6.0 wont start when warm - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 6.0L Power Stroke Technical Info
Register Members List Timeslips Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto EscrowInsurance
Thread Tools Display Modes
  #1
Old 03-11-2012, 02:34 PM
roach's Avatar
roach
Offline
Member's Gallery
a cpl weeks ago when i showed up on the job(50 miles from shop)i shut my truck(06 f250 6.0) off and was checking out the site.i went to move my truck and all it would do is turn over,no start. i grabbed my tools and started working. at lunch i tried again and it started. it has been doing this since. when i drive it long enough to get it warm and then shut it off it wont start for at about an hour.any ideas until income tax gets here and i can take it to the shop?. thanks
__________________
2002 f350 7.3
2006 f250 6.0
Reply With Quote Quick reply to this message Go to the top
Old 03-11-2012, 02:55 PM
02-7.3
Offline
Member's Gallery
Re: 6.0 wont start when warm
Sounds like you have a internal high pressure oil leak. Pipe connection at pump or branch tubes. Fun to fix and hard to diagnose.
  #3
Old 03-11-2012, 05:14 PM
lubeowner's Avatar
lubeowner
Offline
Member's Gallery
Easy to diagnose and easy to fix. If you do it yourself it is about a $20 part. Take you about 1 hour to fix maybe 2 since it is your first time.
__________________
Jeremy Johnson
Search "lubeowner" on youtube for many truck pulling videos.
dieseldr.net
We build Powerstroke pulling trucks.
  #4
Old 03-12-2012, 02:40 AM
Turbodiesel6.0's Avatar
Turbodiesel6.0
Offline
Member's Gallery
Do you know if your truck has the updated STC fitting? If not then most likely that is the problem however an air leak test should be done just to be sure. Although your not going to to be replacing that in 2 hours as stated above.
__________________
2005 F350 XL 4X4 6.0PSD
221K
Muffler/Cat Delete, Sneaky up-pipe, Warren Diesel Injectors, ScanGaugeII, Pillar Pod W/AutoMeter Sport Comp-Boost, trans, Pyro, Homemade Coolant Filter, Blue Spring Upgrade
  #5
Old 03-12-2012, 03:01 AM
lubeowner's Avatar
lubeowner
Offline
Member's Gallery
It doesnt have a stc problem.
  #6
Old 03-12-2012, 03:37 AM
stroked99_1/2's Avatar
stroked99_1/2
Offline
Member's Gallery
I do love how anytime someone has a HPO issue on 04-7 everyone automatically says it MUST be STC.
  #7
Old 03-12-2012, 04:49 AM
theGreenHornet's Avatar
theGreenHornet
Offline
Member's Gallery
please elaborate, my friend is having the same problem with his 06
__________________
Will
2006 CCSB F250 Lariat
Edge CTS / SCT (ID Tunes) / Cooper / Diamo / Pioneer / UWS / PMM / Recon
SOLD: 2000 F-250 Lariat CrewCab ShortBed 4x4
Dynatrac / Rough Country / Mazzi / Toyo / WARN / MBRP / Recon / DP-Tuner / Kenwood / JL Audio / Western Diesel /
  #8
Old 03-12-2012, 12:06 PM
lubeowner's Avatar
lubeowner
Offline
Member's Gallery
I know that you have fixed a lot of trucks with these similar starting issues. How many of those stc fitting have been the actual problem?
  #9
Old 03-12-2012, 02:18 PM
stroked99_1/2
Offline
Member's Gallery
Let me think.... None.
  #10
Old 03-12-2012, 03:16 PM
lubeowner's Avatar
lubeowner
Offline
Member's Gallery
bingo! When the sct fittings go bad it comes apart creating a no start at all temps or the truck dieing while going down the road. No start hot is not an stc fitting.
If you do not want to register, fill this field only and the name will be used as user name for your post.
Human Verification
(View-All Members who have read this thread : 174
$3800.06Fx4, '94IDITurbo7.3, 02-7.3, 06 f250 man, 06kingranch37, 06VT365, 14fan77, 1snowcat, 300,000 and counting, 444CuiOBS, 494doug, 5150Mikey, 6.0lover/hater, 6litrestroker, 94idi, 95PwrSmoke, ajfetterman, amdriven2liv, Arkansas6liter, Az07Ford6.0, AZPowerstroke, bas157, benjiblaze, Big Earl, bigstrap3, BillMcIntire, bismic1, bkwstoy, BlackCloudMafia, black_pstroke, Blake Williford, Blue Hawg, BlueBetty, bluovldeezl, BOYER74, Brent1, brute_mt, bryan.d, Bustedknuckles, bustednuckles, cchoptank11, chucky1313, cmorris11, Cory2537, Csulli250, damiensdad2, Danpegg007, darren.corbin@gmail.com, Dave, daywalker, DBM, Desertdweller, dieseltech11, Dirty_D, drh4250, dukedrummer89, elevateloren, eyoung, F-250-Owner, feeldman, flashawk, ford4x4guy74, Fordguy26, Frank'daTank, Fuzzman, gatorboy6, ghohouston, giantred, Gibrid4x4, Gilbertthomas, Grey6.0, growntexastuff, gtmustang00, harleytruck3392, have12, IIvonnyII, imthemedic, Iron, jamesmet, JBASS30, JCart, JD F350, JD7210, Jeremy, jford03, jimbo75, jkres, jonF-250, jp115, Jpotts24, Jrn2786, JSOC08, Jsweeney5460, JumpMan92, justind, Kgantz, kilohertz, ksieckmann, kyleson, Little Norway Farms LLC, lorado04, Lowsdime3, lubeowner, lucky's diesel, machinehead, matthewd11, Mhatlen, Mikeysford, muddynoll, mudworld, neoxaero, new2deisel, nillestimothy, NjCj, nrook, OBS F350, oilburner2500, partsandservice, Phil@dieselcore, polish pete, powerstrokedkid87, Powerstrokepentz6.0, powerstrokesmoke04, Powertech, raradcli65, rdunagan, Redline7.3, RescueF250, RJC2, roach, Roush4_6, rswhitcomb, rzrdiesel, SAYIWONT, scenarioL113, ServiceTech, sgriff1249, sho669, sixgo, skeetreecetw, smergen, SmokinBlueOval, Snake, sonnyy13n, SpencerXZX, squad2man, ssduck30, Steve06, stroked99_1/2, Stroker03man, Strokin 35s, Super Duty Dude, teddy's6.0h, teddybear, teo9554, The Gray Mule, Thebigeazy, theGreenHornet, thorguy57, timar, tkey3425, tomek385, Trailboss59, Turbodiesel6.0, turbotom1052, Txlogdog, tyler731, wa96stroke, warrens73, webb06, what a mess, Wheelhop, woodstar168, yakice86
Forum Jump
