| Register | Members List | Timeslips | Calendar | Sponsors | Becoming a Sponsor | Mark Forums Read | Auto Escrow | Auto Loans | Insurance |
Thread Tools | Display Modes |
#1
changed oil and its still black. need help
Yesterday i changed my oil in my truck and after i filled it up and turned it over and topped it off, and ran it for like 5 mins. i pulled the dipstick and the oil is black like i never even changed it. And all 13 quarts came out and went back in im stumped. Anyone ever here this before and the truck dont run nearly as good as it did, has like a funky miss to it but not really bad. truck has 218k on it, always change my oil every 3,000. Could injectors be to blame for some weird reason since they are orignal. i also have a tony wild man chip on it. all my mods are in my sig. My buddy is gonna run it on his scanner anything i should look for?
__________________
95 F-250 4x4 standard cab, under construction PULLER 97 F-250 4x4 ex. cab short bed. Daily driver |
| Sponsored Links | |
Advertisement |
#2
Re: changed oil and its still black. need help
If I understand you right.Ur saying that your brand new oil is black after u put it in?
Diesels are just naturally dirty. You can have the drain plug off of the pan dump clean oil through the top and it'll come out the bottom in black. It's just the nature of the beast. |
#3
no way i have changed my oil on these trucks alot. and every time i pull the dipstick to check it after i changed it, its always nice and clear. that goes for any motor.
#4
its normal. every diesel ive ever had, i would change the oil, start it to get oil pressure up, then check it and its black. my grandpa always said if a diesel dont turn the oil black it aint worth a f*ck.
__________________
-Mason 95 f250 xlt ext cab lwb 7.3 e4od 4" straight pipe with a 7" tip 87 f150 xlt 302 original aod 3:55s true dual straight pipes ![]() |
#5
if you want clean oil buy a gasser
__________________
96 5 speed. valair. 160/80. 96 BTS. GQSSB. 250/200. 6.0 coolers. spray. |
#6
I got to say the oil in my ex is clean for at least 1000 miles before it starts turnindark.. I don't know what kindof dirty ass runnin motors y'all r runnin but all my past diesels were the same.
__________________
2000 f250 ECSB, 4x4 7.3 zf6, 150k miles Php hydra w/ php tunes and gearhead, 4" exhaust, stock turbo(ww2, turbomaster wastage actuator, gutted ebpv), FRX, unlimited 160/30 sticks SB 1939-CB single clutch, home brew water setup.... |
#8
Some of you hacks aren't changing your oil often enough. I can see the hash marks on my dipstick for about 2000 miles after I change my oil.
__________________
If only those who knew what they were talking about replied, this thread would still be on page one. 2000 F-250 CC 4x4 PSD Auto |
#9
it usually take some miles to dirty up the oil,idk what would cause it to turn black that quick.what oil do you run?
__________________
2002 ext. cab lwb 4x4 7.3 05 front 08 rear conversion 4in lift,forged rod motor,tunes by tsd,bts trans,6.0 transcooler,6 autometers to watch,studs,springs,push rods,238cc hybrids,itp reg return,stealth hpop,tsd custom fuel system and sump,an so on 6.0's pay the bills and 6.4's soon.. |
#10
My personal truck the oil stays clean for about 2000-2500 miles and then starts to darken a bit. My work trucks are coal black all the time.
__________________
"Real Trucks Don't Have Sparkplugs" A few mods to make it better than stock. 250cc hybrids, Stealth stage II HPOP, H-11 Headstuds, Strickly Diesel Reg. Return Fuel, Spearco 6.0 IC, Garrett 38r 1.15 hsg, BTS transmission, Gearhead Tuning "The Smoke Don't Mean Its Broke" |
| Thread Tools | |
| Display Modes | |
