6.9 IDI High Performance Build - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > F-250 & F-350 1986-1997 & Other Ford Trucks > 6.9 - 7.3L IDI Diesels 83-93 Model Years
Thread Tools Display Modes
  #1
Old 12-26-2011, 02:39 AM
NRHX2009's Avatar
NRHX2009
Offline
Member's Gallery
Well guys here is some of the build info and pics. I'll keep adding pics and info until completed.
1983 F-250 4" lift on 35's
6.9L Bored .30 over
Cryoed and heat treated Rods
Arp head studs
Custom Bottom end girdle with ARP studs
Professionally Ported and Polished Heads
Mahle Pistons with .100 shaved off the top and Ceramic Coated
Compression lower to approx. 16.5:1
Injection pump maxed out by Ken at DPS. (says pump will deliver 4x stock pump)
Injectors maxed out to match Pump
Custom Built Log style Manifolds
Custom Mounted Holset HX-50 66mm inducer 19cm exhaust housing
Converted to Serpentine belt system
Twin Holly Black Fuel Pumps
Superduty Axles D50 front and Sterling 10.25 Rear
OBS Radiator
Superduty Intercooler
Old 12-26-2011, 02:45 AM
91dirtydiesel
Offline
Banned
Member's Gallery
Re: 6.9 IDI High Performance Build
Sick. What's its intended purpose?
  #3
Old 12-26-2011, 02:46 AM
NRHX2009's Avatar
NRHX2009
Offline
Member's Gallery
Not too sure. Its my friends truck and we are doing the build. Mostly fun DD occasional local puller. Just something to dick around in really.
  #4
Old 12-26-2011, 02:49 AM
hairyboxnoogle's Avatar
hairyboxnoogle
Offline
IDI for life
Member's Gallery
I need to find that elbow you have for the compressor side. Looks sweet man. Think the single hx50 will move enough air? By my calculations the pro52 was a hair on the small side. Then again, i have no idea what im doing. Look forward to hearing how it runs. Is that a one-off intake or a highly modified stocker?
__________________
'92 F-250 Supercab long bed. ATS 088 for now
'79 F-350 Custom, Super Cab Flareside weighs in at 6460 -- 7.3IDI Diesel hx35/40-HT60,p-pump, ZF5/205
  #5
Old 12-26-2011, 03:14 AM
seawalkersee
Offline
Member's Gallery
Stock cam? What psi are holley pumps? If you are running that much unregulated fuel (more than 9), I have heard it jacks with your timing. Did the head porting include matching/cc-ing? I see you have added an additional plate across the rear of the intake. Why? How much for one of those lower girdles?
SWS
  #6
Old 12-26-2011, 04:01 AM
RacinNdrummin's Avatar
RacinNdrummin
Offline
Trailer Trash...
Member's Gallery
Good to see another custom build.
I take it this is #2 of the 3 or so DB2/4 pumps out there?? And I see yours is putting out 200cc's instead of Justin's 150cc... I know Ken had some reservations about the pump shaft at that point, does this have the billet ground shaft?
How are you going to connect the passenger side manifold to the turbo?
If you could get more pics of the custom stuff, that would be awesome, Its always good to see what other ideas people come up with.
Whats the plan for head stud torque?
  #7
Old 12-26-2011, 05:41 AM
88 Ford's Avatar
88 Ford
Offline
Member's Gallery
What is the intended boost level too? And you really need one of the two aftermarket regrind cams! It makes quite a bit of difference. One of the regrinds is more for high end power and the other is more for torque. That is an awesome build man. I am quite impressed!!
Do you also have any specs or info on the injectors or injection pump?
  #8
Old 12-26-2011, 05:44 AM
88 Ford's Avatar
88 Ford
Offline
Member's Gallery
Oh and another thing I forgot to ask. What are you using for head gaskets? Thanks for the info man. We appreciate it!
  #9
Old 12-26-2011, 01:33 PM
NRHX2009's Avatar
NRHX2009
Offline
Member's Gallery
Ported stock manifold. We just capped the top and are running a 3" v-band assembly to a 90 elbow to the intercooler.
HX-50 will move more than enough air for this application. Max boost will only be 30 psi. While DD wastegate will be set around 22 psi
  #10
Old 12-26-2011, 01:38 PM
NRHX2009's Avatar
NRHX2009
Offline
Member's Gallery
SWS
Stock Cam for now.
I think the Holly Black pumps flow 120 gpm @ 9psi each. So We will just have a lot of volume while maintaining 9 psi
Plate across the back was going to be used for a turbo mount until we decided to hang it off the side.
Not sure on the heads, They were sent out to be custom ported and polished, and thats what he got back, lol
Working on pricing on the girdles. I have a few guys interested.
