Boost gauge doesn't work - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > F-250 & F-350 1986-1997 & Other Ford Trucks > 1994-1997 OBS Power Stroke - Aftermarket & Performance
Thread Tools Display Modes
  #1
Old 07-09-2012, 02:49 AM
kmanxj
Offline
Member's Gallery
I just bought my PSD it has a boost gauge made by glowshift, It reads with a vacuum hose. It is ran and T'ed into a vacuum line that comes off the Y pipe. The guy i bought it from says that the line from the gauge is to big??? seems weird to me
Old 07-09-2012, 02:55 AM
btomassacci
Offline
Member's Gallery
Re: Boost gauge doesn't work
My line is 1/8. Mine don't read vaccum so don't know if they would be a different size of not
__________________
3in DP, 4 in straight, e fuel, Regulated return/ bowl delete, air dog 165, banjo bolts drilled out, ts 6 pos chip, HPX line, intercooler, EBPV delete, CCV mod, Valair Clutch
  #3
Old 07-09-2012, 02:57 AM
BIGN's Avatar
BIGN
Offline
Member's Gallery
Look up Glow Shift on YouTube and there is a complete installation video on how to install the gauges. Don’t know what vacuum line you are talking about but definitely doesn’t sound right to me.
__________________
2000 F250 4X4 Auto 7.3
6637 intake
PHP phoenix chip
Glow shift Gauges
Trans temp,Boost, EGT
Diamond Eye 5" Exhaust
  #4
Old 07-09-2012, 05:59 AM
04yfzkid's Avatar
04yfzkid
Offline
Member's Gallery
Sounds like the vaccum line off the y-pipe is the MAP line. If so that should be perfect spot. It's where I tied into on my 97.
I do not get why the line size matters. When you pressurize something it is equal pressure everywhere. Pressure doesn't decide to be at 15 psi on the map line and 50 psi in your intake pipes.
__________________
04 cobra - MMR 5.0 stroker, 3.4 whipple, e-85, 30psi of boost when the belt doesn't slip Currently converting to 78mm turbo and ported heads with cams.
Looking for a 96-97 CCSB 4wd auto XLT with power everything and preferably no rust with TTB still.
  #5
Old 07-09-2012, 06:08 AM
onebad97's Avatar
onebad97
Offline
Buy Low Sell High
Member's Gallery
My glow shift guage insatll talked about vacume also which I ofcourse wrong. But check tba you have no leakes in the line and that it is hooked up to the guage and is not punches anywhere. When I put my pillar back I accidently pinched my line and dident give me a reading.
__________________
1997 F250 Psd, 5-speed, 4X4, ecsb, single mass fly wheel, 3" down pipe, stright piped, 6 position Ts performance chip, boost & egt glow shift gauges. Leveling kit.
  #6
Old 07-09-2012, 07:27 AM
BIGN's Avatar
BIGN
Offline
Member's Gallery
same thing happened to me
  #7
Old 07-09-2012, 08:09 AM
ajfetterman's Avatar
ajfetterman
Offline
Member's Gallery
The MAP line is what you want. You arent trying to test it in the driveway are you? Go out and drive it. Other than that I also would check the line for pinches.
__________________
2002 CCLB 4X4 6" skyjacker lift * Ford AIC * 4" turbo back Diamond Eye exhaust * 6637 mod w/ Donaldson filter * Gauges* No Foil * Edge Insight CTS
1988 Camaro Iroc Z
2000 Polaris Scrambler 4x2 400- Bored out and tuned by DAB Racing
~Andy~
  #8
Old 07-09-2012, 11:57 AM
kmanxj
Offline
Member's Gallery
I'll check the line tonight for pinches. And i am in the driveway, but i bought it 3 hours away from home and it didn't move the whole way.
Does the size of the line matter?
  #9
Old 07-09-2012, 12:12 PM
ajfetterman
Offline
Member's Gallery
Mine is 1/8" line. Dont look for it to move while you are just cruising, you have to have your foot in the pedal. At WOT a stock 7.3 will only hit about 18-20. What are you putting this on an OBS?
  #10
Old 07-09-2012, 01:55 PM
sweetdreamz's Avatar
sweetdreamz
Offline
Member's Gallery
Agreed. Check at WOT for movement in the gauge. If that does'nt work run a new line straight from the MAP to the gauge, this will tell you if it's the gauges fault or a leak in the line.
__________________
2001 F350 7.3 CCSB 4X4 - 6-position chip (Bean's) - Riff Raff 6637 intake kit - foil delete - 8" single stack - 6" lift (unknown brand) - 05 front end conv w/HID projector - 20x10 XD strike - Federal couragia 35x12.50x20
(View-All Members who have read this thread : 67
04yfzkid, 16yrenthusiest, 1997stroker!, ajfetterman, Alvapowerchoke, Bayonet16, BayRoan, BIGN, bigstrokin33, btomassacci, Bubbawagsf250, Bugman, ccf350stroker, Chewii, Cratos, danielzink, dentexpowerstroke, Derek C, dragonboi, dsinderson, dwelder454, farmboy17, FarmBoyStroker, Gaius, GASMAN6674, georgia diesel, Greger96obs, grimF350, H-Bomb, Jeffro92, jp115, jrbrock, JWarner, klipz, kmanxj, lorado04, loudmouth, lovesdunes, mantis118, moose7.3IH, MrNiceGuy, Nodge, nossliw, Oakes, old man dave, oldschool, onebad97, Patrick Feeley, patrickke, PsRumors, Robjesup88, sdjohnny, Sethward, sg465, Skew12, smok531, smokinford07, Snail1, StrokinNsmokin, swaan, sweetdreamz, tsanjose, wa96stroke, Welderguy24, Youngwvcoalroller, ZC628
You may not post new threads
You may not post replies
Forum Jump
