When do i need gauges? - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > F-250 & F-350 1986-1997 & Other Ford Trucks > 1994-1997 General Aftermarket
Thread Tools Display Modes
  #1
Old 08-14-2012, 06:57 AM
Mudder_Trucker's Avatar
Mudder_Trucker
Offline
Member's Gallery
Ive got a 96 F350 PSD. currently theres a K&N filter (not intake, filter only) and a Hypertech flash tuner in/on the truck. Granted, I plan on running a Tymar, or similar intake and a TS Performance chip. These were there when i bought the truck, as well as the Mag-Hytec (i believe is the name) trans pan. I plan on doing the intake pretty soon. Then an exhaust (Diamond Eye 5", aftermarket downpipe, 6" tip, no cat no muffler) Then doing the chip. At what point should i add Boost, Trans temp, and EGT gauges? I should probably get them off the bat, but i was curious when it was actually needed.
Order of mods:
1: Intake
2: Exhaust
3: TS Chip
4: (while later) Injectors
My guess is gauges are a must once i have a chip. recommended after intake and exhaust?
Sorry if this has been covered before, ive searched and didnt find much. Sorry if this is a n00b question... This is the first diesel ive had that ive modified.
__________________
1996 F350 SCLB 4x4 auto
K&N filter
Hypertech programmer (both on when purchased )
Old 08-14-2012, 07:19 AM
Strokin450's Avatar
Strokin450
Offline
Real Trucks Rattle!
Member's Gallery
Send a message via Yahoo to Strokin450
Re: When do i need gauges?
With any mods should be gauges. With stocker truck also, its always good to keep a close eye on your enging to prevent damage. Better safe than sorry!
__________________
96 F250 ECLB Intercooler Mod, , 3" downpipe--> 4" straight pipe, 1.1 A/R housing, TS TW tunes, Skyjacker all 4 corners, Maximum boost/pyro/trans gauges, Ion wheels/Nitto tires,Banks trans command, TQ and Valve body upgrades, 160k
2008 CRF-450R- It's a HONDA but still wish it was diesel
2006 Honda Rincon 680 mud machine
  #3
Old 08-14-2012, 07:23 AM
BIGN's Avatar
BIGN
Offline
Member's Gallery
I would install gauges first before any kind of other mod, but definitely before you put the TS Chip on your truck. Gauges were the first thing I bought and installed on my truck. You want keep track of those EGT’s
__________________
2000 F250 4X4 Auto 7.3
6637 intake
PHP phoenix chip
Glow shift Gauges
Trans temp,Boost, EGT
Diamond Eye 5" Exhaust
  #4
Old 08-14-2012, 07:30 AM
Mudder_Trucker
Offline
Member's Gallery
Thats what i had figured. I am unsure of which gauges to get. I will be doing some towing, so i assume trans temp is important? especially since i have an automatic?
Ill look into gauges first. there are some from Summit, the one boost gauge is $200... is there something special about it? heres the link:
Auto Meter 7359 - Auto Meter NV Series Analog Gauges - Overview - SummitRacing.com
I was looking at these gauges, but with a black face... Im rather new to diesel modding, like i stated above.
Also, am i on the right track with my mods? not going the wrong direction?
  #5
Old 08-14-2012, 07:48 AM
BIGN's Avatar
BIGN
Offline
Member's Gallery
Auto Meter is a good gauge. You don’t need one that read's Vacuum either. I would talk to some of the vendors on here and they can get you pointed in the right direction. You will get a better price on all the gauges and pillar as a package deal from the vendors. Then you can get to doing some of the other mods you want to do.
  #6
Old 08-14-2012, 07:51 AM
97-7.3powerstroke's Avatar
97-7.3powerstroke
Offline
Member's Gallery
You want to get just a boost gauge and not a vacuum/boost gauge cause diesels don't create vacuum. That's why they have a vacuum pump on them.
  #7
Old 08-14-2012, 08:16 AM
ajfetterman's Avatar
ajfetterman
Offline
Member's Gallery
Check with the vendors here.....may get a better price.
Start with......
EGT
Boost
Trans temp
__________________
2002 CCLB 4X4 6" skyjacker lift * Ford AIC * 4" turbo back Diamond Eye exhaust * 6637 mod w/ Donaldson filter * Gauges* No Foil * Edge Insight CTS
1988 Camaro Iroc Z
2000 Polaris Scrambler 4x2 400- Bored out and tuned by DAB Racing
~Andy~
  #8
Old 08-14-2012, 01:42 PM
Mudder_Trucker
Offline
Member's Gallery
Ill have to check with vendors, as well as work. I get a discount on everything at Summit. Thats why i chose there. Thoroughbred Diesel has the full gauge pillar kit for just under $500 i believe..
  #9
Old 08-14-2012, 02:07 PM
ajfetterman
Offline
Member's Gallery
You are a SUM-G? Save the discount for the big ticket items unless Summit has lifted the 'amount you can buy thing in a year' thing.
Make a post in an area applicable to what you are in the market for and in the title say something along the lines of -Vendors, looking for gauge prices-
Usually vendors will PM you the info.
  #10
Old 08-14-2012, 02:25 PM
Mudder_Trucker
Offline
Member's Gallery
Its still like that, sadly. I was working on my Jeep so unfortunately i dont have much left. I can only spend $1000 a year since im part time, going to school. I may bump up to Full time though.
Not sure what you meant by SUM-G? lol
Ill Post something similar to that, if im looking for gauges, would General Aftermarket be the place for it? (Sorry, new here lol)
(View-All Members who have read this thread : 79
'94IDITurbo7.3, 04La4iat, 1997stroker!, 19stroker97, 6.9PoweredScout, 7.3L F-250, 94youngturbo, 97-7.3powerstroke, ajfetterman, Alvapowerchoke, Aminator, bear1, BigI, BIGN, bigwhite96stroker, blackf250, BlackHogDown, Bubbawagsf250, Chado, cntryboy17, Corey Hudson, CSIPSD, Cundiff, danielzink, deadinthewater, deezeljunky, Denver, diesel_brad, Dirtyboy82, dragonboi, drh4250, DRT1359, E99Superduty, EverettWV, f250towrig, Farmboy679, FarmBoyStroker, FordFever, Fordzilla11, foxman, fpOwerstRokeD, geared_low550, gould9, greenbeast, Grey6.0, gsxr1216, H-Bomb, hunter scar, hwstem, Its.Strokn.time, j440, Johnny77Mutt, King Valley, leojr, littlewoody, MB97PSD, moose7.3IH, Mooseposse, Mudder_Trucker, Nodge, Oklahoman, old man dave, ole red, Power97Stroke, powerstrokecowgirl, Powerstrokinfirefighter, rollinhot, screamnstroker, sdm, sharpmotors, Smoker05, sprtmetz10, ste2, Strokin450, tsanjose, wannabstrokin, Wazincow, zipp
You may not post new threads
You may not post replies
Forum Jump
