Another week, another problem - PowerStrokeNation : Ford Powerstroke Diesel Forum
Thread Tools Display Modes
  #1
Old 08-13-2012, 08:22 AM
ajfetterman's Avatar
ajfetterman
Offline
Member's Gallery
So I took my boy on a camping trip this past weekend and had everything packed and camper hitched on Thursday night so when I got home Friday afternoon from work we could split.......We got into the truck and it took 5-6 cranks to turn over, after 4 I activated the glow plugs for about 10 secs.
Once started she ran and pulled fine. The next day we took a short trip and I again hit the GPs and it sounded a bit weak in start up but it fired after a longer crank than normal. Ditto for the next day when we left.
If I get time today I'm going to check the oil level in the HPOP. One of batteries was new last fall maybe its time to replace the other, also I am due for an oil change.....didnt have time to do before our trip
So if all this checks out what should I check next? I only have 138k on the clock, wouldnt think injectors yet.
__________________
2002 CCLB 4X4 6" skyjacker lift * Ford AIC * 4" turbo back Diamond Eye exhaust * 6637 mod w/ Donaldson filter * Gauges* No Foil * Edge Insight CTS
1988 Camaro Iroc Z
2000 Polaris Scrambler 4x2 400- Bored out and tuned by DAB Racing
~Andy~
Old 08-13-2012, 01:36 PM
whitjo's Avatar
whitjo
Offline
TennesseeHillbilly
Member's Gallery
Re: Another week, another problem
weak battery(ies)=weak starts......that's the first place to look for weak start issues..it take a lot of cranking amps to spin the motor and supply power to the injectors.....at the same time.
__________________
Early '99 F250, 4X4, SuperCab, "PowerStroke", Auto,
PMT1 PCM, DP 80 tow
ISSPRO gauges
BDS front leveling kit
4" straight piped
Sinister pre-pump mod w/filter
Dick Cepek DC1 w/ Nitto Terra Grappler 325/65R18,
Annoy A Liberal....... Work Hard and Be Happy!
Please dont call me white or Caucasian. It offends me.
  #3
Old 08-13-2012, 02:15 PM
ajfetterman
Offline
Member's Gallery
I was going to start with a battery and an oil change and go from there.
The batteries dont get much 'charge' time since I dont drive too much....usually I go 5 miles up the road a few times a week for baseball or soccer practice.
  #4
Old 08-14-2012, 03:26 AM
kilapapipa's Avatar
kilapapipa
Offline
Old Yeller, REBORN
Member's Gallery
Bats should be replaced 2 at a time. . I know what you mean about problems though.
__________________
REBORN 20 Over on 3/2/11- Pics in gallery- 2000 F250, Auto, 38r, Full Force 238cc/100%, TE 17* hpop, DP F5,HI,60T,80E,120R,140A, Studs and 910's with DI PR's, JW VB, Walbro 392, Bellowed, In-Tank, Pre-Pump, boost fooler, and RR. Air Dog, SS cover, 6.0 TOC,4" straight piped and guages, 6637, coolant filter, 4" Lift on 33's.
  #5
Old 08-14-2012, 04:22 AM
PowerStrokingMachine's Avatar
Offline
Skin that smoke wagon
Member's Gallery
My truck had been starting weaker than normal a few days ago. So I did some searching on here and some people said it was their starter/batteries/battery cables....well to be honest I didn't do much about it. Three days later I went to start my truck and it was making a horrible rattling sound under the truck....first thing came to mind was torque converter related! So I slipped under there and noticed the starter solenoid has just...hanging there lol so I pulled the the whole thing off, replaced it and now my truck starts up better than ever!
__________________
2003 7.3 F-350 FX4 CC FAT BOTTOM
6637,AIH Delete,5in Flo Pro,
Gauges (boost,Pyro,trans),
Bellowed up pipes,6.0 trans cooler,
billet converter,mild trans,
4' lift kit on 35s,Recon lights.
77 Vette-mild motor, built trans,12.4 quarter.
72 Grand Torino Sport-(in storage)future project
99 Dodge 2500, 5.9 28in lift,46' claws- sold
  #6
Old 08-14-2012, 02:41 PM
NorCalDiesel's Avatar
NorCalDiesel
Offline
Member's Gallery
Exact same thing.. Crappy starting for a few days and then I had the presence of mind to pull into the parts store and shut it off. tried to start it again and nothing. Looked underneath and the starter was in several dangling pieces. 20 minutes and $200.00 later back on the road.
..adds a whole new meaning to "Made in China"
__________________
2002 X PSD, Billy Boat 4", AirRaid, 38R,HO Outlet, IH Up-pipes, Gauges: Boost, EGT, Trans Temp, Fuel Pressure and Water Temp, Oil PSI at Turbo Pedestal
DP-Tuner 6 pos No Start - 140
Super Heavy Duty 4R100 / triple disc from ATO
Transmissions in Sacramento
ICON 5" Spring Pack Lift
PSC Ram Assist Steering
  #7
Old 08-14-2012, 02:51 PM
ajfetterman
Offline
Member's Gallery
Cranked fine yesterday.....dang thing. It is going to sit for a few until I get this dang bolt drilled out of the manifold flange so I can finally finish my uppies.
My IROC will be getting some road time I suppose....
(View-All Members who have read this thread : 65
07hs2000, 2002FordPwr, 4BigGreen, 7.3, 7.3 Blackout, ajfetterman, andrewv_24, ARCTICCAT, bigb, BIGN, bill4d, brick, brownfield, bruce51d, Burnin Coal, ByrdDog, C.D., cabloom7.3, Cement, COFG-28, CSIPSD, Cundiff, Denver, dieselmandustin, Don 6.4, E99Superduty, FastFiveO, ford4life76, Fordguy26, ghohouston, Hooter, houtxfdcapt, hwrdbd, jonboy84, jpaitala, Jr2133, juvenile9, kaso76, kilapapipa, kystanger, lep, loner1, Luke909, Mike97f350, nedkin01, neher72, Nodge, NorCalDiesel, Ohnny101, Powerstrokinfirefighter, powerstroking7.3-444, PowerStrokingMachine, pursleybp, SAYIWONT, sho669, silent64, smokey7.3, Strokin450, tbolt, Tprov, truckcap22, whitjo, yellow dog, yz85rider2002
You may not post new threads
You may not post replies
Forum Jump
