| Register | Members List | Timeslips | Calendar | Sponsors | Becoming a Sponsor | Mark Forums Read | Auto Escrow | Auto Loans | Insurance |
Thread Tools | Display Modes |
#1
cleaning the intercooler
just removed the intercooler. it was full of oil from the crankcase vent i think. i want to know what is the best way to clean it myself. i was thinking simple green and some water.
__________________
2001 F350 4 DOOR LONG BED,8" SKYJACKER LIFT ,35" BFG AT ON 17" AMERICAN RACING BLACK THUG WHEELS,DP TUNED,60 TOW,80,120,80PRO,120PRO,140,SLED PULL,FUEL PRESSURE SHIM, ARIAD INTAKE, JOHN WOOD TRANNY WITH 6.4 TC,IDM MOD,ZOO DAD, AUTOMETER PHANTOM 2 GUAGES.HP OIL CROSSOVER.GARRETT BB,BELLOWED UP-PIPES, NON EBV PED.HIGH FLOW OUTLET.167,000 MILES. |
| Sponsored Links | |
Advertisement |
#2
Re: cleaning the intercooler
that or brake cleaner.
__________________
02 CC 4x4. AFE stage 2, Magnaflow 4" exhaust, BTS tranny, live-tuned by Jody, AC singles, DI regulated return, Terminator HPOP, DR 4.5" lift & some other stuff... Southern Nevada PowerStrokes |
#3
Or both. Let it dry and drain really good before reinstall.
__________________
Early '99 F350 DRW, Excab, LB. Auto. 2WD, 2010 bed, 2005 headlights, 298K, on my way to 1000K. H2E, 238 Hybrids, Adrenaline oil, Tuned by Tony. DIY Regulated Return. |
#4
2-3 tablespoons of Dawn dish washing liquid in hot water, pour it in let it soak for about an hour.
Shake it to agitate then rinse,repeat if necessary. Brake clean will cause the plastic to become brittle if used on an IC with plastic end tanks. Simple green can be corrosive to aluminum; this type is safe for alum. http://industrial.simplegreen.com/ind_prod_ext_mor.php
__________________
01 F-250 CC 4R esof PMT AIS, pine tree air freshener, some other stuff not worth mentioning . |
#5
Good info. I will have to remember that.
#6
thanks for the input. now i thought the oil was in there from my new turbo blowing a seal but tn said it was fine when i sent it in. what are the chances of the crankcase vent putting that much oil into the intercooler. i never had a problem before just recently and i dig the crankcase vent mod. they told me the extra boost is sucking the oil out and causing me to burn it. has anyone else had this problem.
#7
I've heard that the crankcase puts a lot of oil into the CAC, so I could imagine a lot of oil. I'll be installing a 6.0 CAC in the next couple weeks, so I'll know then.
#8
When I removed mine and installed a spearco I set the stock one on edge to see how much oil came out of it... I barely had anything come out...just a couple small drips...
#9
I drained way less than a quarter of a cup after one year with the H2e. I really do not think that hurt the performance any.
__________________
2002 F350 Lariat CC 4x4 4.10 DRW, with "the ultimate towing setup!": Nov 30, 1999 engine with Fluidampr, Melling LPOP, 910 springs and ARP headstuds, DP-Tuner, DI regulated return, AC singles with 80% over EDM nozzles, BTS dual HPOP, H2e, Spearco 6.0 IC and BTS tranny . |
#10
Cascade works good also, we use it at our shop when semi blow a turbo.
__________________
99 PSD dually 4" lift 35' tire 4" exhaust to 6" Aussie's K&n air filter cc mod Beans stage II 120hp injectors Beans D66 turbo ITP regulated return updated ecm (2000 model) reburned TS chip- 25,high idle,60,100,120,140hp Dyno #'s 360hp and 965 ft lbs trq |
| Thread Tools | |
| Display Modes | |