(View-All Members who have read this thread : 838
'84 f250, '94IDITurbo7.3, 0 Xero 0, 01grnstroker, 01PSDiesel, 01txdmax, 02BigD, 02strokerace, 02strokin, 03kingranchstroke, 03_dmax, 04.52.6driver, 04power, 04smokeman, 04stroker, 05 shaker, 05LLYMaxx, 06-6.0 stoker, 06stroker250, 08bluestroke, 08straightpiped, 12gauges, 16yrenthusiest, 1960 Ford, 1964f250, 1986IDI2012, 1987 7.3idi, 1993_F350_2013, 1997F350powerstroke, 1997Fummins, 1999 7.3L, 19stroker97, 19_A_LT, 1badidi, 1badpsd, 1craneguy, 1turbo10, 1wyatt, 20007.3psd, 2006powerleaker, 2young2drive, 307diesel, 359 Pete, 4.0l sahara, 444diesel, 46/71 Hybrid, 4x4B190, 4x4quigleyshortbus, 4x4troy, 505yam, 530diesel, 54ford, 59fordcummins, 6.9er, 6.9performance, 6.9PoweredScout, 66IH1206, 6869704x4, 69turbo, 6slow, 7.3HD Guy, 7.3idi-fan, 7.3L F-250, 7.3lsmoker, 7.3maniac, 7.3psd1999, 7.3_IDI_guy, 770 Raptor, 79broncoidi, 7THREE, 800polaris, 82crawler, 82f100swb, 82hotrod, 83Ford6.9, 84mudder, 85 f350, 856f250xlt-4x4, 85F250Diesel, 86turbodsl, 87 F250 6.9L, 87-6.9, 87banshee, 87diesel69, 87idi, 87jumpy, 88 Ford, 887.3DirtyD, 88FordDiesel, 88IDITurbo, 89 Horse Hauler, 90fordf3507.3, 90idi4x4, 91dirtydiesel, 91forddiesel, 92f150300six, 92f350cc, 92hypermax, 93cc7.3, 93idi2007, 93Reddually, 93turboIDI, 93_444idi, 94.5 Stroker, 94IDITD, 94iditrbo, 95 pstroke, 95doodoo, 95gasser, 95psd2, 96F350Kid, 96f350psd, 96powerstroke96, 96powerstroker, 96strok, 96strokerboy14, 97-7.3powerstroke, 97Beast, 97HDstroker, 97PowerJoker250HD, 97Powerstroke Boy, 97PSDiesel, 99-350, 99coalroller, 99f-250, aarons7.3l, abbottfarms, ACFarmer, Addicted2Stroken, Adinas95, adrenalinejunky81, aggiediesel01, ajf350, ajfetterman, aktotn, Al Mighty, alex211, All Jacked Up, Alvapowerchoke, alwil, Arctic Fox, arctic89, army-dude77, aussie_f350, average, backroad7.3l, bad12jr, Badbob, bcold1, BCPSD, Bdsankey, bert, Bewford, bhfarms, Bierman303, Big Bore, Big Green Machine, BIG JER, BIGBLUE08, BigBlue7point3, BigBluediesel08, BigDangFord, BigDiesel, bigjake0524, Bignbadbelair, bigphil76, Bigredpoweerstroke, bigsqwez1982, BIG_RED, BikeMaker, Bikesbeforebabes, billmoody1, Binder man, Binderpower, biostroke1, bknight187, Black 4.6 Beast, black dawg, black7.3, black91idi, BlackBear423, BlackBeauty96, blackie375, Blownoiler, bludog, bnbdiesel83, Bobby j, bobv350, Boogeyman, Boost96, BootZ0360, Borchers88, bourneenterprises, Bradbilt, brazz04, Brimmstone, brinkprop, broncof250444, bry03, bryced1, BuckinBronco, bucklee00, builditloud, Built4tq, Bulldog, burninoil, Burton7.3, ByrdDog, C.D., cabloom7.3, CamTom12, Case IH Guy, Caster, catman, cccomplete, ccf350stroker, Cclinton, cdnf250, CDX825, chadow427, chappy, chevyboy123, Chimera, Choupique108, chris1978, Cincinnati Guy, cjsobas, CLASSICIDI, cliff-1972, Clint39, clv1144, cntryboy17, coal rollin monkey, coalroller94, Codydiesel, Colo6.0, Colorado, Constantfix, Cookie_Monster, Cory_S, cowboy6.9, cowboybootlegger, cowman79, cpdenton, cr250rgio, crabbelle, CSIPSD, Csulli250, ctdiesel99, Cundiff, curshe, cuttin4jc, Cutting-Edge Diesel, d11b, D66stroke, dabluesman, dag4566, DALT 6.9, daltons200x, damons250, dan-devries, danby, dangreen, DarkHorse89, DarrinGT, Dave7.3, davey99ps, Dchaynes3, DcMoore999, DeadMan, DeanH, Deereman4020, Deerezilla, Deerslayer42694, deezeljunky, DeezNutzzz, dentexpowerstroke, Denver, Derek