p0470 Code on 95 F350 - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > F-250 & F-350 1986-1997 & Other Ford Trucks > 1994-1997 Power Stroke Technical Info
Thread Tools Display Modes
  #1
Old 02-24-2012, 01:54 AM
coyconner1983
Offline
Member's Gallery
The truck has been running great until today... I went to work and went out to the truck and fired it up and it was running good, then all of a sudden it was having a real rough idle and the cel was on.. Sat there for about 4 or 5 mins and then all of a sudden the engine light went off and it started running great again.. Drove it about 15 miles shut it off, refired and idled good for about 5 secs then cel light and rough again.. 5 mins later cel is off and truck ran fine back to work.. (The check engine light goes off and right when it goes off the truck runs great. the second the cel comes on the truck runs like crap). Does this sound familar?
Error code p0470
Thanks
Old 02-24-2012, 02:34 AM
zilla68's Avatar
zilla68
Offline
Member's Gallery
Re: p0470 Code on 95 F350
p0470 exhaust pressure sensor circuit malfunction, biased sensor, open signal return
__________________
Chris
Moore, Oklahoma
1996 Ford F350 4x4 Crew Cab PSD
6637 tymar
285-75-16 BFG All Terrains/Weld Wheels
3:55 gears
Automatic with billet convertor, tugger and alto discs
New Gearhead Tunes:
1 heavy tow
2 stealth mode
3 tow/econ
4 street perf
5 all out
6 high idle
1.0 housing
exhaust
  #3
Old 02-24-2012, 03:44 AM
Patrick Feeley's Avatar
Patrick Feeley
Offline
Member's Gallery
Probably won't be all that helpful, but here's the pinpoint tests for that code (may provide some insight). They differ for the KOEO (H1 and H2) and continuous (starts at H3) versions of the codes.
H1 DIAGNOSTIC TROUBLE CODE (DTC) 0470
DTC 0470 indicates an EBP sensor malfunction was detected during KOEO On-Demand Self Test.
Possible causes:
-- Faulty EBP sensor
-- Open signal ground
-- Faulty PCM
NGS Tester installed. Key on/Engine off. Select EBP Pid from the PID/DATA monitor menu on NGS Tester. Is EBP reading below 18.5 psi?
Yes: CLEAR DTC and RERUN KOEO On-Demand Self Test. If code is still present, REPLACE PCM.
No: GO to H2.
H2 SIGNAL GROUND CIRCUIT CHECK
Key off. Disconnect EBP sensor connector. Inspect for loose, damaged or pushed out pins. Repair as necessary.
Measure resistance from Pin A [Circuit 359 (GY/R)] to chassis ground.
Is resistance less than 5 ohms?
Yes: REPLACE EBP sensor. CLEAR DTCs and RETEST.
No: REPAIR open in signal return Circuit 359 (GY/R). CLEAR DTC and RETEST.
H3 CONTINUOUS DIAGNOSTIC TROUBLE CODE (DTC) 0470
Continuous DTC 0470 indicates an exhaust back pressure malfunction was detected during normal driving conditions.
Possible causes:
-- Faulty connection
-- Faulty PCM
NGS Tester installed. Select EBP Pid from the PID/DATA monitor menu on the NGS Tester. Observe the PID while performing the following:
-- Grasp the vehicle harness close to the EBP sensor connector, wiggle, shake the vehicle harness while working towards the PCM.
Does the EBP reading fluctuate?
Yes: ISOLATE intermittent connection problem. CLEAR DTCs and RETEST.
No: GO to H4.
H4 CONNECTOR INSPECTION
Disconnect EBP sensor connector. Inspect connector terminals and sensor terminals for signs of poor connection or corrosion. Inspect connections at the 42-way and PCM connectors.
Are all connections good?
Yes: Unable to verify problem at this time. CLEAR DTCs.
No: REPAIR connection concern as required.
Cheers!
__________________
  #4
Old 02-25-2012, 03:14 AM
coyconner1983
Offline
Member's Gallery
I have more symptoms since i had time to mess with it today... Real rough idle,engine has a different tone to it,no boost while reving up, egts running around 4 to 500 degress at idle,when i turn the truck off it sound like a airplane.. I looked for the sensor to unplug it and i cannot for the life of me find it. Can someone please post a pick of it on a OBS.
