58 volt ficm - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 6.0L Power Stroke - Aftermarket & Performance
Thread Tools Display Modes
  #1
Old 01-08-2012, 01:22 AM
Haun
Offline
6.0 stroker
Member's Gallery
58 volt ficm
got my 2005 f350 6.0 and stock ficm is going out and was wondering about getting a 58 volt upgrade was seeing if any body can give me any imput good or bad.
Old 01-08-2012, 01:36 AM
Niwrek's Avatar
Niwrek
Offline
Member's Gallery
Re: 58 volt ficm
I have one from swamps, I cant say anything bad about it. Didnt notice a difference after putting it in. All I can say is if you can upgrade a part.......DO IT
__________________
2006, 155cc injectors, 58v FICM, Banks intercooler, egr delete, studded, Air raid intake, Powermax turbo,5" turbo back magna flow, custom tunes by Vivian
  #3
Old 01-08-2012, 02:52 AM
windrunner408's Avatar
windrunner408
Offline
I Love Work'N On Hot Rods
Member's Gallery
Re: 58 volt ficm
Mostly everyone I talk to dont really see a gain in performance numbers with just a 58v upgrade but do notice a real difference when they have it with a FICM tune. JMO.
There are no negatives for running a 58v FICM other than your FICM voltage with a CTS wont be accurate as it only reads up to 50.0v so everything above that you wont see.
__________________
Nate
06 F350: Non-VGT 67mm Turbo, NB Oil Cooling sytem, RD 190/100s, WPE Ported Intake Manifold, NB/Warren Tranny, and some other stuff.....
100k miles and counting...
  #4
Old 01-08-2012, 03:00 AM
046.0inBC
Offline
Member's Gallery
Re: 58 volt ficm
I have a Swamp's 58v FICM I got last year at this time. My truck was in BD's shop getting an EGR delete when the FICM arrived so I took it over to the shop to have it installed and flashed. Mine throws the p0611 code, I think that's it, and it actually only read 54v when it was installed. It was $500 cheaper for me to get the Swamps unit then a replacement from Ford. The only performance increase I saw was it wasn't dead in the driveway anymore.
  #5
Dave At BD Power's Avatar
Dave At BD Power
Offline
Sponsor
Member's Gallery
Re: 58 volt ficm
I stand behind the Swamps Diesel's 58V FICM's. I have sold and installed over 100 units and had 1 go bad. Swamps warrantied it right away.
Keep the charging system and batteries good!!!
Dave
__________________
  #6
Old 01-08-2012, 05:13 AM
Term3's Avatar
Term3
Offline
'05 Excursion
Member's Gallery
You could try it yourself. I don't have the nerve though. You screw up and your buying a new one.
http://www.bscustoms.net/diesel/FICM.pdf
Dave when a FICM is sent in you don't get the same one back correct? So is the version and whatever else read off the old FICM that is sent in so that the modded one returned is correctly "married" to the PCM? I have an '05 Ex and was told the coding is different then the '05 pickups.
__________________
  #7
Old 01-08-2012, 10:47 AM
Work&Play's Avatar
Work&Play
Offline
Member's Gallery
Re: 58 volt ficm
I got mine fixed at FICMrepair.com.
Ed did a GREAT job.
He said that the 58v can make them less reliable ?
I went with the upgraded repair for $325.
My FICM is also tuned from PHP and that made a nice improvement and a 1-1.5 jump in mpg's.
__________________
Andy 2007 4X4 F350,6.0 PSD, Lariat, CC, DRW, 9' Knapheide body, stainless steel ladder rack, SCT with custom tunes, Banks turbo back, ARP's, ITP RR, Airdog II, Powermax with Billet Wheel, Firestone air bags, Autometer gauges( pyro,fuel pres,water temp,boost,trans temp), CCV mod.
  #8
Old 01-08-2012, 02:57 PM
moremph's Avatar
moremph
Offline
2Cruel
Member's Gallery
Re: 58 volt ficm
Swamps Pionered the 58volt mod on the ficm and i have yet to see it less reliablem, We hae over 150-200k miles on the test truck with one on it. I agree on a moded truck i noticed little diffrence, but my sotp meter sucks however on a bone stock service truck i have noticed huge diffrences. So much that i do not even keep 48volts in stock anymore i talk everyone into upgrading to the 58 volts. And if you send yours in to be moded you will recieve yours back
Travis
__________________
MPH Enterprises
2L Motorsports
SWAMPS Extreme Powerstroke Performance
Powerstroke Everywhere
  #9
Old 01-08-2012, 06:26 PM
STRAIGHTSTROKEN04's Avatar
STRAIGHTSTROKEN04
Offline
6.0..........
Member's Gallery
Re: 58 volt ficm
i sent mine in to swamps to get the 58v done hope i get it back fast.
__________________
04 H-D Edition, Intake/exhaust/SCT
  #10
Old 01-08-2012, 06:42 PM
07_powerstroke's Avatar
07_powerstroke
Offline
Member's Gallery
Re: 58 volt ficm
Is the 58 volts supossed to make the truck start smoother in cold weather like when its 20* out?
