Fuel Pump Plug Options - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > F-250 & F-350 1986-1997 & Other Ford Trucks > 1994-1997 OBS Power Stroke - Aftermarket & Performance
Thread Tools Display Modes
  #1
Old 08-26-2012, 03:07 PM
Shovel's Avatar
Shovel
Offline
Member's Gallery
I'm going to electronic fuel and looking to plug the hole of the MIA fuel pump. For some reason I'm not big on the freeze plug, has anyone else used a plug that is semi-removable?
I was thinking something like this:
Old 08-26-2012, 03:32 PM
mjonesjr's Avatar
mjonesjr
Offline
Member's Gallery
Re: Fuel Pump Plug Options
What is wrong with the 7/8" freeze plug? There shouldn't be any pressure in the crank case that would cause it to come out.
I haven't had any issues with the freeze plug. I put some Permatex around it when I installed it as a gasket.
__________________
1997 F-250HD Extended Cab 4x4 7.3 Powerstroke
3" Down Pipe to 4" Exhaust (Stainless) ~ Tymar Intake ~ TS 6 Position Chip ~ HPOP Cross Over Line ~ Regulated Return ~ E-Fuel System ~ Intercooled ~ CCV Mod ~ Dana 60 Swap
  #3
Old 08-26-2012, 03:37 PM
Old OutLaw's Avatar
Old OutLaw
Offline
Cantankerous Old Redneck
Member's Gallery
that plug is meant for water, oil will most likely rot it over time.....use the freeze plug, it's a better deal than you think to begin with...I wasn't hep on it either, but it's worked out fine ......
one trick tho, before you install it, put it cup-side down on a heavy piece of steel and set a ball-peen hammer on it (flat side down) and TAP it with a second hammer until you flatten it slightly, as it needs to be TIGHT in the hole..... I checked the before and after outside dimension with a digital caliper, until i had expanded it a bit....
put a SMALL amount of Permatex Aviation Sealant (yep, the brown goo) on it and drive it in.... I also cleaned the surface after I installed it with BrakeKleen and sealed the outside with 1200 degree silicone sealant..... no leaks yet.
__________________
'97 Centurion. F350 4x4 CCLB
Full Force 180cc Stage I's, D66, SRP-1.1, ARP, Banks IC, DIY E-Fuel, EBPV Del & Gut'd Ped., BD Brake., SD IDM, HPX, BstFoolr, 4" DP - 4" exh,
6.0 Fan, 180 T-Stat, DIY Don.105006 AF, CCV Mod, BTS, 3/8" cooling lines, Tru-Cool Max, PML, Bumper Mod, Gauges, Fluidampr, Mellings LPOP.....
Tuned by "The WildMan".....
  #4
Old 08-26-2012, 03:53 PM
Shovel's Avatar
Shovel
Offline
Member's Gallery
Thank you guys, noted and I'll probably be going with the freeze plug.
Just wanted to leave my options open, such as being able to go back to a mechanical pump as a backup option, selling the truck, etc. Maybe taking out a freeze plug wouldn't be as bad as I'm thinking.
  #5
Old 08-26-2012, 11:41 PM
mjonesjr's Avatar
mjonesjr
Offline
Member's Gallery
I went around the inside of the 7/8" plug and put a bunch of dimples in it to make it super tight.
  #6
Old 08-27-2012, 09:05 PM
turboaz2
Offline
Member's Gallery
You can remove the freeze plug. Just punch an hole in one edge (with a sharp punch) and run a lag screw in , then pull it out with vice grips.
__________________
1997 F250 05+ Axle Swap 3.73 Home Built 4-link Front with Ballistic Parts. 2.5" Front Coils. B-code Rear. DIY Trans w/ Precision COnverter. DIY Traction Bars. TDP 6-Pos Chip BW TP38 w/ 1.00 EXH. Rosewood DIY STG1's. DIY E-Fuel w/ Dual FM100's. SD quad pod above Rearview
  #7
Old 08-27-2012, 09:26 PM
Shovel's Avatar
Shovel
Offline
Member's Gallery
Ahhhh, I knew someone much smarter than me would know how to take out a freeze plug.
Thanks.
  #8
Old 08-27-2012, 10:16 PM
mjonesjr's Avatar
mjonesjr
Offline
Member's Gallery
What would you ever want to remove it?
  #9
Old 08-28-2012, 08:26 AM
lovesdunes's Avatar
lovesdunes
Offline
Member's Gallery
When I finally converted to an electric fuel pump I was going to use a freeze plug like everyone else. But then I got all paranoid about the thing falling into the engine or having it leak after everything was all said and done.
So I made my own plug on a lathe in the same shape as the fuel pump that used to plug the hole.
Put 2 o-rings on it...
And then mounted it under the plate that holds the fuel line splitter...
So far so good...
__________________
1997 F-350 4x Crew Cab Long Bed, John Woods Transmission, National Leaf Springs, Custom RSK, DIY E-Fuel, Rosewood Stage I Single Shot Injectors, 17* HPOP, Intercooler, 4" Exhaust, Detroit Lockers Front and Rear, Studded Rear Hubs, Layers of Dynamat Extreme inside
333,000+ Miles
  #10
Old 08-28-2012, 03:17 PM
Shovel's Avatar
Shovel
Offline
Member's Gallery
Your write up is exactly what sparked my post, but I don't have access to a lathe shop and was hoping something similar to what you built already existed. Either way, very well done!
(View-All Members who have read this thread : 83
02 CCSB, 16yrenthusiest, 1997F350powerstroke, 19stroker97, 220Swift, 4btchev, 79Ford7.3, 91F250XLIDI, 97-7.3powerstroke, 97psd16.5mpg, 97slow, bean, big nasty, Bigred95pstroke, billmoody1, bracketracer, Brain's 97 Diesel, brooksbronco17, btomassacci, Bugman, chris1978, cobrabc1993, Copperhead, csp, dalejrfan88, dannymack, david212acu, deadinthewater, Dieslnevan2009, Dirtrider, Dundunitall, EverettWV, farmall16, FordFamilyMan08, foxman, Gaius, glovemeister, gnxtc2, Got4wd, Greger96obs, halfbreed, hendricksbus, Hijo202, Jay7.3, JD3020, jesse319, JMCX, JodyF350, Josh2021, Kampy, kramarj, lovesdunes, maritimer10, MB97PSD, metrojd, mjonesjr, mkbe890, Nodge, Oakes, old man dave, Old OutLaw, pontiacross, Power97Stroke, PsRumors, Pstroke_Dev, Redman84, Robert_H, rusty1161, sdm, sharpmotors, Shovel, Smash Fascism, stoneykegonsa, stroker_1999, swaan, Tom S, trenner101, turboaz2, tyler886, wishbone, wvmike
You may not post new threads
You may not post replies
Forum Jump
