Anyone use Marvel Mystery Oil ? - Page 2 - PowerStrokeNation : Ford Powerstroke Diesel Forum
Register Members List Timeslips Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto EscrowInsurance
Thread Tools Display Modes
  #11
Old 12-01-2011, 12:15 PM
jmac
Offline
Member's Gallery
Re: Anyone use Marvel Mystery Oil ?
I change the oil every 5 thousand. I put 20% MMO and did not plug in the pickup overnite. It got down to 25 degrees and she fired right off. It has NEVER done that in the past. I'll have to wait and see how it acts as time goes on. Might blow up today??
Old 12-01-2011, 03:03 PM
Ottomatic
Offline
Member's Gallery
Kreen Update - Bob Is The Oil Guy
WARNING: ABOVE SITE IS ADDICTIVE
__________________
E99 PS SD 7.3 348,000 mi. Banks exhaust & turbo housing + Beans Stage 1 injectors and tunes. Modded IDM, HPX, Magtech trany pan, SPR1
NEVER been at a dealer
06, Chevy LBZ, 154,000 mi
Banks exhaust, ,Bilsteins, PPE Standard. Suncoast Transfer Case Brace, Kryptonite tie rods & centerlink
  #13
Old 12-01-2011, 03:10 PM
rufushusky's Avatar
rufushusky
Offline
Exploding the magma
Member's Gallery
UOA of MMO in a 7.3
Ask The Marvel Mechanics Forum
__________________
2002 F-350 ECLB SRW 7.3 4R100
6637 203* t-stat 08 diff cover Stancor HPX 6.0 trans cooler
Sold: 2004.5 Ram 2500 w/ 5.9 CTD, Reg Cab 48re
  #14
Old 12-01-2011, 09:19 PM
aklim's Avatar
aklim
Offline
Member's Gallery
Can this diesel shop remove the injectors for you and have them cleaned and how much will it cost?
I have cleaned injectors besides 7.3 injectors but I would expect it would be the same. I regularly have them cleaned or tested (about 100K) for diesel injectors. When I hit 100K the last time, I changed them to Stage II Single shots so no cleaning and testing is required.
__________________
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, GTP38R Turbo with 1.15 A/R housing and BPD Stage II AC injectors. Bilstein Shocks with U front and A Rear.
  #15
Old 12-02-2011, 12:30 AM
jmac
Offline
Member's Gallery
The shop said no cleaning. I will get on and ask on the MMO site. I'll let everyone know how this little experiment works out. So far, so good.
  #16
Old 12-02-2011, 02:14 AM
aklim's Avatar
aklim
Offline
Member's Gallery
If it can be disassembled, it can be cleaned. Ask another shop.
  #17
Old 12-02-2011, 03:05 AM
skippy
Offline
Member's Gallery
cleaning will only get you so far though.the problem is usually caused by poppet wear.to fix it right they need shimmed at the least.thinner oil or thinning the oil helps but only masks the real issue at hand.
  #18
Old 12-02-2011, 03:53 AM
aklim's Avatar
aklim
Offline
Member's Gallery
True. I would like to have it cleaned first before we do any testing though. Once all that is done, if it can be fixed, it would be something to look into.
  #19
Old 12-02-2011, 01:41 PM
kilapapipa's Avatar
kilapapipa
Offline
Old Yeller, REBORN
Member's Gallery
I like the sounds of that Kreen stuff. I just ordered 2 qts. for my 94' Jeep with 121k mostly town driving.
__________________
REBORN 20 Over on 3/2/11- Pics in gallery- 2000 F250, Auto, 38r, Full Force 238cc/100%, TE 17* hpop, DP F5,HI,60T,80E,120R,140A, Studs and 910's with DI PR's, JW VB in 2nd stock tranny, Walbro 392, Bellowed, In-Tank, Pre-Pump, boost fooler, and RR. Air Dog, SS cover, 6.0 TOC,4" straight piped and guages, 6637, coolant filter, 4" Lift on 33's.
  #20
Old 12-02-2011, 03:14 PM
Ottomatic
Offline
Member's Gallery
Kano labs has great products . Their Kroil is fantastic, no shop should be without it. I also ordered some Kreen, but I am still reluctant of putting it in my Ford . I am going to try it in a couple of other diesels I own first.
(View-All Members who have read this thread : 201
01strokin, 02 7.3, 02_powerchoke_F350, 03cummin450, 03F250 6.0, 03_PSD, 16yrenthusiest, 1twisted1, 2CAN, 444-4D, 4duggan, 7.3PowerStroke602, 836.9, 95f250psd, 96f350psd, abraf350, AddictedOffroad, airfish2011, aklim, All Jacked Up, amdriven2liv, aviatorkev, Balthasar, Baxx, BBowden73, BDHABT, BeaveF250, bigdawg69, BIGLARRYS03, billmoody1, birdog, blacksmoke.r.us, blakedunkley, Blasterak, boostaddict, bryan.d, Buford-61, bug-e-dude, bulldog01, Bushwakd, camaroicoc, camaroracer, chadder1313, CHevDog1, chrashd, chunkdunker, cj45lc, claybuster, clp13294, CSIPSD, curt 2006, cutterstroke, Cutty72, Cwillhite04, damons250, Danner96FordF250, Dave, DCTWINKIEP, dermestid, Dirtpusher, Dirtyryder, dperone, DragonSlayer, DRT1359, duncan351, dzlstroker, Eford00, elisowski, engi041, erskine_e, erstroke, evo45, e_in_tn, F-250-Owner, f250towrig, Fddriver2, firedude26, Flash and Flare, Fordfreak4life, fordnut, Gido, Greg, guy, hag000, haulin2000, Hawkshaw, hill_billiez, HMWH, IEBahner, isootmypants, jamesthebikeguy, jamponyexpress, Jayhawk246, Jdg41, jerrid, jfairhurst, jmac, JoeD427, joediesle, JustEZNAlong, jwchurch, kbmkviii, kbog350, kickstand, kilapapipa, lep, loner1, M1009cucv11, Madisdaddy0505, markyt, Matt-F350, mattjensen, MColeman, micky_blue, Mike97f350, mjones, Mo6.0, mtgrease, mttrucker, Mudwizer, Nascar_fan28, NEBR99.5 OIL BURNER, Newman, nm351, Nomad1671, norcalsig, northshoredr, Ohnny101, oldwood, ole_blu, Otter70, Ottomatic, patrickke, PETERC, poon, pooter, PowerstrokeMudder82, PSD-350, psdmike, PsRumors, pueblowestdude, ragecajun, redneckabbott, REGUN, Rescue48, revolvingsteel, rich, rideracelivemx7, Riskit, rockwall7.3, rollingthunder, Ron's power stroke, rsbhunter, Rumsey01-7.3, Russo2, rusty1161, s10extcab2, Semperfidoordie, Shep, shvlhead78, sikedude, skippy, slowduty80, smokinford07, Snake, Sndwrkr, southmike, SPE, srq, Stampitguy, Stroken7.3, sunny644, super73, superxcrewfx4, techteacher, TerryF250, texasredneckjae, the wrench, thecabinetguy, THUNDERstroke73, ThunderValley, Tipher, TomzToyz2, Torque37, trolling2, txdieselmech84, TxFire, umpalumpa1985, Uncle Salty, vintage way, wgoebel78, whip450r, white07psd, whitjo, withrow, Woodbeef, wooner, zilla68
You may not post new threads
You may not post replies
Forum Jump