C, Detroit AutoWorks, deVana3, DevilDog6154, DevjWilliams, dfghgfhj, dgpooch, Diesel73L, diesel78, Dieselboy, DieselDZ, dieseljimmy, DieselJuice, dieselman81, dieselmandustin, Diesel_Jeramy, Diesile, Dieslnevan2009, DIEZEL7.3, Dirtyboy82, djralmtlf, Djs6.9, DMDP, dmschmidt1200, DNichols3288, Dommel01, doofpowerstroke, dragonboi, DragonSlayer, Drew2010, drh4250, Driles85, drkndzl22, dsltech83, Dsl_Dog_Catcher, duckie, dunk, Dustball8504, DuvaFX4, dwelder454, DWitcher, dyoung14, DZLAL, DzlNut, e99CoalBaron, Elog91, eric96ford, eric96obs, Eric@PTP, Etaylor, Etcetera, evaskulleader, EverettWV, eviljmizfit, e_in_tn, F-127, F-25000, f250towrig, f350dualie, F350strok3r, Falls250, Fantom, farmall16, farmall99, farmboy17, FarmBoyStroker, farmer09, farmerboy93, FayettesFinest, fiftyfordfloored, Filko, Firedogbme, Firefighter4hfd, Fishertech, FlatbedCowboy, FlatbedRocketship, FlatbedStroker, flatwoods, Fleatickchad, floridastroke, football3295, ford 6.9, FORD5.9CTD, Fordfreak4life, Fordguy100, Fordguy26, fordguy712, forkspear, Fox'sFord, foxco44, foxcolmo, fpOwerstRokeD, Fr0gstomper, frankintruck, free_rider_151, Frenchb85, frostyweld, FRX NSTY, FuturePharmD, g.w buffalo, Garbage_Mechanic, gbkeith, genoreno, georgia diesel, getblown5.9, getzy, Ghostwhite, Giddy-Up, gingra$$179, glamis_dave, glovemeister, Gman32, Goldenarm85, golfer, gonecrazyi, goodstktbo, GOOSE_SS4, Gotti2k7, granite state destroyer, Grayguy1995, great dane, Green037.3, groomzybanshe, gsfloor, gsxjay, hairyboxnoogle, hami3533, Hardy41, harrisboi93, Harvey, Hawkshaw, HC Emporium, Headcase98002, hexda3m0n, Hick and Tick, Highbeam, HiVoltage, HMWH, HogMouth, Holleran, Hoss1997, Hunter'97, hutchx, hwstem, Hyde, Ice--man, IDI guy, Ididriver, ididuffy90, idiferd, idshred, ifrythings, ihboy, InfamousIDI, Iowa 73, ironbarr, Issacdilldine, Ithumpwheniwalk, iverger, Jacob 76, Jacobbingham, Jake9551, JakePSD, jam0o0, jamerman09, jankestang12, Jarretthise, jays92, JCart, jcbulmer, JcsReno, JD F350, JD3020, jdc753, jdkl81, jdla140, Jdo150, JeffCo97Powerstroke, jgbike, JGod, jhimes56, JI97PSD, jim dandy, jimmyducati, Jinx, Jjona5, jmac, jmjc123, Jnalaplace, Jngreen, Joe's06, Joe01bass, JOECOCHRANE, joedaddy, joeford302, joemx611, Johnny77Mutt, johnnyquest, JoJo, Jonesin, jonnydiesel, josh77, JoshBenavides, jparchment, jpipher, jpw, jpw1616, JRF, jrracerdad, JS98, jschildm, JSVD, jtlane, junior20762003, junk, junkman306, jupain, justcuz, Justincredible, justindyer, juststrokin', kawamatt2, kbog350, KCDAXFACTOR, KCMEADOWS, kiehn18, klipz, kollenh, KR69IDI, krtillison, krueger7.3, kvmushroom, kyle43335, LaWrench, LBF, lbzbuick, legionxxii, lengelhardt, LETHAL WEAPON, lincolnlocker, linkfarms, LOSTCAUSEPOWERSTROKE, loudmouth, lougar6556, lowbedriver, LttleGreenRam, Luke909, lxcoupe, Lysons, madatch01, MadMaxwell87, madmaxz, mandkole, martins96, Marty, matt6.9L, matt92idi, mattscoke, matt_m73, MB97PSD, McFadin(BACON), mcreed90, me2, merle, Michael Dimock, micky_blue, Mike1989idi, MikeK3500, MMillere, Monster758, moose7.3IH, morefuel, MotionmanJCM, Mr. Bob, Mr.Wonderful, MrE, mrlm0082, mrlm1982, MrMike06, mttrucker, mudkickr, mudoc, Mudwizer, mx185sw, mxredneck, nawojtko, ncovey, NE91idi, necks00, nickeagle, niklid05, Nitro