04La4iat, 1989_2004ford, 2003ford, 50gstroked, 5150lariat, 95gasser, ARM5280, Brent1, brute_mt, caleb90, chrlskn123, cporda, ctstroker1080, Daltonf, Deangarth, F-25000, F-350 Explorer, Fast_and_Furious, ford rules, HankyD, hanleyj, jb772, jrex2506, justintimemoto, justrkosa, Low Key, mantis118, Mhatlen, MobileMiles89, MPTonyT, muddynoll, Mxfoxflyer, Nico963, pastorsid, Powerstrokinfirefighter, PScompGenius, rooster, scotty62, Stroked2004, Taylor0369, tl1000r, Turbodiesel6.0, upsidedown2, Weatherlite, Whiteout, zcampbell90
You may not post new threads
You may not post replies
Forum Jump
