P0611 code ? - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 6.0L Power Stroke Technical Info
Register Members List Timeslips Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto EscrowInsurance
Thread Tools Display Modes
  #1
Old 02-12-2012, 03:30 AM
Diesel X's Avatar
Diesel X
Offline
Learning from PSN
Member's Gallery
P0611 code ?
Father in law has a '04 Excursion that pulled a P0611 code today. Hooked up Auto Enginity today because he said it was acting up. Basically it sounds like it going to shut off and does it a couple of times real qiuk. then stops. Sounds like the injectors stop working. The rpm's don't change when this happens. He said it has been doing this for awhile now. The code is for the fuel injection control module. If it is bad should it not work at all? Where is it located on the truck? How much does a new cost? Is this a dealer only part? I know it is alot of questions ,but he is going on a trip next week and I'm helping with a few things to get it ready for the trip.
__________________
94.5 CCLB 5 speed broke again E99 CCLB 4x4 6 speed MBRP 4" straight turbo back 6637 6" lift Southbend way too small Nitto 265 tires a.k.a Grugly 04 Excursion Limited
Old 02-12-2012, 04:56 AM
2 Stroker
Offline
Member's Gallery
Re: P0611 code ?
P0611 FICM Fuel injector control module performance Internal FICM failure
This is caused from weak or bad batteries must get new ones or have them fully charged then load tested if over 3-4years old get new ones also heat kills the ficm it sets in a bad place for heat.
The price of a new ficm around $1100 or you can have your rebuilt at BPD Repair Ford FICM Module for $300
or--- FICM Repair.com - Your Source for FICM Repair (my pick) or here
6.0 DIESEL POWERSTROKE FORD FUEL INJECTOR CONTROL MODULE FICM F250-550 ECONOLINE | eBay
Info here http://www.fordtechservice.dealercon...FICM_Guide.pdf
and here http://swampsdiesel.com/site/install...ge_Testing.pdf
Testing the FICM
I hard wired a Battery Tender Plus into the passerengerside battery had to get new nuts and bolts because the stock ones get screwed up removing then when it set for a long time i just plug it in they come with 2 sets one a clip and the other to hard wire then i just set it up by the AC unit plug in close the hood, keeps them charged at 100% all the time when it sets.
***12 VOLT BATTERY TENDER PLUS BRAND NEW STOCK 220128* | eBay
2 stroker
__________________
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS-Expandable Pyro
AutoMeter Fuel Pressure Gauge
Fuel Reg. Kit 3C3Z-9T517-AG
Amsoil By-Pass(Amsoil 5w40)
Delo ELC-coolant Filter
pulling 14,000 lb Alpenlite 5er
97 F350 4x4 PSD CC LB
PacBrake&ATS converter lockup
3" dp 4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
EGT,Boost,Trans
  #3
Old 02-12-2012, 05:17 AM
CALADASH's Avatar
CALADASH
Offline
Member's Gallery
Re: P0611 code ?
Had many six liters come in the shop with bad ficms. I have personally used FICMrepair.com with great results and all trucks still running flawlessly. 195 for the repair with 45 day warranty. Price goes up for longer warranty. A new FICM is 453 from a non sponsor. That's an oem FICM as well. Pm me if you would like the link.
__________________
2002 F-250 Lariat
Im Dan,my tranny hates me no more!!"
AFE Stage 2
Power Hungry Perfomance Custom 6 Pos chip
Suncoast tranny
Isspro Boost,Tranny and EGT
H2E
Air Dog 150
Adrenaline HPOP
6.0L Tranny Cooler
FS-2500
Fluidampr
  #4
Old 02-12-2012, 11:59 AM
Diesel X's Avatar
Diesel X
Offline
Learning from PSN
Member's Gallery
Re: P0611 code ?
If the FICM is bad would it act this way randomly? Doesn't look to bad in the video to get at. Also the batteries are fairly new, but the truck sits alot. I think he has a battery charger that you can load test with. It only has around 75000 mile on it. Hell he just put new tires on it this week and that was because they where getting dry rotted. Still looked like it had good tread left on the stock tires.
  #5
Old 02-12-2012, 03:40 PM
Dave's Avatar
Dave
Offline
FNG
Member's Gallery
Exclamation Re: P0611 code ?
Its the FICM. If you dont replace it it WILL strand you.
__________________
Dave G
06 F250 Lariat 4x4 leveled on 35s
4 inch flowmaster exhaust
Bulletproof diesel egr delete.
Bulletproof diesel FICM
Performance Machine & Manufacturing Coolant Filter Kit
ECM and FICM tuned by Bill at PHP SCT tunes from Gearhead, Innovative and Wildman
  #6
Old 02-12-2012, 11:05 PM
uga33's Avatar
uga33
Offline
Member's Gallery
Re: P0611 code ?
It will act up randomly and like mentioned above its going to leave him stranded. I got 0611 codes for six months before mine bit the dust. My price for a half shell at ford is 395 bucks.
__________________
2009 F-250 CC/SB 4x4 King Ranch*Spartan Tuning*5" Downpipe back Exhaust*aFe Stage 2 Pro5R Intake
  #7
Old 02-13-2012, 02:22 AM
Diesel X's Avatar
Diesel X
Offline
Learning from PSN
Member's Gallery
Re: P0611 code ?
Pm sent.
  #8
Old 02-13-2012, 08:26 AM
bismic1
Offline
Member's Gallery
Re: P0611 code ?
Simple issue - send to FICMrepair.com, a few days later you will have no issues.
Good work, reasonable price.
__________________
Mark
06 F250 CC SB FX4 Lariat;ARPs OEM gaskets;Banks exhaust;DynaTrac Balljoints;RACCCV6000;Updated HPOP fitting;JimmiJammers;Ravelco;plugs&standpipes;Fumo to;Harpooned;Quadzilla XZT Fuel Press;Blue spring;DashDAQ;PHP_FICM; RiffRaff boots;DCPower250A w/ Inverter;Rancho7000's;BPD EGR cooler;BPD WaterPump;SCT Matts SRL+;ELC Ultra w/ filter;SynchroMax
(View-All Members who have read this thread : 74
03F250 6.0, 04 f350, 05P-stroke, 06 f250 man, 2 Stroker, 6.0.downlow, 96Tangerine, amdriven2liv, bgyllw, BigRedSCEdition, bigstrap3, Big_T, bismic1, bootcamp, brute_mt, bryan.d, CALADASH, cfd f-350, chevyboy123, Csulli250, Dallas, Dave, dave0642, Diesel X, elwood blooz, Falls250, fedxairmech, Fox'sFord, From384, Gibrid4x4, hawgdoctor, hhrecovery, horsehauler, indiana lineman, jamcconnell2, JBASS30, JD F350, jd75760, jjlw, ktmrydr686, lightning666, Low Key, Mcfly89, mjcolemn, Moosefps, mours2, MT Pockets, muddynoll, Mustangl3, nelsonar, NH OIL BURNER, nrook, pa-powerstroke, power-smoke, pyro6999, Realdealoo8, renegade, roughneck0913, Shef, silent64, SKEETERMAN03, srwdoug, steelfinattic, STRAIGHTSTROKEN04, svilla, The Fabricator, treetechsixOH, turboculosis, txffemt, uga33, webb06, whit957, wynndaddy, Zmann
You may not post new threads
You may not post replies
Forum Jump
