Dead 7.3 - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > F-250 & F-350 1986-1997 & Other Ford Trucks > 1994-1997 Power Stroke Technical Info
Thread Tools Display Modes
  #1
Old 06-12-2012, 12:43 AM
Jarrett Johnson
Offline
Jarrett Johnson
Member's Gallery
Dead 7.3
I have a 97 ext cab 4x4 all stock did a zf swap and electric fuel system other than that it's all stock truck ran good then just died I have changed ipr icp cam sensor temp sensor oil pressure sensor idm hpop new low pressure pump new o rings on injectors I have changed and replaced everything but computer and it just won't start full on oil and fuel still has auto computer but ran fine before any thoughts also has good compression and oil pressure
Old 06-12-2012, 03:40 AM
old man dave
Offline
Terminator Nation
Member's Gallery
Re: Dead 7.3
How long did it run after the swap?
__________________
Just another 408hp '97 California Truck with a stock muffler
community.webshots.com/user/davepowerstroke
  #3
Old 06-12-2012, 05:39 AM
madpogue
Offline
Member's Gallery
Re: Dead 7.3
Does the WTS light come on?
Does the tach move when you crank it?
Any white smoke as you crank it?
Do the SHIFT and PERIOD (and question mark) keys on your keyboard work?
  #4
Old 07-16-2012, 02:40 AM
Jarrett Johnson
Offline
Jarrett Johnson
Member's Gallery
Re: Dead 7.3
It ran for a few months after the swap. All the lights on the dash work and same with the tach and oil pressure. I have changed all the upper motor wiring, idm, ECM, all sensors and new electric fuel pump. It's got plenty of oil pressure and is opening the injectors, I know that because I can here them. No check engine light comes on. It will run all day long with a can of ether in it so must be fuel right? It's getting fuel to the heads and the injectors click like they are opening so why won't it fire up?
  #5
Old 07-16-2012, 02:41 AM
Jarrett Johnson
Offline
Jarrett Johnson
Member's Gallery
Re: Dead 7.3
No smoke while it's cranking unless you are using ether
  #6
Old 07-16-2012, 07:00 PM
Jarrett Johnson
Offline
Jarrett Johnson
Member's Gallery
Re: Dead 7.3
Has 55 psi fuel pressure
  #7
Old 07-16-2012, 08:01 PM
sho669's Avatar
sho669
Offline
Horsepower Enthusiast
Member's Gallery
Re: Dead 7.3
You need to scan it with a decent scanner that can read icp and such.
Other than that I'd recomend finding a nice stainless dual well sink and throwing that at it as well.
__________________
03 CCSB King Ranch 4X4 6.0, IDP Xstreet, Muffler delete. 13.94@92.86
00 CCSB, ZF6, 2WD. RIP 1-22-12
06 Mitsubishi Evolution IX SSL, LR 2.0, TS EFR9180, E85, 4 slicks and a chute...maybe some other stuff
69 Camaro, awaiting turbo 580 BB and chassis work
  #8
Old 07-16-2012, 10:22 PM
Jarrett Johnson
Offline
Jarrett Johnson
Member's Gallery
Re: Dead 7.3
Yea no kidding. I have read the icp with a scanner and it's at 3000 psi. Well at least that's what ford said when they read it.
  #9
Old 07-16-2012, 10:47 PM
sho669's Avatar
sho669
Offline
Member's Gallery
Re: Dead 7.3
Fuel heater/ECU fuse blown maybe? Sometimes you can get an airlock in the fuel bowl after its been drained.
Just throwing out some stuff I can think of that would still be left. RPM signal is good?
  #10
Old 07-16-2012, 10:50 PM
sho669's Avatar
sho669
Offline
Member's Gallery
Re: Dead 7.3
A couple months ago I worked on a SD that wouldn't read RPM. Tried CKP, checked crank endplay, traced wires, no dice.
Swapped in a known good PCM and she fired right up. All the PID's read good oil wise and it had planty of fuel just like yours.
Another thought.
(View-All Members who have read this thread : 129
1997stroker!, 4btchev, 94youngturbo, 96BlackOBS, 96Crewcab7.3, 97 7.3 cole berk, 97CCLB410LS, adrenalinejunky81, Alvapowerchoke, Aminator, baggedbug, barber97powerstroke, barrakudaman, bert, bfoster, bhfarms, bigdog97, biggreen96, Blowby, bpa658, buford48, Bugman, C.D., ccf350stroker, chopper, chris1978, Codydiesel, codykthekilla, coyote1, cpdad93, CSIPSD, Cumminspr513, Cutty72, cwbydw, davidamontoya, Deererainman, Deerslayer42694, Denver, Diesel X, Ditchwitch, drh4250, dsinderson, dslcat, DWhitey, eric96ford, excavator, FarmBoyStroker, farmer09, firehog2, Fox24, fpOwerstRokeD, geargrabbin97, ghohouston, haulin99sdp, helo1, hendricksbus, HMWH, hunter scar, ike0321, Jamie V, Jarrett Johnson, JD3020, Jeffro92, josh77, jrbrock, kawihaller48, kbmkviii, killforfood, King Valley, klos, Ks94.5powerstroke, leojr, madpogue, martinique78, MidwestOBS, mikes95powerstroke, mjpage69, mojoman, MOTO7.3, Mudbrother, Nally7.3Powerstroke, neher72, Nitro41, Nodge, Oakes, old man dave, ole red, Otter70, Patrick Feeley, Patrolman, Pinski1015, Poh, powerstroke cowboy, powerstroke02, powerstroke600, powerstrokefarmboy, powerstroker66, powerstroking7.3-444, p_stroke_1, Ranger50, rayd1969, rideracelivemx7, rjhoward32006, RubberDuck, Rusty-Ford, rwhite1, shaynep, sho669, smith7.3, smokinford07, spectreblazer, strokedout73, Strokeradict, strokin n smokinn, Strokin450, TBarrsTruck, Thunderhawk6630, ToMang07, toolmangary, tughill283, TXStroker97, Wardy70, wb589, Weldon, wesconjr, zilla68, Zrock
You may not post new threads
You may not post replies
Forum Jump
