97 Powerstroke wont start!!? - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > F-250 & F-350 1986-1997 & Other Ford Trucks > 1994-1997 Power Stroke Technical Info
Thread Tools Display Modes
  #1
Old 07-03-2012, 11:54 PM
97F250HD
Offline
Member's Gallery
Just recently my truck decided it would just stop running.. the truck died like i turned it off, but when i crank the engine it just turns over and over and no ignition. ive replaced the CPS, that didnt work.. i than relized that i wasnt getting fuel to my filter.. so i changed the filter.. still nothing. i also checked my HPOP resivior and that 1 gallon top alluminum tank was empty.. so i filled it and i tried to clean the IPR but that did nothing as the truck still doesnt start...!? im lost and dont know what the problem is.. IDM or HPOP or LPOP..? any suggestions would be greatly appreciated!
Old 07-04-2012, 01:23 AM
countryboyrob
Offline
Member's Gallery
Re: 97 Powerstroke wont start!!?
If youre not getting fuel into the bowl then your fuel pump is bad.
Click thread tools, move thread then click the obs tech section.
__________________
02 f250
  #3
Old 07-04-2012, 02:49 AM
powerstroke cowboy's Avatar
powerstroke cowboy
Offline
Running at last...
Member's Gallery
Did the HPOP Resevor stay full after cranking??
__________________
97 CCLB 4x4 ZF6 99@15.7
  #4
Old 07-04-2012, 03:23 AM
Bugman's Avatar
Bugman
Offline
Member's Gallery
You have a mechanical fuel pump so if there is no fuel getting to the filter housing then it is either the pump or you have a fuel restriction in the lines.
__________________
  #5
Old 07-04-2012, 11:45 PM
97F250HD
Offline
Member's Gallery
Okay thanks! here is an update, i cranked the engine a few times for about 20 sec each time and the fuel filter gets fuel but still didnt fill it full only about half way.. the oil in the HPOP didnt leak out any it stayed right at the top. also if it is my fuel pump would i be better off just going to electric or do these pumps usually last awhile?
  #6
Old 07-05-2012, 01:06 AM
7.3 injection's Avatar
7.3 injection
Offline
Member's Gallery
Electric is so much better I think, if you have the money for that kind of swap. Cpr fuel systems is good or air dog. Definitely a fuel pump issue u have good luck.
  #7
Old 07-05-2012, 01:38 AM
powerstroke cowboy
Offline
Running at last...
Member's Gallery
I would not do a AirDog.. I have one.. When it goes out I will be doing a daul SD pump setup..
  #8
Old 07-05-2012, 02:26 AM
Poh's Avatar
Poh
Offline
Respect my awesomeness
Member's Gallery
got 238,xxx miles on my mechanical pump, still running....... going to do efuel when I get around to injectors and HPOP..... but for $169 nib mechanical pump....... put another mechanical pump in it while you collect parts for an efuel swap.
__________________
96 F350 Crew Cab Dually. 7.3L stroke. CXracing intercooler, 3" Down pipe, Tru cool max transmission cooler, EBV delete.
just to live does not mean you're alive
  #9
Old 07-05-2012, 04:18 PM
countryboyrob
Offline
Member's Gallery
Alright since its getting fuel we can rule out fuel pump then.
  #10
Old 07-05-2012, 10:32 PM
97F250HD
Offline
Member's Gallery
Alright fuel pump works i checked the PSI it was 40-50 while cranking... when i crank the engine over for approx. 10 sec the oil pressure gauge moves up to normal on the dash in the truck.. im thinking a bad IDM maybe? what do you guys think..?
(View-All Members who have read this thread : 60
1992ccsbpsd, 6.9PoweredScout, 7.3, 7.3 injection, 7.3L F-250, 96Crewcab7.3, 97F250HD, adrenalinejunky81, bigwhite96stroker, bonser16, Bugman, cabloom7.3, chuck heck, Coueshunter, cpdad93, Deererainman, DragginAssphalt1, dsinderson, eric96ford, FarmBoyStroker, Fourplay II, Franchi, greenbeast, gregbrownlow, gtmustang00, halbig7, hunter scar, Jamie V, Jcam88, Jjona5, jmitch50, Justincredible, kb2red, killforfood, kootenay7.3, madpogue, mastrkee, maverik2711, Mike97f350, MJBSEVENTHREE, Mudlight, old man dave, Ole Nasty, pappa b's powerstroke, Patrick Feeley, pff250hd, Poh, powerstroke cowboy, PowerstrokeMudder82, procharged 79, psd=junk, Ranger50, redfordpsd, ryandamo, Sandpro, stevv, The Fireman, wb589, Weldon
You may not post new threads
You may not post replies
Forum Jump
