help - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 6.0L Power Stroke Technical Info
Thread Tools Display Modes
  #1
Old 07-27-2012, 11:30 PM
04 oilburner
Offline
04 oilburner
Member's Gallery
help
So I need to know how to tell if my turbo needs cleaned or replaced. Is there a way to visually to tell if a cleaning will help or if it is just shot? It was whistling real bad and now I got no boost above 30mph.
Old 07-28-2012, 12:37 AM
pwrstrk6.0's Avatar
pwrstrk6.0
Offline
spoolin heavy!!!!
Member's Gallery
Re: help
Nothing visual....I can almost garauntee u it's one of ur up pipes coming from ur manifolds to ur turbo. The flex pipes break and cause ur turbo to whistle like crazy and loss of boost. Almost every time customers come in with same problem it's that
  #3
Old 07-28-2012, 12:40 AM
pwrstrk6.0's Avatar
pwrstrk6.0
Offline
spoolin heavy!!!!
Member's Gallery
Re: help
And turbo has to come out so u might as well clean it while it's out
  #4
Old 07-28-2012, 01:48 AM
04 oilburner
Offline
04 oilburner
Member's Gallery
Re: help
Thanks I will tear into it when I get home. Have you done alot of them? Is the crack or broken part pretty obvious. If I dont have to replace the turbo that would be good. I appreciate the help.
  #5
Old 07-29-2012, 12:24 AM
pwrstrk6.0's Avatar
pwrstrk6.0
Offline
spoolin heavy!!!!
Member's Gallery
Re: help
Ive done quite a few...if u don't have a replaced passenger side that comes with most egr delete kits then u might as do both sides while ur in there.....couple hours first time around....remove coolant bottle....remove ficm......remove chage pipe to turbo......remove clamps on both sides of turbo..... remove turbo ........remove both fender wells to make ur life easier and unbolt the the up pipes from the manifolds and they're out. For both I believe their $300 ish from the dealer with hardware....make sure u get gasket for passenger side where the up pipes meet
  #6
Old 07-29-2012, 03:58 AM
04 oilburner
Offline
04 oilburner
Member's Gallery
Re: help
Awesome. Thanks a ton.
(View-All Members who have read this thread : 13
04 f350, 04 oilburner, amdriven2liv, codykthekilla, elevateloren, justind, majek5, pwrstrk6.0, sixOno, slyfly76, Sniper32, The Gray Mule, toolmangary
You may not post new threads
You may not post replies
Forum Jump
