| Register | Members List | Timeslips | Calendar | Sponsors | Becoming a Sponsor | Mark Forums Read | Auto Escrow | Auto Loans | Insurance |
Thread Tools | Display Modes |
#1
synthetic oil?
if i try synthetic oil will i have to continue to use it?
| Sponsored Links | |
Advertisement |
#2
Re: synthetic oil?
Nope....switch around as much as you want.
Personally I have used synthetics since 20k on the truck. Now with 215k on the original injectors it's a no-brainer for me.
__________________
#3
Re: synthetic oil?
No need to keep using it but, once you've tried it, you'll never go back. The Rotella T6 5-40 made such a difference in my 6.0, it's like a whole different truck. And it didn't take long to tell it. Of course, with 175,000 miles anything is an improvement. After about 1000 miles with the T6, I added 8oz of Rev-X. Then I REALLY saw a difference.
#4
Re: synthetic oil?
it might take more than a single oil change for synthetic to be free of the leftover garbage from natural oil. It took me a dose of RevX and a second synthetic change before the effects of the natural oil stopped being evident (rough running, smoke, and hard starting when cold). After getting rid of it, NO WAY would I put that stuff back in my engine.
#5
Re: synthetic oil?
The fact that the oil is pressurized higher than commercial pressure washers and at the same time is being subjected to superheating because of it; is reason enough for me to use only synthetic oil !!!
__________________
2006 F250 Lariat SC 4X4, ScangaugeII,CAT EC-1,Sinister coolant filter,blue spring, Atlas40, Updated Turbo lines/stc/standpipes/dummy plugs, DC Power 190 alt., 4"exhaust straight piped, Amp Steps,Optima Blue Tops,7"fabtech lift w/D&R Coils,Rancho RSX9000,Toyo MT 38/15.50/18. 168 lbs of Dyna-Mat,Also 200 lbs of foam rubber under cab and firewall. |
#6
Re: synthetic oil?
I'm with these guys. I bought my truck last winter when it was cold out and it was running really rough. I read about stiction and suspected that on my truck. After changing to Rotella T6 5w40 and throwing a couple of bottles of Rev-X in it, it was a new truck after about a week! I will never go back!
__________________
2006 Ford F250 Lariat Crew Cab FX4. Sinister EGR Delete, Sinister coolant filter, new OEM oil cooler, new HPOP, STC fitting upgrade, new dummy plugs and stand pipes, banjo bolts, coolant flush using Rotella ELC, 5W40 T6 Rotella synthetic oil with motorcraft filter, blue spring upgrade, Scangauge II, SCT X3 tuner with mild tunes from MKM Customs. |
#7
Just switched to rotella t6 last night, can't wait for the truck to improve.
Sent from my DROID RAZR using AutoGuide.Com Free App
__________________
2005 CCLB FX4- studded, blue spring, 6.4 banjo bolts, 6 inch lift and 35" Nittos |
#8
Re: synthetic oil?
It shouldn't take long. Try 8oz of Rev-X if you have high mileage, you may be suprised by what happens. Be sure to post any changes you see with the T6.
#9
Re: synthetic oil?
thanks for the response guys. i will give it a go this weekend and report back to see how it goes.
#10
Re: synthetic oil?
The biggest part of synthetic oil is its ability to keep up lubrication under more severe loads and temps.There are additives and formulas that exeed natural refined oil. I can't tell any difference in the way my truck runs exept for the injector noise is different.
I do know for a fact it will extend the life of my engine because of reduced friction and considering what these engines cost it is worth any additional cost to use it. Have a old Penzoil sign that says: (It's cheaper to change your oil than your engine) |
| Thread Tools | |
| Display Modes | |
