how to rebuild fuel pressure regulator - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > F-250 & F-350 1986-1997 & Other Ford Trucks > 1994-1997 Power Stroke Technical Info
Thread Tools Display Modes
  #1
Old 11-06-2011, 02:47 AM
xcessivebronco
Offline
Member's Gallery
as the title says if i take it apart to clean it and put it back together the same way is there anything i need to look for or anything i can mess up?
__________________
Glenn
*1997 Ford F350 CC LB Dually-Tow Vehicle
7.3 Powerstroke-open downpipe
*1998 Ford Expedition
460BB, 24" lift, 44" tires, Dana 60 axles
*1995 Ford Mustang Cobra
460BB Pro Street Car
*1993 Ford F150 Lightning
stock (daily driver)
*New Project* 95 F350 7.3 CC LB on 28L 26 tires, 5 Ton Rockwell Axles, 40" Lift...
Old 11-06-2011, 03:36 AM
Patrick Feeley's Avatar
Patrick Feeley
Offline
Member's Gallery
Re: how to rebuild fuel pressure regulator
If you are talking about the pressure regulator part, it's pretty simple. Remove the 19mm (I think) heax brass plug. Inside will be a spring and valve spool piece. Check the bore and valve spool for scoring and make sure the spring is in good shape. The spring will go on the spool piece bore and the nub on the end of the brass plug. If you are removing the regulator body from the fuel bowl, don't drop the screen assembly, bolts, or the little white plastic check ball (its on the outboard side of the screen) down into the valley of death. If you need new guts for the regulator (just get the CA version) or the screen assembly here are the parts:
Fuel Pressure Regulator (contains spring, valve spool & new brass plug)
(Ford) F5TZ-9K061-A (federal emissions; 94-98)
(Ford) F6TZ-9K061-AA (CA emissions; engine serial no. 201681-98)
Fuel Pressure Regulator Screen Kit
(Ford) F5TZ-9A214-A
Cheers!
__________________
  #3
Old 11-06-2011, 03:59 AM
old man dave
Offline
Terminator Nation
Member's Gallery
URe: how to rebuild fuel pressure regulator
Using the California kit in a federal truck will result in increasing fuel pressure to about 60-65 psi from about 50-55 psi. This can result in the truck running better. You can get the same pressure increase placing a BB behind the fuel regulator spring.
The screen may be no longer availiable so be careful if pulling the regulator assembly off from the fuel cannister, you have to pull it straight off. Once you have the assembly pulled off enough to see the screen then you can degreaser or BreakClean to remove the buildup of junk on the screen without fully removing the regulator assembly.
__________________
Just another 408hp '97 California Truck with a stock muffler
  #4
Old 11-07-2011, 02:23 AM
xcessivebronco
Offline
Member's Gallery
thanks to both of you. ill let you know how it goes
(View-All Members who have read this thread : 113
38R turbo, 4d_powerstroke, 50cal, 70jeeper, 79jasper, 82crawler, 94Matt, 95onetonRigRide, 97crew4x4, ArXane, baggedbug, Bamboo, Big97fordpowerstroke, BIGGPIGG4x4, biggreen96, bigredstroke, bio, Bobby Keller, Bugman, Bulldog, Bushwakd, camd94234, Cascade_Cruiser, Cbass, cooter, cthom388, Deererainman, Dieselboy740, Dieselyoungster, dpulltrk, dsinderson, dzlstroker, Elgin MGP, F-127, f250towrig, firefighterwp1, fitzih29, fordman73, Freshmeat, GASMAN6674, ghostrw, Giarcg, Grandmaspeedshop, GSG, gstang408, hag000, hendricksbus, HMWH, ih1466, ike0321, ilh, Ithumpwheniwalk, iverger, Jaredkeller96, JBone, Jcam88, Jcavers, jeffjam, Jerodl, jerseyrob119, Jnewsome368, jteam, Kcothey, kramarj, loudmouth, mental floss, metrojd, mkelly, muddynoll, mxredneck, ngtstk3r, Nitro41, NORCALOBS95, nujef12, old man dave, Original Guster, Patrick Feeley, PDEMICH, POORBOY1964, pooter, PowerStroke94, pumpkin, rafter3w, raptor, reptillikus, rmckee242, rockets10510, Ron's power stroke, rpm-inc, Russo2, rusty1161, sailor1502, savage250, shredder55, sleepyhead416, Speedracer7c, Ssg MAJ, swjeffcoats, tdevinejr, TNR, tongboy, toolmangary, towsurfer, travis182008, truckcap22, turbo.isaac, txoutlaw, Wengayle, whitie, xcessivebronco, xrcris, YoungFordAddict66, zilla68
You may not post new threads
You may not post replies
Forum Jump
