7.3 won't crank - PowerStrokeNation : Ford Powerstroke Diesel Forum
Thread Tools Display Modes
  #1
Old 08-26-2012, 02:56 AM
juststrokin
Offline
Member's Gallery
7.3 won't crank
i have a 01 powerstroke that will not start no clicking noise nothing. i can start it with a screwdriver on the starter relay though. but after i got it started the first time the power windows,dome light,speedometer would not work and od light flashing. now the windows and dome light have started working but still no speedometer and od light still flashing.
Old 08-26-2012, 02:58 AM
juststrokin
Offline
Member's Gallery
Re: 7.3 won't crank
the first thing i tried was two new batteries. any suggestions would help. thanks
  #3
Old 08-26-2012, 03:29 AM
jtgf250's Avatar
jtgf250
Offline
Member's Gallery
Re: 7.3 won't crank
Think I would replace the relay if batteries have already been done. Its obviously bad if you had to jump it with a screw driver. Or check your ignition. Not sure what year your truck is but some have a little tit on the bottom of them that breaks off
__________________
2003 F-250 CCLB 7.3L
Lifted sitting on 315/75/16s, Afe stage 2 with pro guard 7, 4" turbo back, IAH delete, Triple Guages, TGC dual steering stabilizer, Bilsteins all around, 6.0 Trans cooler, polished intake y pipe, foil delete, and ccv mod, PHP Hydra chip
  #4
Old 08-26-2012, 03:13 PM
juststrokin
Offline
Member's Gallery
Re: 7.3 won't crank
would the starter relay make the speedometer and od light flash though?
  #5
Old 08-26-2012, 07:54 PM
juststrokin
Offline
Member's Gallery
Re: 7.3 won't crank
ok i replaced the stater relay and ignition switch and now the truck will crank over on its own with the keys not even in the ignition. the small starter wire on the starter relay has power all the time.
  #6
Old 08-26-2012, 08:30 PM
roughneck0913's Avatar
roughneck0913
Offline
Member's Gallery
Re: 7.3 won't crank
the relay is hooked up wrong or the ignition switch is out of time
__________________
2000 f-250 4x4 cclb 6 pos tuned by cale airdog 250, holding a stock tranny. afe cold air few other tricks under the hood always
  #7
Old 08-27-2012, 06:21 PM
ColeTrain45's Avatar
ColeTrain45
Offline
Member's Gallery
Re: 7.3 won't crank
od ligt light is something elec or a trans problem...judging by whats going on it s a wiring issue
(View-All Members who have read this thread : 40
Balthasar, Bama, bigb, Black Pearl, BryceB, cabloom7.3, codykthekilla, ColeTrain45, d-selpowereddiebauer, Diesel Mack, elhombre, Franchi, GallopingFord, Hoss1997, hydro man, iam1096, jamisgood, jdbarlow, jfarmer86, jtgf250, justinlogue5_0, juststrokin, Keitho22, kilapapipa, kip4234, ngtstk3r, okiebindernut, old Smokey, portillo, pursleybp, redneckabbott, rick23406, roughneck0913, sho669, srswain, t-ride, TerminatorEngineering, tholdenfl, Tprov, twelch3
You may not post new threads
You may not post replies
Forum Jump
