Air in fuel system? Why or how? - PowerStrokeNation : Ford Powerstroke Diesel Forum
Thread Tools Display Modes
  #1
Old 08-14-2012, 01:33 PM
cjfarm11
Offline
Member's Gallery
Workin on a 1999 with a fresh rebuild with around 800 miles on it. Ran great tell now. After some tinkering around i found air in the fuel causing the engine to run rough and die. Bleed the air out and it will run fine. Question is how is it getting air in the system? Installed all new injectors and cups at rebuild. ANy info or ideas is appredciated. Thanks
__________________
Curtsey
Early 99 Crew Cab,LB , 4" magna-flow exhaust, S&B Intake, FASS Pump, HRX, Regulated Return, Riff Raff Billet Plenums, ARP Studs, 910 springs, Chromoly Push rods, OBA, Carson Stuaffer mount and a Bell HFSB Turbo, Full Force 250/100 Hybrids, T-500, DP tuner, ISSPRO EV2 Gauges, Trans go Tugger with Billet Convertor and DP tuner LIVE tuned!
Old 08-14-2012, 02:27 PM
NorCalDiesel's Avatar
NorCalDiesel
Offline
Member's Gallery
Re: Air in fuel system? Why or how?
With just 800 miles on a fresh rebulid I would bet it had some air in the fuel system from reassembly and it just now made it through.
Otherwise you have to have an open system before the heads, but most likely before the fuel pump.
__________________
2002 X PSD, Billy Boat 4", AirRaid, 38R,HO Outlet, IH Up-pipes, Gauges: Boost, EGT, Trans Temp, Fuel Pressure and Water Temp, Oil PSI at Turbo Pedestal
DP-Tuner 6 pos No Start - 140
Super Heavy Duty 4R100 / triple disc from ATO
Transmissions in Sacramento
ICON 5" Spring Pack Lift
PSC Ram Assist Steering
  #3
Old 08-14-2012, 06:58 PM
cjfarm11
Offline
Member's Gallery
So are you thinks maybe something inside the Tank?
  #4
Old 08-14-2012, 09:45 PM
NorCalDiesel
Offline
Member's Gallery
Well, I am saying it is entirely possible that you just had some air in the system from the rebuild. Otherwise you could have a leak on the suction side of the fuel system which is from the pump back to the tank. It is common for the duck bill style intake inside the tank to allow air inside. There are some of us that have modified the in-tank pickup due to this general problem. It could also be the quick disconnect on the intake side of the pump.
If you bled the air out and it runs better and stays that way then don't worry. If it still has air being introduced then you need to start looking at the fuel system.
  #5
Old 08-15-2012, 01:13 PM
cjfarm11
Offline
Member's Gallery
I can bleed the system and it will run fine for a few minutes and then it starts running rough again. I guess and going to pull the tanks and start there and work forward.
  #6
Old 08-15-2012, 07:07 PM
sho669's Avatar
sho669
Offline
Horsepower Enthusiast
Member's Gallery
You could also be getting compression/exhaust leaking past the copper washer on the bottom of the injector geting into the fuel system.
Usually happen when they're too loose. You can do a balloon test on each bank to verify if it's the issue or not and/or just double check the torque on the injectors.
Not discrediting any of the info you've been given already just adding something else to the mix. Personally I delete the "mixing chamber" whenever I have a tank down and throw a little filter inline before the pump.
__________________
03 CCSB King Ranch 4X4 6.0, IDP Xstreet, Muffler delete. 13.90@94.627
00 CCSB, ZF6, 2WD. RIP 1-22-12
06 Mitsubishi Evolution IX SSL, LR 2.0, TS EFR9180, E85, 4 slicks and a chute...maybe some other stuff
69 Camaro, awaiting turbo LSX and chassis work
  #7
Old 08-16-2012, 01:13 PM
cjfarm11
Offline
Member's Gallery
Last night i did eliminate the in-tank mixing deal. did the hutch mod. and the problem continues.
  #8
Old 08-16-2012, 11:21 PM
SledDogg's Avatar
SledDogg
Offline
Member's Gallery
Did you eliminate the mixing chamber? If not drop the tank, and pull the bottom off the mixing chamber so as too get at the two screens. Pull them and have fun cleaning them!!! They just caused me a crap load of money out of pockets replacing wrong parts. Mileage is up now and my stage 11 single shot sticks are you quiet now. Full fuel pressure.
__________________
02' Black F250 Super-Cab, 7.3, Auto, 4x4, XLT loaded, Frnt Add-a Leaf, 4" Silverline Turbo back, Wix 6637, Billet Grill, Full Force Stage 1, single shot sticks, 6 Pos with Matt Robinson tunes.
]R.I.P02' F250 4x4 XLT Super Cab 7.3 w/4" Silverline Turbo Back Exhaust, K&N, Diablo Tuner, Amsoil through-out, and a Amsoil By-pass filter
  #9
Old 08-17-2012, 06:18 AM
LilBlack
Offline
Member's Gallery
My 7.3 had the same problem, after I replaced my trans.
Turns out I had ripped my underbody hose that runs right by the frame and it was pulling in air.
Maybe this could be you.
  #10
Old 08-17-2012, 06:38 AM
purplepstroke's Avatar
purplepstroke
Offline
International Diesel Tech
Member's Gallery
Sound like compression coming up through the injectors washers or cups to me.
__________________
E99 7.3***swamps 175/145 sticks***swamps tuning*** 4" mbrp***t500 HPOP***6637 filter***BTS valve body***racerx torque convertor***walbro fuel pump***20x10 fuel hostages with Nitto 305 terra grapplers
(View-All Members who have read this thread : 53
03Excursion, 07hs2000, 7.3maniac, 97 psd black beauty, adcausey, Bdickey, boostaddict, brick, brownfield, cabloom7.3, cjfarm11, cpdad93, CSIPSD, CTC DEEZUL, Denver, Falk, golfer, Hooter, hydro man, iceberg, jamisgood, JD F350, jhunter14, jimmyducati, Jordy53, jpaitala, juvenile9, klos, Les, LilBlack, Luke909, mantis118, monster-energy-825, mttrucker, Mudwizer, NorCalDiesel, PJB, powerstroking7.3-444, purplepstroke, Richard DDR, shmokenpstroke, sho669, SledDogg, slutz4, smokey7.3, smokin99stroke, sonnyy13n, Strokin450, tbolt, teray, tomspear, Tprov, WHT00EX
You may not post new threads
You may not post replies
Forum Jump
