1997 Ford F350 7.3 will not start - PowerStrokeNation : Ford Powerstroke Diesel Forum
Register Members List Timeslips Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto EscrowInsurance
Thread Tools Display Modes
  #1
Old 04-01-2012, 11:38 PM
vallery47
Offline
Member's Gallery
Engine shut down with no warning, I have replaced the fuel pump, and the crank sensor. The truck still will not start. It will start on either and then immediately shut down. Can anyone make a suggestion or have any idea what the problem may be?
Reply With Quote Quick reply to this message Go to the top
Old 04-01-2012, 11:42 PM
powerstrokeracing's Avatar
powerstrokeracing
Offline
Young'n
Member's Gallery
Re: 1997 Ford F350 7.3 will not start
IPR? check the wiring to it as well. seen the wires break before. easy on the ether
__________________
  #3
Old 04-01-2012, 11:43 PM
vallery47
Offline
Member's Gallery
Hate to sound like an idiot, but where is the IPR located?
  #4
Old 04-01-2012, 11:48 PM
DMDP's Avatar
DMDP
Offline
Quitter
Member's Gallery
IPR is on the hpop. Did you check your fuel bowl heater fuse?
__________________
Jon
96 F350 Puller "Crazy Ex" - 6 cylinder with a lot of fuel and air
'10 f250 ccsb 6.4. Leveled, 35s. 5 inch exhaust, innovative tuned
  #5
Old 04-01-2012, 11:50 PM
DMDP's Avatar
DMDP
Offline
Quitter
Member's Gallery
Fuse #22 in the fuse panel under the hood
  #6
Old 04-01-2012, 11:52 PM
vallery47
Offline
Member's Gallery
Checked the fuse, its OK. In the process of the checking the IRP. Thanks!
  #7
Old 04-02-2012, 12:27 AM
vallery47
Offline
Member's Gallery
Woops typo, IPR
  #8
Old 04-02-2012, 11:28 PM
tbolt's Avatar
tbolt
Offline
Member's Gallery
might check in the obs section. I'm not familiar with those minor diff from our superduties. Good luck.
Have you scanned it??
__________________
Glen
early99 f350 cc, lb, 2wd, drw, A pillar autometer guages, CTS monitor, AIS intake, 4" turbo back cat delete diamondeye exhaust, dptuner, pmt1, jw vb, Swamps ab inj, Adrenaline oil, Coolingmist, 180*T, Trucool cooler, spin on trans filter, Firestone air bags, 2" frt leveling kit, now chased by a 34' toyhauler
  #9
Old 04-02-2012, 11:37 PM
middlemanjw's Avatar
middlemanjw
Offline
Member's Gallery
what he said take it apart and clean it or replace pry stuck open!
it on the back side of the hpop!
  #10
Old 04-16-2012, 03:29 AM
f0rdracing
Offline
ASE CERTIFIED TECH
Member's Gallery
WOW!! I had the same problem and took a month to figure it out. First thing is to take off your fuel filter and check if there is correct amount of fuel in it. I can almost bet you have a clogged fuel line like mine. I changed the same things you did on my 97. The problem was the fuel tank auxiliary switch on frame rail before tank was fully clogged with black mudd to the main feed line. I just bypassed mine to front tank only and was a $20 fix. Rubber fuel line,barbed fitting and hose clamps and it was fixed! You can take it off and clean it but for me the switch was bad and only ran the front tank anyway. Man hope this help you and good luck!!
If you do not want to register, fill this field only and the name will be used as user name for your post.
Human Verification
(View-All Members who have read this thread : 39
300,000 and counting, 95PwrSmoke, aggressivediesel, Bugman, ByrdDog, catfish, ccf350stroker, chopper, cota, cpdad93, DMDP, dzlj 50, f0rdracing, Falk, fordpsd, ghohouston, Heywire77, jk59640, kilapapipa, Lew99, Mdoffroader23, middlemanjw, Obspsd7.3, oilplane32, opiespowerstroke, powerstroke095, powerstrokeracing, shaynep, sleepyhead416, SnowFlake, spongebob915, stroker525, tbolt, Terry johnson, vallery47, wb589, Wildfire532FB, yellak9, ZMONSTER
Forum Jump