Blazer, NJ2012F250, nm351, NMB2, Nodge, NorCal1stgen, nova, np205, NRHX2009, nrook, ntruderrider, NutFarmer97, Oakes, OBS F350, obs stroker, obs5speed, OBSdan, OBSIDI, OBSpstroke97, Ocelotl, ohiopowerstoke, Ohnny101, OilBurner62, okiebindernut, Olb Blue Beast, old man dave, oldbluef250, ole red, ONEFASTSTROKER, onus, optikalillushun, orchard6, oregon96psd, orly, otis62888, Otter70, pa-powerstroke, papastruck, papps8168, patrickke, patricku47, Patrolman, paulzx, pbdp, pennsylvaniabo, Petro, PhattyBanks, pino2234, Pipeliner08, Piperig78, pizalm, PJB, plainjane, PokinDaPower, pontiacross, poorboy's stroker, pooter, portlandareae28, powdersmoke4700, PowerPerformanceChainsaw, powersmoker73, powerstroke cowboy, POwerstroke Named BIG D, powerstroke095, Powerstroke2008, powerstrokedkid87, powerstrokefarmboy, powerstroker20, PPE'dPowerStroke, predator86, printzjd, psduser1, pullinstroker97, purplepstroke, PWRstroke_smoke, racer30, racin460, RacinNdrummin, ranger553x, rayd1969, rc31080, Rdh605, RedBull_04, redlined88, redneckmarine, redtop_travis, reis1995, reklund5, Rhinotoyz, rider2xtreme93, riotwarrior, rlacasse1, RLSCOAL, Rmartin-97, rollingcoal69, rollinhot, Ron's power stroke, rpm-inc, rsama, Russo2, Rustler, rustyescott, ryandamo, sailor95, samickguy15, sargepep56, Satan's chariot, SAYiWONT8, Schneider 86, seawalkersee, sharpie, sharpmotors, Shaun_Nell, shmokenpstroke, sho669, ShogunRider, Shovel, silent14, silent64, silverf250, simmonscoatings, SixtySix Ford, skeetreecetw, slinga, slippydaman, Slog58, SLOSIXOH, slosvt, slosvt.kw, slutz4, smokey bronco, smokey05, Smokin LB7, Smokin444, smokin99stroke, smokinford07, smoking69, smokyidi, Smut, snaponprofile, Sndwrkr, SoFlaKev, sootieoil, Soupy, southbend_powerstroke, southtexasidi, sparks427, spectreblazer, Speedwrench, SPless, Splinter, spok, squirrel64, Stacks92, ste2, steelhorse08, stevedrums, stevv, stirling35, stoker04, Stokes, straggleweed, streetsoldier, Stroker96, Strokersace, stroker_1999, Strokethis17, strokin n smokinn, Strokin6Liters, strokin83, strokin97psd, strokinak, strokindt444, StrokininMO, strokintilbroken, studded 6leaker, stumiister, superstroke80, SuperStroker91, suprdzlduty, svtwhipple03, Swamp239, swedenidi, t4050nh, t444epsd, takeyourchromehome, tanman_2006, tattoocharlie, Taylor22, tcn idi, tedsxb, the only Qualk, the06wildebeast, TheColt, thee6.9diesel/7.3idi/, theelcaminoman, Thefarmboy21, TheStroker, thewoodman, Tiewire, Tivs, TJ9373idi, tjmp111, tneibling, tnk41411, Totalled, towncorners, trackspeeder, Trapper, Traveler, tredav39, ttford07, tughill283, Turbill, turbolab, turbonator, turbotibbo, turbovanman, TXStroker97, tyler886, u2slow, UNCOOL, Utah7.3, v800, vdog, venomusduck, Viking, vista461, VS_Admin, wa96stroke, wadeclinton, wanabebig, Wanger212, wannabstrokin, Weldon, wes lewis, Why Not, Wicked97, wicked_four_play, wildbroncobilly, wildjon, willholl79, Wilson444, wilsonbaird, wint, WishinIwerFishin, wjamesm, Woody35, xcite, xrxmxcx, yogr, yotee, younggun55, youngstroker, zcampbell90, Zrock, [willy]
You may not post new threads
You may not post replies
Forum Jump
