Steering Gear box adjustment - PowerStrokeNation : Ford Powerstroke Diesel Forum
Register Members List Timeslips Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto EscrowInsurance
Thread Tools Display Modes
  #1
Old 02-04-2012, 01:51 AM
Moroney167's Avatar
Moroney167
Offline
Fasthog.com
Member's Gallery
Send a message via Yahoo to Moroney167
I have searched all I could but was told there's a way to adjust steering mesh a little tighter. Truck drives great just has a little wonder and slop between steering wheel an the ground.
Told a lock nut and an Allen key on gear box, hold Allen while loosen lock not. Tighten a small amount going to much will do damage. So what's to much. Can I do a 1/4 turn an test drive? Any help please
Sent from my Autoguide iPad app
__________________
Jim
'08 F-250 CCSB
S&B - Spartan - 5" - 4.5 Icon
PMF 3-Link & Traction Bars- 20x10 ATX - 37" ATZ P3's
Reply With Quote Quick reply to this message Go to the top
Old 02-04-2012, 02:08 AM
eleventhtruck's Avatar
eleventhtruck
Offline
My other twin turbo...
Member's Gallery
Re: Steering Gear box adjustment
I would go 1/8 at a time and test. This adjustment is very sensitive and if the sector is too worn you will still have play in the steering box even as the sector starts hanging up. You say play between the steering wheel and the ground? I usually, if I don't have help, start the vehicle and rock the input shaft at the gear while I observe the box and linkage to find the loose detail.
  #3
Old 02-04-2012, 02:16 AM
Moroney167's Avatar
Moroney167
Offline
Fasthog.com
Member's Gallery
Well I typed that wrong. Basically when driving you keep working on moving wheel to avoid wonder an keeping straight. I will try small turn like you said on it and see if anything changes. After adjusting two times at 1/8 turns I'll be sure to stop if it's not better or changing.
If you do not want to register, fill this field only and the name will be used as user name for your post.
Human Verification
(View-All Members who have read this thread : 97
03Excursion, 07-OUTLAW, 1954oldred, 1badz, 2ndHandSmoke, 96PSD, 97stroking1982, 99fordman18, 99whitePSD, Alvapowerchoke, austin229, Baker82, bigblocktisdale, bigpete73, BigRed97, Blown284, Bow-TechAggie, BucktownPSD, coxral, cutterstroke, Cutty72, dan_k, davidamontoya, dblamp, dieselboy01, DieselRangerKid, Driles85, Dustin F2504x4, duxpsd, eleventhtruck, ElkBowHuntR, Evofit300, famlyride, firedriver19, Fl Stroker, flocksmonster garage, FordPower, fourwheeldrive9, Frenchb85, gsxr1216, HARDTIMES, harperc, hoist00, houtxfdcapt, impostor, jammin60, jaybuller, Jmjohnson1717, Jorobe33, Josh_pesty, Kampy, kilapapipa, kystanger, Loonatic, MacDinho, machete31, Monumentally, Moroney167, MrNiceGuy, NEBR99.5 OIL BURNER, niklid05, nopainnofear, NorCalDiesel, northid710, ntgd1, NVJAY775, Old OutLaw, OLD'SCOOL, parnellz, PDR Diesel Inc, PowerstrokeMudder82, PSDTDIer4life, pursleybp, redpowerstroke, REDSTROKE188, rfrostick, rodrocket, rolsmojave3, rusty1161, Sandpro, scottKP99, snakedoc, Sndwrkr, sparksmx450, steve burris, strokerdually, sujumptd, super73, SUPERDF350, superm, sxcross, toddman35, vintage way, WA_PSD, wickedx, xxxbrutusxxx, yancey01x
Forum Jump