__________________
07 ford f250
Josh Vandyke
(View-All Members who have read this thread : 329
'94IDITurbo7.3, 03.6.0powerstroke, 03fathead6.0, 03_PSD, 04 f350, 046.0inBC, 04MT, 04psd6.0, 04stroker, 05lariat, 06-6.0 stoker, 0660stroker, 06deezel, 07_powerstroke, 1000klr, 1992ccsbpsd, 1997F350powerstroke, 1hydroman, 2 stroked, 2005stroker, 2Dstorm, 3sixjoshua, 494doug, 50gstroked, 6.0lover/hater, 6.0Powerjoke, 6.0stroken, 6.4power, 6keeper, 6litrestroker, 6oh stroker, 6speedSD, 89fiveoh, 8k05, 92f150300six, 97F250 HD, 97PowerJoker250HD, aerial, afFORDable, alwil, Amofg4, ARivest0347, asims9, ayrn, backroads, Bad Habit, baggedbug, bahenry87, Baker82, Barnbuilder, BCPSD, BCS, Bernie Jr, bgyllw, bhart, bhfarms, BigBlack03, BigDirty '04, bigjj, bigrngyj, BlAcKeNeD, blackqball, blakes, Bogath, boilermaker123, bootcamp, bornstrokin83, Bubbastroke, buckskins4life, bulletproof.6-oh, bvantiem1, cardiac, CbMac87, cfd f-350, CFH, chappy, ChaseN, chevyboy123, chromedom, cjetcat, clp13294, coalroller3x, coldhanz, Cory2537, Craig28, crawlake, Csulli250, cummins kid, Curtsturbo331, D.F.A., danny2313, darsey715, Dave, Dave At BD Power, daywalker, dbailey1111, DCTWINKIEP, DEMON, Desertdweller, Deuce02, DieselDan73, dits145, dodgeb2500, Dogman691, donalfila, Donlin, donnybau, dougnilsson, Down East Diesel, DragonSlayer, Dtech, duece, duncan351, Dutchboy, dwall, dwc032, DZL JIM, eatoncobra04, ed3196499, elevateloren, Extended Power, F-250-Owner, farmboy17, farmboy8201, Fartbucket, fast1000busa, fireanchrome, firebolt12r, FlossyB, Flyin' Hawaiian, Fnltch, fordboy11, fox farms stroker, Frank'daTank, fvrpowerstroke, G-Sqrd, geared_low550, georgia diesel, getsum, Gnarkle, gogo5.0, golfer, greenbeast, GTPaul, Guido404, harleyf250, Haun, Honda30, horsehauler, huhner5, Hutch, Ignorant1, IHPowerstroke7.3, injected79, Innovative6.0PWRStroke, InnovativeDiesel, irish4, James W, jammin60, Jason.Horath, JD F350, Jdiamond, jg6.0, Jgman141, jmplath, jonny18, jp115, jven6.0, jweber6.0L, kcbillb2, KCDAXFACTOR, keblmo, Kgradert7, kidmogster, king06, Ks94.5powerstroke, ksieckmann, ktm250f, KVD7360, legionxxii, liftedsilver250, loc0gring0, Loonatic, lopp, louisvanwilker, lubeowner, Magical_Merlin, MattFoster55, mehaffey, Merc82, mgeistman, mhastings04, Mikeh1725, mikek, Mikeysford, millerj, mint-6oh, mjcolemn, Modern90, Moosefps, moremph, MrBill1, mttrucker, Mud digger, muddynoll, Mudlight, Murdered6.0, mustang6, Muthafintank, mx185sw, Napadan, needalaugh, nelsonar, neoxaero, new2deisel, New6.0PSOwner, nickPSD, Niwrek, nrook, Nutz, OBSdan, oconnors17, oldbluef250, ole_blu, pizza pig, plumbstroken, Powderpilot, Powerstroke0694, powerstrokedkid87, PowerstrokeJunkie, powerstrokeshane, POWERSTROKE_GOD, Propwash, radioflyer, raenglehart, range91, Reaper8253, rentstdi, RescueF250, rfiscus2005, RHCDIESEL, ricg, RickF350, rideracelivemx7, Rob D, rockinamullet, Roush4_6, Sanger, scotty62, SDER1, Seand717, SevenThreeOBS, SgtCoalRollingChicken, shmokenpstroke, SickStroke6.0, SILVERSTROKER250, Six Liter, SKEETERMAN03, SledDogg, smokeless, smokin250, smokinstroker, smorris, Smut, sniffone, snopro_03, Speedinpolaris, sprayjock, Stevenmc08, STRAIGHTSTROKEN04, streetscrapin16, Stripp, stroked, Strokeofluck, strokethis06, Strokin2006, strokin603, strokin6L, StrokinSlow, Stu, sunsetmazdacs, super73, Superblack6liter, SUPERIOR OFFROAD INC., svilla, svorob, swaan, t.land, t.r.p., teena, texascadillac42, The Gray Mule, THE KITCH, TheFinalStroke, theGreenHornet, TIERNEY, Trouth302, turbie, turbodeezul7.3, turboluke, Twan, TxRanger3006, Tylus, umpalumpa1985, usmcmurillo20, utripin, villestrip, vindiesel2, Vozar, vt6.0, wackum, Wangfu12, whodathought, wildcat922, willyd465, windrunner408, wisp625, Work&Play, Xtreme, yamaman, ynpmoose, youngstroker, YZ250F12154, ZaC851
You may not post new threads
You may not post replies
Forum Jump
