1997 powerstroke aftermarket exhaust - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > F-250 & F-350 1986-1997 & Other Ford Trucks > 1994-1997 General Aftermarket
Thread Tools Display Modes
  #1
Old 10-26-2011, 02:39 PM
Heartbroke Powerstroke's Avatar
Offline
Member's Gallery
I'm sure this question has been asked before... But is there any aftermarket exhaust (manifold back) that doesn't require you to smash your firewall in with a sledge hammer for installation...? Or as they say... Alter your firewall... I'm not sure Ive ever seen such a ridiculous colaboration of pancaked pipes! What was Ford thinkin? I'd like to rid of this nonsense and wake this bitch up!
Old 10-26-2011, 03:18 PM
wrenchturner250's Avatar
wrenchturner250
Offline
Member's Gallery
Re: 1997 powerstroke aftermarket exhaust
No sir you must alter it or do a body lift
__________________
2007 f250 Sd fx4
Arp's, 4"dp 5" straight pipe with 7" stack,S&B intake, no limit cold side, blue spring, 6.4 banjos, gauges, 2.5" leveling kit,sct with gearhead tunes, egr delete and coolant filter warren 175s, powermax
  #3
Old 10-26-2011, 03:54 PM
94.5stroker's Avatar
94.5stroker
Offline
Member's Gallery
I have heard of people on here not having issues due to how far the engine is set up in it's mounts, and how the cab is mounted. You might be able to slide the engine forward enough to get the dp to clear, but I am not sure on this. I just used a porta-power and moved it a bit and tired the pipe then moved it a little again and so on......
__________________
94.5 F-250 ECLB Flatbed, Rosewood Stage Ones, 3'' dp to 3'' straight, 6637 style intake, gauges, TW Tunes: (stock, high idle, economy, tow, street, extreme), boost fooler, DIY E-Fuel setup.
  #4
Old 10-26-2011, 03:59 PM
Offline
Member's Gallery
Hmm... A body lift? Sounds like a good idea... Would I need to go a full 3" or would 2" work? Does the exhaust clear everything with the body lift installed? Or is there still going to be a passenger in my truck wondering why his shoes are melting from the pipe sticking out of my floor???
  #5
Old 10-26-2011, 04:04 PM
Offline
Member's Gallery
So are the power gains worth the time and money???
  #6
Old 10-26-2011, 04:10 PM
f250towrig
Online
Member's Gallery
I would never go more then 2 in on a body lift. I fit my 3in dp with no altering the firewall.
  #7
Old 10-26-2011, 04:36 PM
Bradbilt's Avatar
Bradbilt
Offline
STILL LEARNING
Member's Gallery
Not really power gains, just better exhaust flow, lowering EGTs
__________________
97 CCSB 4WD 7.3 5spd DP Tuner, 6637, 4" Flo-Pro SS Exhaust(3" DP), 99 I/C, T500,Cali Truck w/120cc Split Shot Injectors, 1.0 exhaust housing/WW2, Irate Up-pipes, CCV Mod, Autometer gauges, Valair Organic clutch, PFM 2.25" RSK, PMF Traction bars, Rear Air bags,SD springs Front(V code)/rear(B code), 315/75/16s, 300HP/561TQ
  #8
Old 10-26-2011, 06:32 PM
Nodge's Avatar
Nodge
Offline
OBS Stroker
Member's Gallery
All you really need to do is cut down, or fold over the pinch weld seam, and you'll have plenty of room. I wouldn't say I smashed my firewall. "Massaged" is a little more accurate. I use a combination of dremel, pry bars, 2x4's, baseball bat, and a 3lb hammer.
It's not that bad.
__________________
1997 F250 ECSB, 140Kmiles, 3.55's, 5 spd, Sht throw, S.B. dd clutch, Rosewood 238/100, Adrenaline, S468, irate mount, ARP studs, 910 springs, smith bros. p/r, 4" MBRP, AFE Stg 2, BDP tunes, Termi Scan gauge, Swamps IDM, intercooled, BDP fuel
1997 F250, CCSB, swamps idm, 3" dp, 3.5" cat delete, 38gal rear tank.
  #9
Old 10-26-2011, 10:06 PM
countryboyrob
Offline
Member's Gallery
It wont be manifold back as there are up-pipes to the turbo, it will be a turboback exhaust, also you dont need to "smash the firewall" or use a sledge hammer. Most people use a pry bar, port-a-power, a baseball bat works great too, its not that hard of an install.