Thanks guys
  #5
Old 02-25-2012, 06:06 AM
bracketracer's Avatar
bracketracer
Offline
Member's Gallery
Welcome to guzzle's Exhaust Backpressure Sensor Cleaning Maintenance Web Page
Scroll down the page a bit.
Stephen
__________________
Newest project: 1995 F350 CC/DRW 2WD E4OD. 3" DP, 4" Diamond Eye system. But I'm still fixin' the broken stuff......
  #6
Old 02-25-2012, 02:25 PM
hendricksbus's Avatar
hendricksbus
Offline
Member's Gallery
you will only make boost under load. it's normal not see any boost by just reving it up..
__________________
1996 F-250,Ext.cab,LB,4x4
stock tires
180K,6 pos chip,Open air filter, 3'' down pipe,fpr mod,ccv mod
4.10s gears!
Boost, Pryo and transmission gauges
sonnax shift improver kit
bronco tank mod
hayden cooler for transmission
  #7
Old 02-25-2012, 02:30 PM
coyconner1983
Offline
Member's Gallery
Originally Posted by bracketracer View Post
since mine is a 95 is the sensor in the same spot?.. Thats where i looked yesterday and dont see it.. Do i need to pull the black plastic cover off to be able to see the sensor?
  #8
Old 02-25-2012, 05:07 PM
screamnstroker's Avatar
screamnstroker
Offline
Member's Gallery
Yes, Pull the cover off (if your talking the black shroud). it will be in the same spot as on the website
__________________
1996 F250 ECLB- Dana 60 swap, Intake system, 3 inch downpipe-4inch diamond eye, ts 6 pos with php tunes, Gauges- Pyro,trans,boost...scan gauge on the column, built e4od with all the goodies
  #9
Old 02-26-2012, 12:30 AM
coyconner1983
Offline
Member's Gallery
Well i think i found the sensor.. i unplugged it and started the truck and didnt help it at all.. Do i need to erase the codes then try it again? The truck is at work and i want to get it home so thats why i am trying the easy stuff first. Since its still doing it then im guessing the sensor is good and maybe the pipe is clogged?
  #10
Old 02-26-2012, 02:51 PM
coyconner1983
Offline
Member's Gallery
i came back up this morning to work and disconnected the sensor and cleared the codes and now it will start for about 2 seconds and shut back off. no throttle response what so ever. I was able to pull a second code and it was p0472. I data streamed the ebps and it stayed around 22.1. that was with the truck off and with it running for the few seconds it did. what does the 22.1 mean? is it good or bad?
(View-All Members who have read this thread : 95
'94IDITurbo7.3, 02-jeeper, 19stroker97, 1SLO GT, 7.3L F-250, 7.3psd1999, 95F250, 96Crewcab7.3, 97CCLB410LS, 97obspsd, bentpushrod, Bergy1, billmoody1, black7.3, blageurt, bpa658, bracketracer, Bradbilt, Brandonwilk10, Brockbit, buckingbrutus, Bugman, Carlosf, Cass, ccf350stroker, ccsc, cmt9399, co04cobra, cobrabc1993, countryboyz04, coyconner1983, cthom388, dalejrfan88, Dan V, danielzink, DEEREPULLER, Dieselpop, DNSPSD, eric96obs, f250towrig, F350 FF, farmer09, floridastroke, foxman, freddie, friskyjake, glovemeister, Griffin, hendricksbus, idahojunker, JD3020, jess, JHartley, Jim g, jjdup, JMWRIGHT335, josh_mangan, jsterli1, jven6.0, KADEH, Kevinwatts, Kgaeta92, lincolnlocker, Litnng, loudmouth, mandkole, maxlf311, mcreed90, Mini-Stroke..., morefuel, muddynoll, MustangMatt96GT, oneton, OUTLAW101, Patrick Feeley, pff250hd, portlandareae28, POwerstroke Named BIG D, POWERSTROKE2311, prostock1, Rkidd121209, Robjesup88, Roenicke95stroker, Sciulli, screamnstroker, smokinford07, The Oiler, tjul1128, u.f.o., VaEx, wadeclinton, wannabstrokin, wildbillcody97, young95stroker, zilla68
You may not post new threads
You may not post replies
Forum Jump
