Yep just buttoned everything up yesterday afternoon and took it for a drive. Runs awesome and seems to be pretty responsive but I desperately need to have my chip re burnt. Oh and the sound is just sweet, people look at it like wtf?
Well I kind of been looking around and taking notes on what sizes everyone else has for their setups. I know I wanted to move a lot of air at a low pressure and I had this on the shelf off the tractor so I decided to try it and it seems to be working good. As far as gates it has been good so far. 50lbs at the manifold and about 12-13 on the first stage. The only thing I want to change is the 2nd stage. that stocker kind of makes me nervous and I know it dosent spool like it would with a bb drop in.
Yep had to no room to keep the ac and everything and run a 5 inch pipe out of the turbo between the evaporator core and manifold and no body lift really makes it hard
Yep I have a cooler on the first stage. Injectors are 275's with .012 nozzles and Ive been able to get 50lbs out of it easy enough but it is moving a $hit load of air.
urbanwheeler, I was thinking of that but when I was welding it nothing flaked or peeled off the pipe. If it was going to flake my assumption was it would have done it then. I guess time will tell and it will most likely get revised when I go to a different 2nd stage.
Cracker, where in florida do you live. You might get to see it sometime I'm down south at my grandparents near Sebring.
