trouble towing above 55 - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > F-250 & F-350 1986-1997 & Other Ford Trucks > 1994-1997 General Aftermarket
Thread Tools Display Modes
  #1
Old 08-01-2012, 02:04 AM
fordboy
Online
Member's Gallery
I have a 97 f350 7.3 five speed I bought a few months back. It is 100% stock all original as can be with 290000 miles. I have towed my boat with it on several occasions which weighs in at about 5000 pounds with no issues, can go 70 all day if wanted. I hooked my 5ver(10000 pounds) up to it today for the first time and towed it about 3 miles to just make sure everything was good. I seemed to be having trouble getting above 55. I will try again in the next day or so cause I just towed it around the block which is 1 mile sections each time, so not really a lot of room to roll it up past 55 before having to slow again. If I do find its having trouble with getting it to continue to accelerate after 55 what do you guys think I need to be looking at? I have put 4000 miles on it so far and dont seem to notice any issues with the truck and this is probaly my 4th or 5th 7.3, but all the others were superdutys.
Old 08-01-2012, 02:15 AM
diesel_brad's Avatar
diesel_brad
Offline
STILL LEARNING
Member's Gallery
Re: trouble towing above 55
Sounds like a tired stock OBS. Nothing really wrong
__________________
I am probably the most hated person on here, and I don't care
97 CCSB 4WD DRW 7.3 5spd DP Tuner, 6637, Flo-Pro SS Exhaust, 99 I/C, T500, Autometer gauges, Valair Organic clutch, PFM 2.25" RSK, SD springs Front/rear 315/75/16s,
Bunch of other trucks
  #3
Old 08-01-2012, 02:21 AM
pa-powerstroke's Avatar
pa-powerstroke
Offline
Thirsty For More
Member's Gallery
With that many miles probably just a lot of blowby
  #4
Old 08-01-2012, 12:39 PM
fordboy
Online
Member's Gallery
So what are you guys telling me I need to rebuild? It doesent seem to have excessive blow by from the tests I read to try on here but I guess I will recheck it. runs great other wise.
  #5
Old 08-01-2012, 12:48 PM
diesel_brad
Offline
STILL LEARNING
Member's Gallery
I would 1st do complete service on the whole truck, engine to axles, filters and fluids.
If blowby is not a problem, I would be looking at injectors. These injectors are typically for for 150-200k. After that they just got sloppy and inefficient.
You could also look at power adders(chip, exhaust, intake)
  #6
Old 08-01-2012, 01:30 PM
fordboy
Online
Member's Gallery
ok whats a good wayto check the injectors? Do you think a chip and intake/exhaust would help if thee is other issues or will I be adding to my truobles?
  #7
Old 08-01-2012, 02:44 PM
diesel_brad
Offline
STILL LEARNING
Member's Gallery
You have to pull the injectors and have the flow tested
  #8
Old 08-01-2012, 07:04 PM
pontiacross's Avatar
pontiacross
Offline
OverFuelingForYourPlesure
Member's Gallery
make sure you dont have any exhaust leaks between the heads and the turbo as well, it could just be a boost issue
__________________
Ross
2.6 modified street pulling truck "The Lone Stroke " 2011 season video!
-1996 f350, stock bottom end! swamps 400/400% injectors, swamps BFH turbo, swamps IDM, Swamps tunes, BTS oil, springs, studs, tubes, fuel system, water to air cooler, and much more...
-97 f350 4x4 CCLB tow rig
  #9
Old 08-01-2012, 07:55 PM
fordboy
Online
Member's Gallery
I think I may have an exhaust leak as when you have the windows down and you are driving down the road you get a strong exhaust smell in the cab.
  #10
Old 08-02-2012, 06:27 PM
fordboy
Online
Member's Gallery
tips on where I should be looking for the exhaust leaks at? Also is there a concrete way to verify what I have if any for low by to verify this is not the trouble. Hard to believe it would be for as well as the truck runs, and it has no issue at all with pulling the load up to 55. Still have to hook it back up again though.
(View-All Members who have read this thread : 116
'94IDITurbo7.3, 1997stroker!, 1badpsd, 521TURBO, 7.3L F-250, 7.3psd1999, 70DS, 96BlackOBS, 96f350psd, 96powerstroker, 97 f350 p-stroke, 97-7.3powerstroke, 97Powerstroke Boy, 97supercab, 99whitestroker, Al Mighty, Baja931, bfoster, BIGN, bigshawn, BigSparky, bigwhite96stroker, blackf250, blk6.4, bracketracer, Bugman, Chimera, chizetown, chopper, Coueshunter, Cratos, csp, ctdiesel99, dag4566, danielzink, david212acu, deezeljunky, Denver, dieselmandustin, diesel_brad, Dirtyboy82, Dragon, dragonboi, Epd444, Falls250, FarmBoyStroker, firedriver19, floridastroke, flyinj, ford dually 350, fordboy, Gaius, geared_low550, greenbeast, Greger96obs, gtmustang00, halbig7, halfbreed, hendricksbus, Hijo202, hunter scar, jdsf350, jeremiahmercier, jestersv, Jomax, Josh2021, josh77, Juan-Lightning, konzkustomz, LBZ, leojr, LGibbs91, loudmouth, madpogue, mamadiga, maritimer10, mattman90, MB97PSD, moose7.3IH, MustangMatt96GT, nedkin01, Oakes, old man dave, P714, pa-powerstroke, Patrick Feeley, pennsylvaniabo, pete33, plainjane, pontiacross, reedi1, Rick59, Rocky mountain stroke, rusty1161, sg465, shmober, Slated4Greatness, slufkin, slyfly76, snoblade82, speedman, stik, strokepower, Strokersace, Strokin450, the great white, tughill283, turboaz2, TXStroker97, wa96stroke, Wolfe88Ford, wyoming9, zipp, Zmann, Zrock
You may not post new threads
You may not post replies
Forum Jump
