trans shifting problems, kills engine when i put it in gear - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Other Diesel Topics > Transmission Related
Thread Tools Display Modes
  #1
Old 12-11-2011, 08:51 PM
jaxral
Offline
Member's Gallery
Lately my trans truck was surging as i drove, like the trans was slipping, now when i put it in gear ( reverse or forward) it acts like its revving up then kills the motor.. if i put it in gear without holding the brake it will take off real quick then idle back to normal and i can drive it somewhat, until i put the brake on.. sometimes it will idle but then it wil try to go faster and kill the motor. Does this make sense ?? One time i was driving and it just went clunk real loud like it shifted extrremely hard, then went back to normal..
Old 12-12-2011, 03:19 AM
dave186
Offline
Member's Gallery
Location: Idaho... potatoes aint the only thing that we grow
Re: trans shifting problems, kills engine when i put it in gear
Have you checked the fluid? sounds like the converter is locking and that can be caused by lack of fluid. It could also be the filter has fallen out of the pump. Just a guess though. Also what trans is this? im assuming its a e4od or 4r100
  #3
Old 12-12-2011, 03:21 PM
PowerStrokingMachine's Avatar
Offline
In 6.7 heaven
Member's Gallery
Jaxral: Im no help I have the same exact issue, Im just going to stay tuned in until I can have the codes read. I did search some more threads and found that it could be the torque converter clutch solenoid on the passenger side, it could be the torque converter, someone even said just change the filter/fluids?
__________________
2011-F250 6in BDS 4link lift, full rear leaf, ridding on 20x10 BMFs wrapped in 37s. Currently no plans for performance.
SOLD-2003 7.3 F-350 CC FAT BOTTOM
77 Vette-mild motor, built trans,12.4 quarter.
99 Dodge 2500, 5.9 28in lift,46' claws- sold
  #4
Old 12-29-2011, 01:44 AM
Andypac
Offline
Member's Gallery
This similar problem happened to me I was pulling my boat after my tranny started kinda acting funny I'd stop at a light (w/o my boat hooked up) and it wouldn't down shift until a second or more and some times it wouldn't go back into gear off the line until a second or more but my truck only stalled in reverse and it was only a few times. Then a month or so later it got even worse I barley move in drive (baby crawling speed) slowly press the pedal and rpm's jus climb feels like it is trying to get into gear but just won't happen I can move in 1st and 2nd but not with drive until I shift from first and second manually then drive and it still slipps quite often but after time it got up to about 55 60. I tried to drop the trans but after I drained the fluid(black btw) after the pan was dropped I was horrified there was metal particles stuck to the plug magnet :-/ I am getting an overhaul kit because I'm a diy kinda person(and cheap content spend more then 350) but I have no clue if that will fix what may be wrong it's my only vehicle and I don't want to take it out of commission for too long any advice will be increadabley appreciated I need to have it fixed by the end on Jan :-/
Oh and the truck is an 03 7.3L with 4r100 and 260,000
  #5
Old 12-29-2011, 04:09 PM
ricg's Avatar
ricg
Offline
Member's Gallery
like dave186 said more than likely its the torque convertor staying locked up..
__________________
04 f250 fx4 with 03 turbo (whistle), APR head studs, external oil cooler, egr delete,stock 3.5" exhaust with 6" tip, warrens 175cc injectors, xcal 3 with matts SRL+ tune...SOLD..
2008 f250 with Donahoe Racing 4" lift on 35x12.5. H&S Mini Maxx (HOT DAMN), DPF delete
(View-All Members who have read this thread : 54
01pwrchkn, 01REDSTROKER, 02 CCSB, 07outlawpowerstroke, 2000XLifted, 250turbo, 6.0Powerjoke, 86turbodsl, 92f150300six, 94.5 Stroker, 96f350psd, aklim, Andypac, blakes, bpa658, bracketracer, bryan.d, btaylor08, cbrown, chadott755, cobragarage, Codydiesel, Cratos, dan-devries, dave186, Denver, Driles85, eleventhtruck, f250towrig, farmboy93, fitzih29, Gibrid4x4, guy, highfive, hwhizbang, IHPowerstroke7.3, jaxral, ktmrydr686, Mark Kovalsky, Myles_S, paul06d-max, PowerStrokingMachine, ricg, seven.3psd, skobiak, steel, strokin93, tensixniner, trackspeeder, transman81, treetechsixOH, turboaz2, Uncle Salty, Zmann
You may not post new threads
You may not post replies
Forum Jump
