cure for p0107 - PowerStrokeNation : Ford Powerstroke Diesel Forum
Thread Tools Display Modes
  #1
Old 07-08-2008, 09:32 PM
bork
Offline
Member's Gallery
cure for p0107
SES keeps coming on even before I start engine.KOEO. P0107 = manifold absolute pressure/barrometer pressure circuit low input. How do I correct this? Is there a sensor to change out?
__________________
1999E350 7.3psd, XLT, 15 pass/ext, purchased 6/05 w/255k mi, BTM/straight pipe,5/06 BTS,1"shimmed front coil springs,MichXPS 235/85 16 R,FredGroeske2"RearWheelSpacers,1.5" rear swaybar,AIC,3 pillar guages, Tekonsha Envoy,coolant filter,4pos DPtuner,In-tank mod & pooned,dahl-100 prepumpfilter,Scanguage,Bilstein shocks, rear R&R 280K +new tracloc
Old 07-09-2008, 12:49 AM
kainers's Avatar
kainers
Offline
Starting Over
Member's Gallery
Re: cure for p0107
the Baro is part of the PCM as far as I know.The map is a sensor in the engine compartment on the passanger side .You can fallow a 1/4 hose off the Y pipe to it.You can try unplugging it or checking for wire chafe.On a van I have no idea if they are in the same locations.
  #3
Old 07-09-2008, 01:12 AM
DIRTBIKEZ
Offline
Member's Gallery
Re: cure for p0107
In the early superdutys the baro was separate from the PCM, if its anything like the truck I believe it was located up above the go pedal.
**If your van was built before 12/7/98 the baro is actually seperate.
__________________
1999 F350 6SPD 4x4 LARIAT Tymar, DP-F5, ITP Reg Return, 4" Exhaust **SOLD**
2002 F350 REG CAB DRW 2WD Tymar, PHP, 5" stack, DJM drop hangers and shackles, Hellwig sway bars, Nathan K5LA, Full Power '08 Mirrors...**SOLD**
  #4
Old 07-09-2008, 11:08 AM
bork
Offline
Member's Gallery
Re: cure for p0107
Hmmmm? Should I call my local parts guy and ask for a barrometer sender? There is a 3 pinned connector with a a small box on it, similar to a turn siganal flasher, under right side of steering column, under dash.
  #5
Old 07-09-2008, 11:25 PM
DIRTBIKEZ
Offline
Member's Gallery
Re: cure for p0107
Yeah, 3 wires. Might be dark blue/light green, brown/white and gray/red.
  #6
Old 07-10-2008, 11:18 AM
bork
Offline
Member's Gallery
Re: cure for p0107
Yup, the thingy under dash, had part #'s & ford send it was a barro sensor. Originally I asked for the sensor & they couldn't find it listed. Thank heaven for the #s. over a $100 for the little thing. got it though, plugged it in & cleared codes & so far no SES . Advance auto could get part in 2 days for around $70.00. (borg/warner) would you guys trust these over oem? I hated to wait any longer, cause everyonce in a while I get a noisey rattle for a few seconds. injectors? then SES would come on. I hope this barro fixes this also.
  #7
Old 07-10-2008, 11:50 PM
DIRTBIKEZ
Offline
Member's Gallery
Re: cure for p0107
Cool, hope that was it.
  #8
Old 07-11-2008, 03:15 AM
bork
Offline
Member's Gallery
Re: cure for p0107
Update, drove it about 250 miles & ran good. No woodpecker sounding injectors. & no SES. And almost seems to have better milage, 1-2, according to scanguage #s. But more time will tell. Or maybe I got a good batch of fuel. (added 3/4 fillup) Also, 1st time I used the AE, & appears I have saved on repairs or kept stealership from botching it up for $1k more.
  #9
Old 07-14-2008, 08:58 PM
solareclpse2000's Avatar
solareclpse2000
Offline
Solareclpse
Member's Gallery
Send a message via Yahoo to solareclpse2000
Re: cure for p0107
ok so what if your trucks pops a 0107 and 0108 at the same time?
__________________
2002 F250 crew cab, short bed, 7.3, 4x4, auto,8.5 procomp lift/37 in. tires.
needs new badges and paint,
it's a 7.3 PSD.what more can i say? does anyone have any extra parts they need to get rid of?
  #10
Old 07-15-2008, 12:22 PM
bork
Offline
Member's Gallery
Re: cure for p0107
I dont know? I'm glad mine was seperate from the PCM, & was able to plug & play. I just wished there was a friend with same vehicle to swap parts & try befor purchasing a new part, especially the ($100 +) non returnable electrical ones. I did find at Advance auto parts, a borg/warner barro sensor for around $65,but I'd have to wait 2 days. IIRC (but I was going on a trip next am & couldn't wait.) Is yours in PCM? Do you have access to another PCM? to try?
(View-All Members who have read this thread : 74
20X, 250turbo, 777mechanic, 90ranajo, adamsryan, Arisley, Barnbuilder, bigdjvp, Bignbadbelair, BMac, bork, Brian Cox, Calico5, chevyhurstolds84, chunkdunker, Clouse2411, CooterBrown, Dantheman, dblamp, DIRTBIKEZ, ditch_dawg, Doakster, e444, Eford00, Fddriver2, fordboy424, GCncsuHD, Haul_n_horses2, JLDickmon, jlegg, josesimoes2, Juniorssrollin, Justin@DP-Tuner, kainers, kampinguru, KRUISECONTROL, Logan21SV, madmaxz, Madvan, Matikus, MATREDGT, matthewd11, mattr66, mattrac, mazdaparts, medicman88, Millerfarms, Mr. Bob, MudSouth, mustang_gt_350, Nodge, NWSUPRD, Ramblin'_Man, redmist, rideracelivemx7, Ripsaw, riverjet, Rogue1970, Roots, Rustler, SeeYa, sixiron, solareclpse2000, steck, tank23, thedudebrah, theSLEEPER, tkdbf350, treyloco, txoutlaw, Willy
You may not post new threads
You may not post replies
Forum Jump
