trailor sway - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Other Diesel Topics > Towing and Hauling - The Work Horse Forum
Thread Tools Display Modes
  #1
Old 06-30-2008, 03:02 AM
EverettWV's Avatar
EverettWV
Offline
Member's Gallery
Question trailor sway
It seems like when we load our trailor with firewood, it likes to sway anywhere past 60 mph. It does not sway with any other load we've had on it, and if i am remembering right it doesn't sway on my dads sd with firewood. I am wondering what could be causeing it to sway on my truck. My dad had an idea that air goes through the wood lifting it some and causeing swaying. If this is it would covering it work? Or would adding some weight (wood) in the bed help some? Or is it the way we loaded the trailor? I just can't figure out why it does it. It gets annoying since, i can get above 60 sometimes but when i hit a bump in the road, it starts swaying. Here are some pics
__________________
Everett
1997 F-250 Heavyduty, Powerstroke, DIY Intake, 4X4, 5 speed, SWD 4:10 axle, 4" Flo-Pro SS Exhaust
Dana 60 conversion with PMF RSK with superduty V code springs, Rear superduty B code springs
Old 06-30-2008, 03:52 AM
bigd4me2's Avatar
bigd4me2
Offline
Member's Gallery
Re: trailor sway
cheapest= reese sway bar, but it looks like you would need a different slider in your receiver. read directions, and try not to back up with the friction sway bar in place, they remove in 2 seconds!
the better choice, is more costly, a weight distribution hitch, with the proper slider in your receiver.
__________________
02 dmax cc dually 4wd "miss piggy" tow bitch
00 f350 srw rc=6100lbs
ats comp housing,bdp 1.0 exhaust,afe pr7,4in turbo back magnaflow,hx cross,di regulated return,bbha,dp hi,40,80e,120r,6.oh no cooler autometer gauges
  #3
Old 06-30-2008, 04:12 AM
fishslayer's Avatar
fishslayer
Offline
go fast turn left
Member's Gallery
Re: trailor sway
try stacking the load so it is not behind the trailer axles, this should add tongue weight.
__________________
2000 F250 4x4 auto, crew cab, K&N fipk, 4" exhaust, 4"lift, 325/60/20 BFG a/t tires
  #4
Old 06-30-2008, 04:32 AM
TANK'S 250's Avatar
TANK'S 250
Offline
King Dingaling
Member's Gallery
Re: trailor sway
Exactly.....a lot of people don't know.
Atleast 55% of your load should be towards the tongue(past the center point of the trailer axle)....if not...it sways..that is what causes it.
__________________
2005 F-250, CC,SB,PSD, MANUAL TRANNY
Icon 4.5" lift, 40" SS-M16, and some other stuff
  #5
Old 06-30-2008, 04:44 AM
389SixPack's Avatar
389SixPack
Offline
Grumpy Old Bitter Bastard
Member's Gallery
Re: trailor sway
Just looking at the pics of your trailer. Axles are too far forward. Yes, you need a lot more weight on the front. 8 to 10% of total GVWR should be on the tongue for stability. Generally, in trailer design, the front edge of the front tire will be about the centerline of the load area of the trailer. From the pics, your front axle looks like it is ahead of the centerline. Stack it high in the front or pull some off the back.
__________________
aka - Grumpy .. aka - Bubba Grump .. aka - Bubba .. aka - Grumpy Old F... . . A "slow" fatass 9K Dually.
  #6
Old 06-30-2008, 06:15 AM
crowz's Avatar
crowz
Offline
PSN Mega Miler
Member's Gallery
Re: trailor sway
Thats one high sitting trailer too. My car hauler which looks similar sits a bunch lower than that plus the axles are a good bit further back. You will need to load it down on the front pretty heavy for sure like everyone said.
__________________
2002 F250 SuperDuty Lariat PSD 7.3 Crew Cab 4x4 302,000+ miles.
S&B Intake, Valvoline Extreme Blue 5w40 Synthetic, 295/75R16 Swamper SSM16 Tires, Kenwood DDX512 Stereo with GPS, Clifford Matrix 50.5x Alarm
4300K HID Headlights, DiProcol Boost & Pyro Gauges, P3 Brake Controller, Swamps Injectors, PHP Tunes
My F250 and other Rides
  #7
Old 06-30-2008, 04:23 PM
EverettWV's Avatar
EverettWV
Offline
Member's Gallery
Re: trailor sway
Thanks all, I will try loading more on the front next time.
Do you mean the front of the trailor is to high? I noticed on my dad's truck the hitch sits about 2-3 inches lower so maybe thats why it doesn't sway on his. Of course his is a f-350 and cc so that helps some.
  #8
Old 06-30-2008, 04:45 PM
crowz's Avatar
crowz
Offline
PSN Mega Miler
Member's Gallery
Re: trailor sway
I mean its got more ground clearance than most 4x4's running around here
When you stick something that high in the air it has a tendancy to sway. You might consider some kind of sway bars as high as it sits.
  #9
Old 06-30-2008, 04:51 PM
99F250Smitty's Avatar
99F250Smitty
Offline
JDG's #1 Fan
Member's Gallery
Send a message via AIM to 99F250Smitty
Re: trailor sway
Definately need more weight towards the front of the trailer, the axles are to far forward. You have alot of weight on the tail end with those ramps and the wood. That will cause the sway.
__________________
Brian
_____________________________________________
99.5 F250 Extended Cab Short box. 4x4.
Mike's Diesel Performance
http://www.phptune.com/
  #10
Old 06-30-2008, 05:32 PM
EverettWV's Avatar
EverettWV
Offline
Member's Gallery
Re: trailor sway
lol, yes the trailer is high and i wish the ramps a little longer so it wouldn't be as sharp as an angle when loading but it does the job. My dad had someone make the trailer for him back in 94. I know with his old truck (94 f250 sc lb, gas) with trailer with our international 674 tractor on it, it never swayed. I never remember haulin wood with it though.
As for sway bars, i think i will try loading it different first. We only have about 2-4 loads a year of wood. And so far, firewood is the only thing that makes it sway.
(View-All Members who have read this thread : 77
00PSD1, 1991idi, 389SixPack, 96 stroker, 99F250Smitty, ADubDiesel, Alan Hicks, badluck_early99, bens99f350, big nasty, big shooter, bigd4me2, BigTonka, BMac, Burton7.3, cemeyer, chunkdunker, CraigG, crowz, dennis11, Dieselgeek, DIRTBIKEZ, Dirtyboy82, Doakster, EverettWV, fastpowerstroker, fishslayer, FleetMan, FloridaStroker, forddieseltweek, FTG-05, FuriousGeorge, fxdwgi, GEM, gtmustang00, ironworker25, jakef250, jdc753, Joedog, Jordy53, jshank, JSlack, kickstand, King Ranch, KMurakami, kts532, Lee, mazdaparts, mech2161, merlinnilrem, mflores, moose99ps, newmexicocrawler, Patrolman, Pocket, PSDnate, qcfarmer, Redfish, RFD_Truckie, Rogue1970, shortbox, sixiron, smokyred, spindrift, squeak12, StrokerTurbo7.3, strokinva, Tampa450, TANK'S 250, tkdbf350, Tom S, tpull3, TrailerHauler, treyloco, xsperf
You may not post new threads
You may not post replies
Forum Jump
