No Heat -2002 Excursion 7.3 - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > Power Stroke Excursions
Thread Tools Display Modes
  #1
Old 03-10-2012, 07:40 PM
wayno
Offline
Member's Gallery
Question No Heat -2002 Excursion 7.3
Starts and runs fine. All stock. Temp gage reads normal. No leaks anywhere. Thermostat looks good. Replaced but no change. No heat comes from the vents. Only obvious issue is the coolant tank has raised itself way over normal fill level. Can anyone help ?
Thanks. Wayno
Old 03-11-2012, 12:13 AM
fordman2121
Offline
Jack Ken
Member's Gallery
Re: No Heat -2002 Excursion 7.3
Is the vaccum shut off hooked up? Does your vaccum pump work? Are the heater hoses hot? Start with the basics.
__________________
2003 Exursion 7.3 diesel exhaust, intake, ts chip, banks exhaust housing, big head actuator all sittin on 20s w/ 35s.
1989 F350 460 propane, 4inch lift 39.5s
1988 bronco ii 2.3 turbo motor on propane
  #3
Old 03-11-2012, 12:37 AM
wayno
Offline
Member's Gallery
Thanks. I'll start with those.
  #4
Old 03-11-2012, 12:48 AM
ajfetterman's Avatar
ajfetterman
Offline
Member's Gallery
Are you getting cold air out of the vents or no air? If no fan speeds work, its probably your blower motor resistor. Thats a cheap and quick repair.
__________________
2002 CCLB 4X4 6" skyjacker lift * Ford AIC * 4" turbo back Diamond Eye exhaust * 6637 mod w/ Donaldson filter * Gauges* No Foil * Edge Insight CTS
1988 Camaro Iroc Z
2000 Polaris Scrambler 4x2 400- Bored out and tuned by DAB Racing
~Andy~
  #5
Old 03-11-2012, 12:56 AM
abbottfarms
Offline
Keep er shinny side up!
Member's Gallery
Good question...and good place to start if the answer is no air of any temp out of vents.
(View-All Members who have read this thread : 26
02EXCURSION, 997.3ps, abbottfarms, ajfetterman, BDS, Capricious, chelada, Cutty72, Denver, drew504, fordman2121, ghohouston, Gibrid4x4, Jbolen323, JoJo, Madisdaddy0505, micky_blue, NEVRNF, prostock1, RexLG, richard720, rickvm, steinerr, ToMang07, towsurfer, wayno
You may not post new threads
You may not post replies
Forum Jump
