BW S366 Turbo Specs? - PowerStrokeNation : Ford Powerstroke Diesel Forum
Thread Tools Display Modes
  #1
Old 02-14-2012, 03:53 AM
ToMang07's Avatar
ToMang07
Offline
Member's Gallery
Anyone have a full spec list for the S366?
Curious whats the max HP you can comfortably push with it.
__________________
~Tom~ 02 F350 CCSB 4x4 SRW 7.3L, DIY-6637, PHP Phoenix-(STK-80dd-100P-120R-65T-40T) 4" TB-409SS MBRP, GS 3 in 1, EGT/Boost/Tranny, Fisher 8' MM2. Tymar HPX, NON-EBV Pedestal, Turbo Master, Wicked Wheel, Hutch/Harpoon, RR-Plenums/clamps, 203*TS and Billet Housing, ELC, Fumoto, CCV Dumped, Foil, AIH, and EBV, Pontoons All Missing...~AE w/Ford Pack~
Old 05-22-2012, 04:05 AM
dentexpowerstroke's Avatar
dentexpowerstroke
Offline
Member's Gallery
Re: BW S366 Turbo Specs?
Bump. Curious about this too.
__________________
01 f250 ccsb 4x4 pushing the limits of pmrs, but that's all about to change.
  #3
Old 05-23-2012, 02:20 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Offline
Subject Matter Expert
Member's Gallery
Gotta love google.
Wheel Dimensions:
•Compressor: 66 mm inducer / 91.4mm exducer, with exclusive Extended Tip Technology. 82lb/min
•Turbine: 80 mm inducer / 73 mm exducer. Cast in Inconel 713 for high-temperature operation.
Housings:
•Compressor: Large 4.00" ported anti-surge air inlet / 3.00" charge pipe outlet
•Turbine: .91 A/R Twin Scroll, with 'T4-style', divided entry, and 4.21" v-band discharge.
Just enough air for 525-550hp on a 7.3 engine depending on how over-fueled you want to run the turbo.. Relatively large displacement compared to other performance diesel engines means more exhaust flow and you'll be overspinning the turbo and consuming more air than it can produce efficiently compared to some of the smaller displacement diesels that can make several hundred HP more on the same exact turbo.
__________________
Stock
(View-All Members who have read this thread : 56
004wdPSD, 19stroker97, 444-4D, 7.3L F-250, 92f350cc, 97250HD, bikit, Blowby, boostaddict, brleggettjr, Bushwakd, ccmac, cj45lc, cjfarm11, dentexpowerstroke, dieselman9773, E99Superduty, farm boy, fishindude, Fl Stroker, Ford Crazy, g2shuck, Garbage_Mechanic, hwrdbd, IBESTROKEN, IHPowerstroke7.3, isootmypants, jeremiahmercier, JHill, Kampy, mandkole, MidwestOBS, MOTO7.3, newmexicocrawler, Nodge, NorCalDiesel, OBSWIZ, oldbluef250, pooter, powerjoker97, PowerstrokeJunkie, purplepstroke, pwrstrk01, ryanss22, sideswipe7, supersize, swaan, SWVa, t.r.p., TBarrsTruck, theSLEEPER, ToMang07, ttford07, UNDER PRESSURE, vtine523, wise guy
You may not post new threads
You may not post replies
Forum Jump
