Checking TPS? - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > F-250 & F-350 1986-1997 & Other Ford Trucks > 1994-1997 Power Stroke Technical Info
Thread Tools Display Modes
  #1
Old 08-09-2012, 01:11 AM
6.9PoweredScout's Avatar
6.9PoweredScout
Offline
Bleeds IH Red
Member's Gallery
Checking TPS?
ok i know the pedal is throttle by wire what do i check to make sure its good? is there a sensor on "the other end" to check too? sometimes my transmission downshifts flawlessly, other times it "falls" into the next gear and the truck runs out of power till it builds boos again.....
__________________
-Jon
1980 IH Scout Terra
6.9L
1971 IH Travelette Crew Cab
DTA466 swap.
1991 F350 CCLB DWR 7.3L Banks Sidewinder/ E4OD 2WD
Old 08-09-2012, 02:27 AM
old man dave
Offline
Terminator Nation
Member's Gallery
Re: Checking TPS?
The TPS is a simple potentiometer. 0-5v output and 5 volts to it. You should be able to read a smooth change in voltage between maybe 0.5 volts to 4 volts or so while operating the pedal. The IVS switch is just that, open or closed.
__________________
Just another 408hp '97 California Truck with a stock muffler
community.webshots.com/user/davepowerstroke
  #3
Old 08-09-2012, 09:54 AM
6.9PoweredScout
Offline
Bleeds IH Red
Member's Gallery
Re: Checking TPS?
so test it hooked up?
  #4
Old 08-09-2012, 04:36 PM
STROKER #1
Offline
Member's Gallery
Re: Checking TPS?
You need to put a voltmeter across the GY/W and the GY/R wires on the connector to the TPS. With the key on, watch the voltage across the range of the throttle to see if there is any flat spots. You should see no less than 3.7 volts at idle position and no more than 4.5 volts at full throttle. The third wire, (BRN/W), is the ref. voltage and should be 5 volts all the time.
IVS is on or off as mentioned.
__________________
F-250 PSD 1996 ext.cab 2WD, Short bed, E4OD.
  #5
Old 08-09-2012, 05:54 PM
6.9PoweredScout
Offline
Bleeds IH Red
Member's Gallery
Re: Checking TPS?
Easy enough. Thanks. And whats IVS stand for?
  #6
Old 08-09-2012, 05:58 PM
STROKER #1
Offline
Member's Gallery
Wink Re: Checking TPS?
Just put your mouse over the Green acronim and you will get the meaning.
  #7
Old 08-09-2012, 07:37 PM
6.9PoweredScout
Offline
Bleeds IH Red
Member's Gallery
Re: Checking TPS?
Thats hard to do on a phone... Haha
  #8
Old 08-10-2012, 02:41 AM
old man dave
Offline
Terminator Nation
Member's Gallery
Re: Checking TPS?
Idle Validation Switch. It tells the PCM to start sensing the Throttle Position Sensor. If this isn't working, the engine RPM will not change from idle when depressing the pedal.
  #9
Old 08-10-2012, 02:49 AM
old man dave
Offline
Terminator Nation
Member's Gallery
Re: Checking TPS?
I've seen voltages as low as less than 1 volt at idle using AE and full throttle at voltages ranging from 3.5 volts to 4.5volts. Cold checking resistances at minimum of 400-500 ohms on the sensing legs to about 5000 ohms checking across the reference voltage legs. Voltages above 4.6 volts is rumored to make the PCM revert back to idle state.
(View-All Members who have read this thread : 38
19stroker97, 6.9PoweredScout, 97psd16.5mpg, bmorervns20, Bugman, Denver, Dirtyboy82, drh4250, dsinderson, dyoung14, dzlj 50, dzlstroker, E99Superduty, f250towrig, FarmBoyStroker, GASMAN6674, gsxr1216, harley1iron, HeadHunter, hunter scar, JD3020, kaker123, madpogue, mojoman, MrNiceGuy, mxredneck, Oakes, old man dave, ole red, Patrick Feeley, PSDEng, STROKER #1, Stroker612, Strokin450, vick97psd, wanagofaster73, Weldon
You may not post new threads
You may not post replies
Forum Jump
