| Register | Members List | Timeslips | Calendar | Sponsors | Becoming a Sponsor | Mark Forums Read | Auto Escrow | Auto Loans | Insurance |
Thread Tools | Display Modes |
#1
7.3 main seal an oil pan leak. how do i fix?
hey i got a 1999.5 7.3 powerstroke an its leaking alot from the front main seal. how do i fix this? some say i have to pull the motor to do the pan an flip it over an some say i dont. an whats it take to change the front main seal? its in a 1979 f-250 with a big lift so theres lots of room under neath an in front. anything helps, thanks alot!
| Sponsored Links | |
Advertisement |
#2
Re: 7.3 main seal an oil pan leak. how do i fix?
Are you 100% sure the leak isnt from uptop in the valley? Or to the cover to unbolt the gear to the hpop?
#3
Just seen this after I pm'd you.
![]() I had a front main leak in about 05'. If you replace the pan, you do have to pull the motor on a super duty, not sure about your set up. However, a local machanic talked me into letting him try injecting rtv into the area of my leak. Not sure how he did it and he rebuilt the oil cooler in the process and it only seeped a bit after that but didn't drip for 6 years prior to my rebuild.
__________________
REBORN 20 Over on 3/2/11- Pics in gallery- 2000 F250, Auto, 38r, Full Force 238cc/100%, TE 17* hpop, DP F5,HI,60T,80E,120R,140A, Studs and 910's with DI PR's, JW VB, Walbro 392, Bellowed, In-Tank, Pre-Pump, boost fooler, and RR. Air Dog, SS cover, 6.0 TOC,4" straight piped and guages, 6637, coolant filter, 4" Lift on 33's. |
#4
yea its not from the valley, its main seal u can watch it drip down
#5
whats the labor like to change the main seal? big job or something i can could do in my garage? heard a lot of diff things from people
#6
Pull harmonic ballancer pry seal out of front lpop and be carefull the lpop is aluminum and will crack.A new pump is 65.00 at advance auto parts, if you have to replace it. It is about a 1-2 hour job.
#7
Good time to swap to a melling or if your pockets are deep dieselsites new I have a dream of if I have to go after something like that of doing a fluid damper, and melling ..but my wallet say right now oil is cheaper ![]() Tg mine is not leaking
__________________
early 99 f350 4x4 crew cab, auto. Diy Twin tymar, TS chip, Powerslot rotors & Hawk pads, ford AIC, pmt2 pcm ..... with big fat want to list. |
#8
ohh alrighty thanks alot! any special tools ill need or anything to watch out for?
#9
I FIRST find out what is leaking, the front main OR the pan,
If it is just the front main, do yourself a favor and buy the melling improved Lo-pressure oil pump and throw that on(new main seal is included). It takes about an hour to do. The HARDEST part is getting the puller in there to pull the harmonic balancer
__________________
I am probably the most hated person on here, and I don't care 97 CCSB 4WD DRW 7.3 5spd DP Tuner, 6637, Flo-Pro SS Exhaust, 99 I/C, T500, Autometer gauges, Valair Organic clutch, PFM 2.25" RSK, SD springs Front/rear 315/75/16s,
Bunch of other trucks |
#10
no you dont need no special tools, except a harmonic ballancer puller. a melling oil pump is 79.99 at advance auto parts and the front seal is 9.95 good luck
| Thread Tools | |
| Display Modes | |