__________________
02 f250
  #10
Old 10-26-2011, 10:30 PM
rancherstroker6's Avatar
rancherstroker6
Offline
Just another OBS addict
Member's Gallery
As others have mentioned, what's the big deal of smashing the firewall? It's not like you're putting a huge hole in it, as Nodge said all you're doing is bending the pinchweld on the bottom of the firewall. It's not that big of a deal once you get the stock pipe out, the pinch weld will be staring you straight in the face, and then it's straight-forward. As was mentioned above, OBS's are known to have different engine placements
(forward or back), so you may not have to alter the firewall even that much. Just make sure you do the firewall before you put the downpipe in the first time...ask me how I know .
__________________
1995 F250 7.3 SCLB 4X4 Auto, D60, Efuel, MBRP Turbo-Back, Tymar Intake, Autometer Gauges, Recon Cab Lights, 05 SD Steering Wheel
Looking for an OBS rear sway bar
(View-All Members who have read this thread : 244
'94IDITurbo7.3, (520)F350, 16yrenthusiest, 1995stroker, 4rcFed, 550ss, 7.3psd1999, 78f100, 82f100swb, 94.5stroker, 94Matt, 95'em, 95gasser, 96f350psd, 96gas2diesel, 96PSD, 96rclb, 96stroker, 96strokerf250, 97 f350 p-stroke, 97Beast, 97biggreen, 97CCLB410LS, 97f3504x4green, 97Powerstroke Boy, 97powerstroke7.3, 97RuffRyd, 97Stroker13, 97supercab, Adam.Niesen, AddictedOffroad, Alberta 7.3, Aubskee, austinlibke, backroad7.3l, balchikonisjeremy, Basso97psd, bert, bfoster, bigshawn, BigSparky, bigtrucks33, bigwhite96stroker, BIG_RED, Bobby Keller, bodaciouscj7, bracketracer, Bradbilt, Brosten, btowngills, bucklee00, CanadianPS, CFiss, Cheapshot, clackster, Clouse2411, Cloverleaffarm, co04cobra, colbev57, cooter, Copperhead, corn fed, csp, cumminskiller69, Cumminspr513, d4klutz, danielzink, david212acu, deadinthewater, Deererainman, dego_red, Delox, Denver, derbyfreak84, Desert Rancher, DieselFreak92, dieselman, Doctorsmack, Drew2010, DRT1359, dukedrummer89, dwelder454, dxp200, e.gresham, evans213, EverettWV, f250towrig, f350pstroke707, farmboy17, FarmBoyStroker, farmer09, firehog2, fitzih29, Flippincgfighter, foxman, frostyweld, Gaius, Goldknight, Got4wd, Greger96obs, greyf350, gsxr1216, H-Bomb, hcwt, Heartbroke Powerstroke, hendricksbus, Hprpartytruck, Htownstroker, Its.Strokn.time, itsdieselornothing, Jarretthise, jasiri, JCart, jclem, jeichert, jim dandy, Jinx, JK Fab, jkrum10238, Josh2021, JoshM, jrbrock, jrcoogs, JRF, jschildm, K5383, konzkustomz, kramarj, krisx125, leojr, LGibbs91, Litnng, littlewoody, lorado04, Lord Humungus, lossscause, loudmouth, lovesdunes, macbanner, madpogue, mattman90, mgraveman, mike scordo, Mini-Stroke..., morbeeeus, mud on the tires7.3, Mudbrother, Mudlight, mwalsh9152, mxredneck, nards_13, nickersonm, Nodge, not enoughsmoke, nova, old man dave, oldfordisbetter, oldschool, Ole, Ole Nasty, ol_blue97, pennsylvaniabo, pff250hd, Pipeliner08, pjwoolw, Plowboy93, poon, power73, Powerjoke4life, powerjoker97, powersmoker73, powerstrokin97, psdmike, rancherstroker6, rashole, rayd1969, redneckabbott, reptillikus, Richie, Rjmorrow, RobCassaday, Robjesup88, ROCKSTAR815, Russ, Russo2, rusty1161, Sackie, saltyfly88, screamnstroker, Shiryas, shmober, sjdiesel, slinga, slutz4, SMOKE&STROKE, southtexasidi, sparkey75, speeddemon, Spmrks, spstactical, Stacked95Flatbed, steelhorse08, stever88, stevv, strokenit97-11, stroker93, strokerjoker, strokernine6, strokin n smokinn, strokin97psd, stupid_rope, Superboy3897, SuperSmoker318, t.land, teevo20, the great white, thenephilm, theoldgirl1990, thewolf, toads250, tonto13, toolmangary, towsurfer, turboaz2, TXStroker97, Ty's Diesel, tyler886, Tylerjm7.3, usmarincorps86, Vannnce, wanagofaster73, wes lewis, whit7452, whitten1, Wolfe88Ford, wrenchturner250, wyocountryboy, YoungFordAddict66
You may not post new threads
You may not post replies
Forum Jump
