Won't start after rebuild. Need help - PowerStrokeNation : Ford Powerstroke Diesel Forum
Thread Tools Display Modes
  #1
Old 08-14-2012, 03:15 AM
Bdickey
Offline
Member's Gallery
Exclamation Won't start after rebuild. Need help
I just got done rebuilding my 7.3. She's back in the truck and all buttoned up. I did fill the fuel bowl and hpop reservoir. I gave it about 6 10-15 sec cranks and it gave a couple good tries but won't start. Am I not cranking enough? Long enough? Or is there air in fuel system? Any help or suggestions would be great.
Old 08-14-2012, 03:20 AM
sho669's Avatar
sho669
Offline
Horsepower Enthusiast
Member's Gallery
Re: Won't start after rebuild. Need help
Checking for air in the fuel system would be a good start, pop the cap and see if its air locked.
You have base oil pressure reading on your gauge? It'll take a while to bleed everything out.
__________________
03 CCSB King Ranch 4X4 6.0, IDP Xstreet, Muffler delete. 13.90@94.627
00 CCSB, ZF6, 2WD. RIP 1-22-12
06 Mitsubishi Evolution IX SSL, LR 2.0, TS EFR9180, E85, 4 slicks and a chute...maybe some other stuff
69 Camaro, awaiting turbo LSX and chassis work
  #3
Old 08-14-2012, 03:22 AM
kilapapipa's Avatar
kilapapipa
Offline
Old Yeller, REBORN
Member's Gallery
Keep filling the hpop. Put some chargers on the bats. It will take a while to get oil to the injectors.
__________________
REBORN 20 Over on 3/2/11- Pics in gallery- 2000 F250, Auto, 38r, Full Force 238cc/100%, TE 17* hpop, DP F5,HI,60T,80E,120R,140A, Studs and 910's with DI PR's, JW VB, Walbro 392, Bellowed, In-Tank, Pre-Pump, boost fooler, and RR. Air Dog, SS cover, 6.0 TOC,4" straight piped and guages, 6637, coolant filter, 4" Lift on 33's.
  #4
Old 08-14-2012, 03:31 AM
Bdickey
Offline
Member's Gallery
It was showing oil pressure reading on gauge in truck after a few seconds of cranking. So do I need to crank Longer or ??
  #5
Old 08-14-2012, 03:34 AM
kilapapipa's Avatar
kilapapipa
Offline
Old Yeller, REBORN
Member's Gallery
Yup. I had to refill the hpop 2 times. Keep cranking and watch the hpop oil level.
  #6
Old 08-14-2012, 03:54 PM
Bdickey
Offline
Member's Gallery
How much oil should it take to fill her up after being bone dry. I put in about 3 1/2 gallons initially then started to crank the motor over, added another gallon and it's not even on the stick??
  #7
Old 08-14-2012, 04:28 PM
kilapapipa's Avatar
kilapapipa
Offline
Old Yeller, REBORN
Member's Gallery
Did you fill the HPOP initially? I did and ended up adding another qt. after cranking a while and checking it. The hpop fills the rails and then and only then can that oil fire the injectors.
After I did mine, I decided if I did this again, I would fill the rails and the HPOP to help speed up the process.
If you did not fill the hpop, then the lpop is filling the hpop and then the rails so it may take a lot of time.
  #8
Old 08-14-2012, 04:58 PM
Bdickey
Offline
Member's Gallery
I initially did not fill the hpop. After a few tries of cranking I did. It took on very little on very little oil. I double checked and everything looks to be hooked up right. All grounds are on.
  #9
Old 08-14-2012, 05:26 PM
sho669's Avatar
sho669
Offline
Member's Gallery
Also thought I'd add that you are going to be in the 18qt range to fill a completely dry engine. 3 1/2 gallons isn't going to be enough, 4 1/2 would be a good start IMO.
  #10
Old 08-14-2012, 06:17 PM
Bdickey
Offline
Member's Gallery
I have to pick up another gallon of oil and I'll get it topped off and do some more cranking.
(View-All Members who have read this thread : 74
01REDSTROKER, 03f250powerstroke, 2002FordPwr, 7.3 Blackout, 94youngturbo, accudie, adcausey, ARCTICCAT, Bama, Bdickey, BigJake, BIGN, brinson, brownfield, Burnin Coal, Bustedknuckles, cota, cpdad93, CSIPSD, Denver, doubledoor, drunk on diesel, dustinz85, E99Superduty, edub32, FarmBoyStroker, Gcashwell, georgia diesel, ghohouston, golfer, Hooter, hunter scar, hydro man, IHPowerstroke7.3, jefhuf, JohnDeereFarmer, JoshuaLO, justinlogue5_0, juvenile9, Kampy, kbmkviii, kilapapipa, King Valley, klos, kmesaeh, kystanger, lariat7.3, Locoelectrician, lubeowner, Luke909, mclean, merle, merlinnilrem, mfrazier3030, Mike97f350, moose7.3IH, mttrucker, Mudwizer, NorCalDiesel, powerstroking7.3-444, protronics00, rideracelivemx7, roughneck0913, scheidt27, sho669, silent64, SledDogg, smokey7.3, Sndwrkr, teray, The Oiler, whitjo, zilla68, zkurtz
You may not post new threads
You may not post replies
Forum Jump
