6.0 shut off while driving down the road!!! - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 6.0L Power Stroke Technical Info
Thread Tools Display Modes
  #1
Old 02-29-2012, 11:48 PM
doublesrtroker
Offline
Member's Gallery
so it would not idle . Thought it was a fuel problem as i filled it out of my bulk tank in the rain. Added diesel 911 still nothin. drove it home 40 miles it stalled 12 times but started rite back and never missed a beat . Shut it off in the drive way then no restart . Took it to the shop . He said bad cam sensor and a faulty battery. replaced both still lots of codes and wont run . next code was crank sensor. Replaced and nothing. To make a long story short it was the number 8 injector. That was all. No one had ever herd of one injector doing this ?? anyone on here ???
Old 03-01-2012, 12:49 AM
cobrabc1993's Avatar
cobrabc1993
Offline
Member's Gallery
Re: 6.0 shut off while driving down the road!!!
I have seen a lot of 6.0 injectors fail, but not just one that caused it too die. It must have failed severly.
__________________
2006 F250 HarleyDavidson,CCSB, 6.0, Arps, RCD delete, SCT Extreme.
1997 F350,4x4, auto, srw, reg cab, 3.55's, cold air, 4inch exhaust, chip, gauges.(Sold)
1996 F350,4x4, auto, srw, reg cab, 3.55's, bone stock.
(Builder)
  #3
Old 03-01-2012, 12:56 AM
stoker04's Avatar
stoker04
Offline
Member's Gallery
I had an issue two years ago Cylinder 6 Injector circuit low. Truck ran fine never missed a beat. Then took it out a month before Christmas truck cut off and me and nothing. Turned out that cylinder 6 injector back shorted through the ficm took out 5 other injectors, ficm harness, GEM module but never took out the ficm it did fail about 4 months later though. Lesson learned. Should have replaced the injector when it through the code
__________________
2004 F350 6.0 ECSB Lariat. All the normal stuff
  #4
Old 03-01-2012, 04:09 AM
06kingranch37's Avatar
06kingranch37
Offline
Member's Gallery
I also had the same issue in my truck the ipr #### the bed
  #5
Old 03-01-2012, 09:00 PM
lucky's diesel
Offline
Member's Gallery
I have seen the injector harness short on the intake manifold bolts, causes random codes and stalling or no starts strange running concerns, The harness gets sqweezed under the air intake tube from the air filter. When you start taking it apart and moving things around the condition goes away, typical 6.0 wire chaf thing. When this happens it sets dtc,s for cam and crank sensors and sometimes injector circuit codes. Lots of wire chaffing problems on both the injector harness and engine harness in that area by the intake manifold,valvecover, on bank two under the air inlet tube from the air filter. But it sounds like they got it handled just a thought.
  #6
Old 03-03-2012, 12:10 AM
6.0&SN95tagteam's Avatar
6.0&SN95tagteam
Offline
Boost Junkie
Member's Gallery
I'm actually having a similar issue with my 6.0. When the truck is cold, it runs fine; once it has warmed up however, it either shuts off or will act like it's running into a fuel cut at ~1700-2500 rpms... Once it shuts off, it will generally start right back up. Due to my operational schedule at work, I haven't had a whole lot of time to look at it and troubleshoot, so advice on where to start looking would be appreciated.
  #7
Old 03-03-2012, 05:17 PM
treetechsixOH's Avatar
treetechsixOH
Offline
Certified Engine Destroye
Member's Gallery
Egr valve,icp,Ficm,injectors.
__________________
___________________________________
03 CCSB Lariat 350 SRW
Built by me @ Outlaw Diesel Performance
Warren/K&N/Deleted/Exhaust, few other goodies.
Studs, SCT, Nitrous Express, ODP RR, Custom Fuel waiting for install.
  #8
Old 03-03-2012, 06:36 PM
jmyrkle
Offline
Jboy
Member's Gallery
Mine was doing the exact same thing. Twas throwing all sorts of injector codes. Turns out the ficm was bad. Changed it out and all the injector codes went away.
Sent from my DROID BIONIC using AutoGuide.com App
  #9
Old 03-04-2012, 12:32 PM
6.0&SN95tagteam
Offline
Boost Junkie
Member's Gallery
Wouldn't the FICM/injectors being bad throw codes? As it stands right now I'm not getting any codes...
__________________
2004 F250 CC 6.0 4x4
Intake, 4 in turbo back, deleted, studded, SRL+ by Matt @ Gearhead
  #10
Old 03-04-2012, 08:08 PM
treetechsixOH
Offline
Member's Gallery
Depends on what you mean when you say codes. When mine went bad I never had a check engine light and with a basic scanner no codes came up. With a Ford scanner it was tossing several different injector codes.
(View-All Members who have read this thread : 138
!!!PainTrain!!!, 03f250fx4, 03_7.3POWER, 04 stroker, 06 f250 man, 06kingranch37, 1993250, 19_A_LT, 2006powerleaker, 6.0&SN95tagteam, 6.0lover/hater, 6liternole, 86F250, amdriven2liv, Arctic Fox, armalite, austin229, Austinfqt, Bald Beaver, Big Bri andSam, bismic1, BoskyTrees, cadwell08, cfd f-350, Charles Heald, chrissythesissy, cmoerg, cobrabc1993, cook03F250, cornbread, Cory2537, Currey, Daniel Richeson, Dantheman, Dave, daywalker, DBM, deathwishracer, dominic600, doublesrtroker, DrewGerhan, drmtnbk, droflakcin, eviljarv, f250brah, farmall_560m, Fluff, fordboy11, Fordfreak4life, FTREE50, Fursty, fuzzys69, gtmustang00, Harley Strokin', huck2080, Ian123, Ignorant1, indiana lineman, itzdylan24, J HO 22, jammin60, JBASS30, JD F350, jeremy.ball3, joe_r_dog, johnblade, kbradke, klinker010, Krisco, kyle882, Liddy, liftedsilver250, louisvanwilker, lubeowner, lucky's diesel, mattscoke, Matt_f350, Mega5150, mgeistman, Michigan XLT F350, middlemanjw, mjcolemn, mmm635, Mudbug1979, muddy650, mudworld, mx185sw, mxximus5, nitrogen, nitroteam, northid710, oh-ate6.4PSD, oilburner2500, OregonPlumber'05 6.0, patrickke, plumber dave, Powerstroke08, powerstrokeracing, powerstrokin7.3, PPE'dPowerStroke, PSD2190, PSDOWNER, Realdealoo8, redhors66, RNally, roberth58, rockinamullet, Rocky mountain stroke, Rustymx11, SaNnDnSurF, Sanspeur, SDER1, Shouldagota7.3, Six Liter, Skin, SmokinSD350, snoracerx, sonnyy13n, Sparkymichigan, stoker04, Stroker03man, StrokerSmoker01, superdooty89, SureShot88, SwampEdition7.3, tgaliger, TheReelMuhcoy, toverbey21, treetechsixOH, Turbodiesel6.0, vista461, Warsteiner, wberry85, webb06, wheelnrock, you smoke, Zmann
You may not post new threads
You may not post replies
Forum Jump
