I thought I have seen this Truck Before .
I went on Reading More of this Story . an Then an Light came on . .
This is Tom S Truck from Prower stroke Nation .
This is an Need to Read Story .
I have an 97 F 250 2WD .
I would like to have my truck set up like your in two years .
Tom
You have an Great job seting up your Truck .
Can you give me more Info about your Hood . Where did you Buy it .
It is the August issue, which is on newstands right now. (Barnes and Noble is the best place to find it) If you subscribe now, you would not get this issue as it mailed to subscribers about a month ago.
You can do that as well. There is also a pretty lengthy OBS build-up story in the previous issue, the April/June issue (has a white dodge dually on the cover.)
You can do that as well. There is also a pretty lengthy OBS build-up story in the previous issue, the April/June issue (has a white dodge dually) on the cover.
Congratulations Tom. anyone who has seen his truck in person knows that he has maintained it in showroom spankin new perfect condition. I have not seen a cleaner truck that was not new, and all his mods are very clean and as factory looking as possible. He also has a garage with a floor clean enough to eat off.
My dyno number are with the OEM charger and a 1.0 housing. Our last dyno day was like 5 degrees and it was impossible to get the truck properly warmed up to dyno.
