What would cause every cylinder to be low on compression? - PowerStrokeNation : Ford Powerstroke Diesel Forum
Thread Tools Display Modes
  #1
Old 08-11-2012, 04:20 PM
RLSCOAL
Offline
Member's Gallery
So I have this issue with my truck I was driving it and it started smoking white thought my injectors went because it was skipping. I had to drive it home because of where I was no cell service and in the woods. got it home and smoke had increased all white and the engine was knocking. brought it to the dealer and they did some testing to it and came back and said it was low on compression on all cylinders I think 1 and 8 had the highest compression of the low 200's the rest where in the 100's low and high. they said it got dusted but i pulled the old turbo off 5k miles before it died and there was no indications of dusting. truck has 272xxx miles with mods below i was thinking it was a head gasket because they said there was coolant in the cylinders and the coolant level dropped some after this happened what do you all think?
__________________
2000 F250 SCSB 6-speed, stage 3 clutch, lifted 4'' with 37's, 5er, 4'' turbo back, 6637 intake, STAGE II Rosewood singles, PHP Phoenix chip, 38R, 910"s shimed, Traction Bars.
05/12_288.64 RWHP. 575.04 FT-LBS-TQ
JUST DYNOED! 411 HP 794 FT-LBS-TQ
Old 08-16-2012, 12:36 AM
RLSCOAL
Offline
Member's Gallery
Re: What would cause every cylinder to be low on compression?
bump
Any one have a guess??
  #3
Old 08-16-2012, 12:37 AM
RLSCOAL
Offline
Member's Gallery
or does anyone know where to start to diagnose this issue?
  #4
Old 08-16-2012, 12:51 AM
CSIPSD
Offline
Banned
Member's Gallery
You put down less then 300hp with stage 2's?
  #5
Old 08-16-2012, 05:16 AM
NorCalDiesel's Avatar
NorCalDiesel
Offline
Member's Gallery
Sounds like a head gasket.. I mean they pointed out coolant in the cylinders and all cylinders are low and you have white smoke. While white smoke is usually assoc with injectors and raw fuel, it's also a symptom of a blown head gasket. If you have Diesel in your coolant overflow reservoir then it is an injector cup or two. But unlikely a cup due to your other symptoms.
I love the "ya dusted yer engine" WTF, the fact you have coolant in the cylinder is an automatic fix it before a compression test. Was that a Ford dealer?
__________________
2002 X PSD, Billy Boat 4", AirRaid, 38R,HO Outlet, IH Up-pipes, Gauges: Boost, EGT, Trans Temp, Fuel Pressure and Water Temp, Oil PSI at Turbo Pedestal
DP-Tuner 6 pos No Start - 140
Super Heavy Duty 4R100 / triple disc from ATO
Transmissions in Sacramento
ICON 5" Spring Pack Lift
PSC Ram Assist Steering
  #6
Old 08-16-2012, 09:56 PM
RLSCOAL
Offline
Member's Gallery
ya it was a ford dealer but i dont think they work on diesels much they had to special buy a compression tester from snap-on
  #7
Old 08-16-2012, 10:30 PM
RLSCOAL
Offline
Member's Gallery
yes unfortunately idk why might be something to with this issue i have
  #8
Old 08-16-2012, 11:11 PM
RLSCOAL
Offline
Member's Gallery
anyone ever done a head gasket? is it easier to pull the heads off inn the truck or pull the engine?
(View-All Members who have read this thread : 81
00 ford f250, 02bestroked, 07hs2000, 2kstroker, 444-4D, 74zorro, airfish2011, ajfetterman, AK1, babydoll, Barnbuilder, barnhartal, Bdickey, bigb, boostaddict, bruce51d, Buford-61, cabloom7.3, ccf350stroker, cementhead, chris1978, CLASSICIDI, ColeTrain45, cpdad93, CSIPSD, CTC DEEZUL, Denver, Desertdweller, dieselboy01, FarmBoyStroker, firedriver19, FlatbedRocketship, ford4life76, Fordguy26, ghohouston, golfer, gtx, hwrdbd, hydro man, IHPowerstroke7.3, jamisgood, jonboy84, Jordy53, justinlogue5_0, juvenile9, kbmkviii, kilapapipa, lariat7.3, LilBlack, Locoelectrician, Luke909, middlemanjw, mikeflores350, mtmod50, Mudder_Trucker, Nodge, NorCalDiesel, NRHX2009, oldschool, Petro, powerstroking7.3-444, PowerStrokingMachine, RLSCOAL, roughneck0913, scheidt27, sho669, Six Liter, smith7.3, stevedrums, Stokke, T-Bubba, tbolt, TomzToyz2, Tprov, Treyspooner65, Ty's Diesel, wannabstrokin, WhiskeyTangoFoxtrot, Witenite, zx800x
You may not post new threads
You may not post replies
Forum Jump
