Taking the plunge - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 6.0L Power Stroke - Aftermarket & Performance
Thread Tools Display Modes
  #1
Old 07-13-2012, 03:23 PM
6litrestroker
Offline
Member's Gallery
Taking the plunge
Alright so I finally bit the bullet and ordered the Basic solution with oil cooler and coolant filter and EGR Delete , 4" exhaust, SCT Livewire and Blue spring upgrade from Sinister Diesel( MKM Customs). Any one have any tips or advice on installation. I am a mechanic but not a diesel tech. Thanks for any advice. Also what kind of coolant should I replace the ford gold with?
__________________
04 SBCC
4x4
Auto
Sinister EGR delete
EGR cooler delete
4" AFE turbo back, no cat , no muffler
Sinister coolant filter
SCT Livewire
Blue spring mod
Old 07-13-2012, 04:14 PM
oldbluef250's Avatar
oldbluef250
Offline
Member's Gallery
Re: Taking the plunge
I would install head studs too
__________________
2003 F350 cclb 6.0
  #3
Old 07-13-2012, 04:22 PM
Kbryant777's Avatar
Kbryant777
Offline
Member's Gallery
then get some custom tunes and you can just enjoy the truck
__________________
[B]2005 F250 King Ranch
Studs,egr delete, regulated return,RCD 68powermax, banks CAI,FICM tunes from PHP, Tuned by Eric
  #4
Old 07-13-2012, 05:13 PM
6litrestroker
Offline
Member's Gallery
Head studs are next on the list. I figure if I am easy on her I will be OK.Once I get the studs in then watch out.
  #5
Old 07-13-2012, 05:16 PM
Kbryant777's Avatar
Kbryant777
Offline
Member's Gallery
I would also do the stc update while you are in there. Wish I had some help for the install but RCD worked on my truck cause I was outta town for a couple months and diet have time
  #6
Old 07-13-2012, 05:41 PM
shreyshah1120
Offline
dieselnoob.
Member's Gallery
maybe some cat elc
__________________
2004 f250 ccsb rwd, rcd egr delete, oil cooler, pmm coolant filter, straight piped
  #7
Old 07-13-2012, 07:40 PM
06_WhiteBull's Avatar
06_WhiteBull
Offline
Gettin there
Member's Gallery
Ford doesn't approve coolant other than Gold, so if you're under warranty I'd stick with it. If not, alot of guys are running CAT ELC or Delo. I will be running the CAT after my flush. I'm pretty sure International (they make the engine ours is based off of) recommends ELC.
Also, before you strip everything out, do a coolant flush (there's a procedure for it in the tech folder) that way your system is clean for the new cooler. Change your coolant filter after 1,000 miles in case there was anything missed by the flush.
A long read but worth it to understand how CAT ELC works.
Cat Extended Life Coolant incorporates advanced formula technology with organic additive corrosion inhibitors. It is free of nitrates, silicates, phosphates, borated, and amines. Instead, CAT ELC uses mono- and dibasic organic acid salts to provide maximum protection of the six basic metal alloys - copper, solder, brass, steel, cast iron, and aluminum - found in most heat transfer systems. Some nitrites and molybdates are added to help protect the iron components in the cooling system.
Since CAT ELC doesn't contain phosphates or silicates, hard water deposits in the cooling system are practically eliminated, and the low level of total dissolved solids improves water pump seal life. ELC's advanced technology also prevents gel formation and provides excellent protection against cylinder liner cavitation corrosion.
Plus, additives used in ELC don't deplete as fast as those in conventional coolants. Coolant life in heavy-duty diesel engines is limited by the depletion of the corrosion inhibitors. In conventional coolants, supplemental coolant additives (SCAs) deplete, so heavy-duty diesel engine manufacturers require that you add SCA's at every oil change. With CAT ELC, however, additives deplete much more slowly - so you don't need to add any SCAs.
I copied the above from Caterpillar.
One other note, no matter what coolant you use, if you don't maintain it you will have issues. By the way, I am no expert, just do alot of reading before I do chit.
  #8
Old 07-13-2012, 07:49 PM
6litrestroker
Offline
Member's Gallery
Thanks for the replies. I checked on the cat ELC. Found out that Zerex makes a coolant that is compatible with the cat ELC?
  #9
Old 07-13-2012, 09:03 PM
06_WhiteBull
Offline
Gettin there
Member's Gallery
Compatible?? I think you mean comparable. Yea, I have heard of it but don't know anyone running it. One thing you don't want to do is mix different coolants...BAD news.
  #10
Old 07-13-2012, 10:54 PM
6litrestroker
Offline
Member's Gallery
No doubt on that one. Sorry for the mix up.I am going to do a full coolant flush so there wont be any mixing of coolant. Thanks 06 WhiteBull
(View-All Members who have read this thread : 111
'94IDITurbo7.3, 03StrokerJoker, 04 f350, 04harley250, 04_stroke, 06_WhiteBull, 08twinturbo, 1999 7.3L, 2005Ex6.0, 2005stroker, 6litrestroker, 7.3 Blackout, 95doodoo, 98stratusryder, acplowboy84, adrenalinejunky81, airfish2011, alalhunter, Backwoods Electric, baller9409, bboteler, BCF250, BIG"E", birddog55, blakes, bootcamp, BootZ0360, cam1111, chadsstroker, Chall12, charlez, Codydiesel, cporda, cshsrh, Dane1985, daves02, DieselDavis, Dieselpower187, Dieseltechjesse1, Dirt Floor Poor, dixiefishing, DNichols3288, ebs05, eyoung, Fastassdiesel, ford fanatic, Ford4Eva, ford4life76, g2shuck, geared_low550, Grey91, huntergodwin12, int6.7, intakeu, jamcconnell2, jaredb, Kbryant777, KCMEADOWS, kmanxj, mattm, mcjr, meatmachineman, mkelly, muddynoll, mudoc, new2deisel, nrook, Nutz, oldbluef250, pa-powerstroke, pbuxton11, pete33, pizza pig, Power12, powerstroke44241, powerstrokedkid87, POWERSTROKE_GOD, Powerstrokinfirefighter, PScompGenius, Quackaddict, RAUD, Rescue48, Rmartin-97, Rocky mountain stroke, rougerocco, sailor95, sargepep56, Seven-Point-Three, shadow6.0, shreyshah1120, slvr bullet, slyfly76, SnowRider1, spb_2006, stroked06, StrokeThis34, SuperBlazin, Swamp Star, tavis43, terrye, The Butcher, TheReelMuhcoy, Thunderpimp, tl1000r, upsidedown2, vegasff13, vindiesel2, Weatherlite, Wheelhop, yodermanks, Youngwvcoalroller
You may not post new threads
You may not post replies
Forum Jump
