| Register | Members List | Timeslips | Calendar | Sponsors | Becoming a Sponsor | Mark Forums Read | Auto Escrow | Auto Loans | Insurance |
Thread Tools | Display Modes |
#1
wrench light
Hi All, I recently bought a 06 king ranch, had it about a month and the egr cooler took a crap. I had that replaced by Ford, with a bullitproof one. I was told that the oiler cooler was checked and it was within the parameter to work correctly. About 2 months after that i purchased a 30 foot travel trailer and two out of the three times towing it, the wrench light has come on. I am going in this thursday to have the codes pulled. I am just looking for an information from others with the same problem.
It did not go in to limp mode and turbo gauge "factory one" is running around 23 uphill, while towing. thanks in advance, Joel |
| Sponsored Links | |
Advertisement |
#2
Re: wrench light
Joel
Need to get a good set of gauges to tell the health of the motor something like the Edge CTS, CS or even the Scangauge II harder to install but all are plug and play. With the Scangauge you will need to add a pyro gauge a must if you pull. With the CTS I'm running 11 different things at one time, 8 on the CTS, boost stock, fuel on the column, volts from a power port. The main reason the egr cooler went out is the oil cooler plugged from casting sand and silicate drop out from the Ford Gold coolant They should of changed the oil cooler.2 stroker
__________________
06 F350 4x4 PSD Lariat FX4 CC LB Edge Insight CTS-Expandable Pyro AutoMeter Fuel Pressure Gauge Fuel Reg. Kit 3C3Z-9T517-AG Amsoil By-Pass(Amsoil 5w40) Delo ELC-coolant Filter pulling 14,000 lb Alpenlite 5er 97 F350 4x4 PSD CC LB PacBrake&ATS converter lockup 3" dp 4" exhaust TruCool 28,000 lb cooler Tymar Intake EGT,Boost,Trans |
#3
Re: wrench light
I would have paid for the oil cooler kit out of pocket while they were in there doing the EGR cooler but that ship has sailed
![]() but it's all speculation on what your problem is until the codes are pulled ,, one thing I would check or clean is the EGR valve and if you want to clear the codes disconnect the batteries .. but it is good to read them first (of course)
__________________
O6 King Ranch cc sb 7 inch lift ,37 Toyo's,Helo’s Edge Insight CTS guage only , Auber EGT , o8 center console ,2x10 subs, xm satellite ,coolant filter,RSX 9000 shocks,dual bilstein steering stabilizers ,Viper , remote toolbox popper, High Idle mod , up fitters added ,weather guard mats , ARP's, BPD EGR cooler, Fabtech traction bars, X3 Matt's tunes |
#4
Re: wrench light
thanks, i will pull the egr today and take a look.
#5
Re: wrench light
cool do a search on how to clean it or post back and ask ,, you don't want cleaner in any port above the valve
I set mine in a glass cup filled with solvent |
#6
Re: wrench light
So i pulled the egr, it was very clean. i cleaned it a little more. My friends shop was closed today, so i tried autozone, and there were no codes stored. I will stop by the shop tomorrow.
#7
Re: wrench light
Here is the egr.
#8
Re: wrench light
I wet to the shop, and had my friend check the codes, and nothing. He has a nice Matco setup, so i would think that would be able to retreive all the codes. hmmm what next?
#9
Re: wrench light
Maybe it has the newest strategy on it (flashed by ford) where the coolant and oil temps get out of tolerance it throws the wrench light.
__________________
2005 Ford F-250 CCSB-Lariat-FX4-SRW GearHead / PHP / AutoMeter / Diesel Site / Weather Tech Viper / Pioneer / JL Audio / Mmats / Alpine / Stinger MECP Certified Mobile Audio/Video/Security Installer |
#10
Re: wrench light
Several things can cause the wrench light - such as oil cooler efficiency, APP performance, turbo overboost, and battery voltage. Your issue sounds like an oil cooler issue. Find out the actual EOT and ECT values.
A wrench light will throw a code, sounds like the Matco won't read all of the Ford codes.
__________________
Mark 06 F250 CC SB FX4 Lariat;ARPs OEM gaskets;Banks exhaust;DynaTrac Balljoints;RACCCV6000;Updated HPOP fitting;JimmiJammers;Ravelco;plugs&standpipes;Fumo to;Harpooned;Quadzilla XZT Fuel Press;Blue spring;DashDAQ;PHP_FICM; RiffRaff boots;DCPower250A w/ Inverter;Rancho7000's;BPD EGR cooler;BPD WaterPump;SCT Matts SRL+;ELC Ultra w/ filter;SynchroMax |
| Thread Tools | |
| Display Modes | |
