97 7.3 start problems - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > F-250 & F-350 1986-1997 & Other Ford Trucks > 1994-1997 Power Stroke Technical Info
Thread Tools Display Modes
  #1
Old 07-28-2012, 02:52 PM
aamartin89's Avatar
aamartin89
Offline
97 7.3
Member's Gallery
Exclamation 97 7.3 start problems
I have a 97 f250 xlt 4x4 blah blah blah.......
Two days ago when I went to start it it made a loud click sound like it had a dead battery, but it didn't. Now, sometimes it decides to start, sometimes it doesn't. A few weeks ago I jumped the clutch safety switch. I'm not sure if that would have anything to do with it. Not sure if its a loose wire, bad starter, or something. Let me know if anyone has had this problem and how to fix it.
Old 07-28-2012, 07:31 PM
aamartin89's Avatar
aamartin89
Offline
97 7.3
Member's Gallery
Re: 97 7.3 start problems
Bump
  #3
Old 07-28-2012, 07:33 PM
Bugman's Avatar
Bugman
Offline
Member's Gallery
Check the starter and the connections going to it. Also were the batteries load tested to see if they were good or are you just presuming that they are good?
__________________
  #4
Old 07-28-2012, 07:45 PM
aamartin89's Avatar
aamartin89
Offline
97 7.3
Member's Gallery
Batteries are fairly new. I swapped a battery out as well just to check. I tried replacing the starter relay (solenoid) and that didn't work. I'm gonna go over the starter next. The starter will click when I turn the key. Think I'm gonna take the starter off, wire it up without it attached and see if it turns. Good plan?
  #5
Old 07-28-2012, 11:36 PM
aamartin89's Avatar
aamartin89
Offline
97 7.3
Member's Gallery
Bump
  #6
Old 07-29-2012, 12:23 AM
biggreen96's Avatar
biggreen96
Offline
Member's Gallery
Yeah sounds like your starter is dead, have it checked or check it yourself, just be careful they are high torque so youll want to have a good grip on it.
__________________
96 cclb f350.
idm mod,
gauges-boost/pyro/trans temp
afe stage 2 intake
dp to 4" straight pipe
studs, springs, pushrods
srp1
intercooler
electric fuel convertion
238/100
dp-tuner f6
  #7
Old 07-29-2012, 12:24 AM
aamartin89's Avatar
aamartin89
Offline
97 7.3
Member's Gallery
Ya I'm gonna use a bench vise.
  #8
Old 07-30-2012, 01:43 AM
aamartin89's Avatar
aamartin89
Offline
97 7.3
Member's Gallery
So I took the starter off and tested it. Worked fine. Took off the solenoid and checked it out. Seemed okay. I cleaned all the connections, coated them In anti seize and put it all back together. Started up fine. Weird......
  #9
Old 07-30-2012, 02:00 AM
Strokin450's Avatar
Strokin450
Offline
Real Trucks Rattle!
Member's Gallery
Send a message via Yahoo to Strokin450
Maybe it just wanted a little attention But really sounds like it was a bad connection.
__________________
96 F250 ECLB Intercooler Mod, , 3" downpipe--> 4" straight pipe, 1.1 A/R housing, TS TW tunes, Skyjacker all 4 corners, Maximum boost/pyro/trans gauges, Ion wheels/Nitto tires,Banks trans command, TQ and Valve body upgrades, 160k
2008 CRF-450R- It's a HONDA but still wish it was diesel
2006 Honda Rincon 680 mud machine
  #10
Old 07-30-2012, 02:02 AM
aamartin89's Avatar
aamartin89
Offline
97 7.3
Member's Gallery
Ya I'm sure there was a bad connection somewhere. It all seemed clean and tight when I took it apart though.
(View-All Members who have read this thread : 30
97crew4x4, aamartin89, biggreen96, BigWhite97, Bugman, ccf350stroker, Deererainman, dsinderson, ghohouston, jackson1, Jeffro92, joemx611, King Valley, kodiak65, M8xpld, madpogue, msscatter, MTStoker, ol'red, pumpkin, quartershot, silent64, slushman06, strokepower, strokin 7.3, Strokin450, TNR, toolmangary, wsm
You may not post new threads
You may not post replies
Forum Jump
