97 7.3 turns over but will not start. help please!! - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > F-250 & F-350 1986-1997 & Other Ford Trucks > 1994-1997 Power Stroke Technical Info
Register Members List Timeslips Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto EscrowInsurance
Thread Tools Display Modes
  #1
Old 03-05-2012, 03:09 AM
wjjb2010
Offline
Member's Gallery
Hey, new to diesels here, im a great gasser mechanic but im having troubles with my diesel. Back in January i was hauling a repo on a trailer and i pulled over the get diesel and jumped back in and it would not turn over. i checked the starter but the problem was that the starter was hanging down by the main wires for it. I unhooked the stater and taped up the wires and got a pull start from a semi, i drove to the nearest Napa and bought a new starter...$250 later i was back on the road. i made it home from the 12 hour trip and the next day i went out there to start my truck and it didn't start as quick as usual. on my way to work it was cutting out and hesitating when i got on the pedal. on my way home it shut down and would not start back up till it got cold. The next day i changed the IPR o rings cause I was told to try that, it did not help. the hpop reservoir had oil in it, i changed the CPS, ICP, IDM, PCM. tested all the valve cover gasket and the tested good. got a snap on scanner from a friend and it had no codes and passed a buzz test. Then one day it finally decide to run again, it ran for about two weeks but it was running rough. Then the hpop bearings decided to explode and was shooting oil out the back of the pump. So I bought a new hpop for a superduty and a new IPR, new glow plugs, new stancor gpr, fuel pump and i also order new exhaust and down pipe and turbine housing since i got a bundle discount. i tried starting it and it would not even attempt to start. today i bought two new batteries and traded in my starter for a new one, when i tried starting it today it started to smoke out of the exhaust and is trying to start more and more. i am getting a fuel pressure reading of 50 to 60 while cranking it over, i am completely stumped and would like to have my truck running again. any help would be appreciated. thanks
__________________
97 F350 cc, lb, 5spd.
17* hpop
Stancor gpr
1.00 turbine housing
Superchip programmer
Diamond eye turbo back dual 4" exhaust
Glow shift digital gauges
K&N intake
12,000lb Ramsey winch
Air lift air bags
4" lift kit
37x12.50x16 tsl swampers
Old 03-05-2012, 01:56 PM
Cratos's Avatar
Cratos
Offline
Member's Gallery
Re: 97 7.3 turns over but will not start. help please!!
check your fuses on the fender well #22 may be out (fuel heater) thay are known to come a part and short out.
__________________
Blue 2012 XLT SCLB 4X4 , 15,000 miles, 3:55's & 18's Camper and Tow packages. Edge insight, Airlift Wireless compressor & Air Bag set-up, Dieslesite filter kit, ccv mod, deleted :)
  #3
Old 03-05-2012, 02:03 PM
toolmangary's Avatar
toolmangary
Offline
Fixing Broken Stuff
Member's Gallery
^^^ Check that, then see what codes you have, clear the codes you have and then try to start it again and see what codes come back. Then we can go from there.
__________________
1997 F350 4X4 CCLB PSD
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
$ 1 7 , 5 1 4 , 8 2 2 , 6 4 8 , 0 8 7 is our National Dept
The estimated population of the United States is 317,825,127
so each citizen's share of this debt is $55,108.36.
  #4
Old 03-05-2012, 07:05 PM
JFURNER77's Avatar
JFURNER77
Offline
JFURNER77
Member's Gallery
Do you have WTS light? Check fuses & verify GP relay is working.
You may have to purge the air out of HPOP system. Loosen the line going into the head while turning over engine.
Verify the injector solenoids are firing.
__________________
1997 F350 4X4 XLT CREW CAB
7.3L POWERSTOKE DIESEL 355,000
T/S 6 POS CHIP/STAGE 1'S/
17* HPOP
6637 AIR INTAKE/NO CAT
WARN MANUAL HUBS
4R100 STAGE 2 BUILD, RED ALTO'S, TRIPLE DISC BILLET TORQ, TRANSGO-SHIFT KIT
5" SUSPENSION LIFT, STAINLESS NERF-BARS
16X10 PRO COMP 35X12.50 TOYO OPEN COUNTRY A/T II
  #5
Old 03-05-2012, 11:12 PM
wjjb2010
Offline
Member's Gallery
well thanks for the replys but i think it was just air in the system, i kept cranking and cranking and it finally started.
(View-All Members who have read this thread : 57
02-7.3, 1997F350CCLB, 389SixPack, 50cal, 6litrestroker, 89 Stroker, 94powerstroke, 97CCLB410LS, bigblue7.3l, blue99sd, bpb424, bracketracer, Bugman, ccf350stroker, chopper, CLASSICIDI, constF350, Coueshunter, court dukes, Cratos, Falk, farmin97psd, Hoss1997, JFURNER77, jmontes, JoJo, jtsparks2, Justincredible, killforfood, littlejoe, lovesdunes, madpogue, Mudbrother, My95stroker, newadvocate, Obspsd7.3, ODR, old Smokey, outlaw721, Patrick Feeley, Patrolman, pff250hd, PIR8 DIESEL, powersmoker73, powerstroke44241, powerstrokin7.3, PSDEng, rolsmojave3, rwhite1, shaynep, Shovel, splauchs, toolmangary, usramc, wishbone, wjjb2010, xbones
You may not post new threads
You may not post replies
Forum Jump
