Hard start...ICP issue - PowerStrokeNation : Ford Powerstroke Diesel Forum
Thread Tools Display Modes
  #1
Old 01-17-2012, 03:47 AM
95powersmoker's Avatar
95powersmoker
Offline
Member's Gallery
Ok finally had some time to spend some time with the superduty and AE today. I figured out why my truck cranks for a 5-10 seconds before starting every time... ICP is slow to build pressure and takes forever to climb to over 500 psi.. Once the truck is started, the ICP is erratic, 600-800psi. Then once the truck is warmed up, the ICP stays pretty steady at 500ish psi. I'm not sure why but the truck was really sluggish and I couldn't get it to do over 50 mph. The DC never went above 32% or so. The ICP sensor is oily. Should I take the IPR out and clean it? Is there a way to rule ICP sensor vs IPR or even HPOP as the culprit? I did an injector buzz test and they all sounded the same even though it came up with a high side open - bank 2 code.
Some info on the truck, 6 speed, 144k miles, stock.
__________________
James
1995 F-250 Powerstroke, auto, 4x4
Gauges, Tymar Intake, 3" dp to 4" exhaust
Old 01-17-2012, 04:58 AM
TerminatorEngineering's Avatar
Offline
Sponsor
Member's Gallery
Re: Hard start...ICP issue
James, replace your ICP sensor first. Leaky sensor can cause issues.
__________________
Visit us at: www.TerminatorEngineering.com for all your Big Oil needs.
SDRCM #7
  #3
Old 01-17-2012, 05:02 PM
95powersmoker
Offline
Member's Gallery
Thanks joey. I will put that on the list.
  #4
Old 01-18-2012, 07:27 PM
95powersmoker
Offline
Member's Gallery
Joey, Could the ICP sensor be causing all the things I posted in my first post? All I want is this truck to do is start everytime and run good. However, when I tried to hammer down in 3/4 gear, I couldn't get it over 50mph. That was pedal to the floor, but no SES. I realize the oil in the sensor could mean it is compromised but ICP does settle in once the truck is warmed up.
(View-All Members who have read this thread : 49
04popo700, 1BadF350, 1badz, 6.9turbocharged, 95powersmoker, aviatorkev, BIGLARRYS03, BigWhite97, birdog, Brian918, chainsaw, clydesdale, colbev57, curb guy, DieselBrad, Dieselpop, double-s-diesel, DRD, Fl Stroker, Ford Crazy, jamisgood, juvenile9, kilapapipa, mattatk81, Mekanik, middlemanjw, mikedb6690, Mikes01f350, niklid05, Old OutLaw, outlaw 4017, pff250hd, pipedobber, PowerstrokeJunkie, PowerstrokeMudder82, RLSCOAL, sbeachstang, strok-n, Stroker96, Strokerstooge, super73, survivor, sweetdreamz, tecelec1, TerminatorEngineering, Torque37, ttford07, Uncle Salty, whitemonster97
You may not post new threads
You may not post replies
Forum Jump
